10-19-2011 03:17 PM - edited 03-21-2019 04:49 AM
we have cisco UC540 (8.2)
Extension 390 has an AutoAttendant script on CUE.
After initial greeting on 390, a call is being forwarded to the extension 280 (B-ACD queue)
If we make calls from the local IP-phone to extension 390, everything works fine.
If a call comes via a SIP trunk from outside, than after 390 greeting a strange pause comes up (about 30 sec long) and only after that pause starts 280.
In the debug I see that right after 390 there are SIP messages about 280 transfer and dialup is being matched. However, after that a strange pause appears.
Could someone advice on what can be done to remove this pause.
Thank you for your help!
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2011.10.20 01:26:48 =~=~=~=~=~=~=~=~=~=~=~=
Compressed configuration from 40210 bytes to 20024 bytes[OK]
UC_540#sh run
Building configuration...
Current configuration : 41547 bytes
! Last configuration change at 14:23:40 PDT Wed Oct 19 2011 by company
! NVRAM config last updated at 14:23:41 PDT Wed Oct 19 2011 by company
version 15.1
parser config cache interface
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime show-timezone
service password-encryption
service internal
service compress-config
service sequence-numbers
hostname UC_540
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging queue-limit
logging buffered 1000000
no logging rate-limit
enable secret 5 1111
aaa new-model
aaa authentication login default local
aaa authentication login Foxtrot_sdm_easyvpn_xauth_ml_1 local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa authorization network Foxtrot_sdm_easyvpn_group_ml_1 local
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
crypto pki trustpoint TP-self-signed-1455436669
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1455436669
revocation-check none
crypto pki certificate chain TP-self-signed-1455436669
certificate self-signed 01
3082023E 308201A7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31343535 34333636 3639301E 170D3131 31303139 31393034
33395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34353534
33363636 3930819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CC72 35EC0D39 7DD0F392 C3D6D55A 14080428 3704DC59 CA39410E 66A52798
F91C2825 52CC1E37 2141E680 605B330F DAE7C887 DE01BF14 7C770AB4 7C4EB8CD
70CC40CC 2F1276BE 75D943B2 55877B70 45F3095D 0DF89B3D 1127CFAA 0DB167DD
952A8F75 E4E6D808 AD2D304C 24C016BD 90907918 CC06583C 0EF01185 AF0987F2
E0E10203 010001A3 66306430 0F060355 1D130101 FF040530 030101FF 30110603
551D1104 0A300882 0655435F 35343030 1F060355 1D230418 30168014 4EBC0297
0B56A8AB 677A9D31 41D75B7D AEE5BF03 301D0603 551D0E04 1604144E BC02970B
56A8AB67 7A9D3141 D75B7DAE E5BF0330 0D06092A 864886F7 0D010104 05000381
81000569 6B511162 A29CD13F 5BAE211B 5E1DD0C2 45F04FA4 83B5AF6D BBF58C0A
0461C85F 9D0D7825 DFC10728 58910461 34729A10 2F1D21E9 0845D660 2A493165
4CB90165 F227472F 825628DC A4C17B6E 284A60D4 EC694F74 076652F0 941864FA
E6FCEF50 FE3E8FC8 D2868D21 63A1542F 85F82A5D 3A6F6551 BBCE0603 D3B64110 B5FE
quit
dot11 syslog
dot11 ssid Apple Network
vlan 1
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 06021A3644460C1D0445425B59
dot11 ssid cisco-voice
vlan 100
authentication open
wpa-psk ascii 7 104A1C0E0D1F170F0D567A7B71
no ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
no ip bootp server
ip inspect WAAS flush-timeout 10
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 X.X.X.X
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
codec preference 4 g729br8
voice class cause-code 1
no-circuit
voice translation-rule 30
rule 1 /\(.*\)/ /0027357408/
voice translation-rule 40
rule 1 /^41/ //
voice translation-rule 50
rule 1 /\(.*\)/ /00056700/
voice translation-rule 60
rule 1 /^42/ //
voice translation-rule 70
rule 1 /^565678001007772/ /A280/
voice translation-rule 80
rule 1 /^00056700/ /390/
voice translation-rule 90
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2002
rule 1 /^6/ //
rule 2 /^A/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile incoming8800
translate called 70
voice translation-profile inside74957775498
translate called 90
voice translation-profile inside74957737370
translate called 80
voice translation-profile nondialable
translate called 1000
voice translation-profile outside_sipnet
translate calling 30
translate called 60
voice translation-profile outside_telphin
translate calling 50
translate called 40
voice-card 0
dspfarm
dsp services dspfarm
fax interface-type fax-mail
application
service aaservice0 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param aa-pilot 280
paramspace english index 0
param drop-through-prompt _transfer_to_app_order.au
param second-greeting-time 60
paramspace english language ru
param call-retry-timer 5
param voice-mail 399
param max-time-call-retry 600
param service-name bacd
param number-of-hunt-grps 1
paramspace english location flash:/bacdprompts/
param drop-through-option 1
param handoff-string aaservice0
param max-time-vm-retry 1
service aaservice1 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param aa-pilot 281
param drop-through-prompt _bacd_xferto_operator.au
paramspace english language en
param call-retry-timer 15
param drop-through-option 2
param handoff-string aaservice1
service aaservice2 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param max-time-vm-retry 3
param aa-pilot 283
param drop-through-prompt _bacd_music_on_hold.au
param drop-through-option 3
param handoff-string aaservice2
service aaservice3 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param aa-pilot 284
param drop-through-prompt _transfer_test.wav
param drop-through-option 4
param handoff-string aaservice3
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
param number-of-hunt-grps 10
param aa-hunt2 A281
param queue-len 30
param queue-cme-debugs 1
param aa-hunt1 A280
license udi pid UC540W-FXO-K9 sn FHK142872B1
archive
log config
logging enable
logging size 600
hidekeys
username company privilege 15 secret 5 $1$NMoP$kY4U.eT9xj5zE.bO4sJo//
username eddy212 secret 5 $1$G0h2$FTf96DLRvFAUtyIBk3nf81
username viki secret 5 $1$YjTO$uI4jnbroWvnNMGn69sq/10
process-max-time 150
ip tcp synwait-time 10
ip tftp source-interface Loopback0
ip ssh version 2
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
set cos 6
class _class_Voice1
set cos 3
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP_1
key xl2010but
dns 8.8.8.8 192.168.10.1
pool SDM_POOL_1
acl 101
save-password
max-users 10
crypto isakmp profile sdm-ike-profile-1
match identity group EZVPN_GROUP_1
client authentication list Foxtrot_sdm_easyvpn_xauth_ml_1
isakmp authorization list Foxtrot_sdm_easyvpn_group_ml_1
client configuration address respond
virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile SDM_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile sdm-ike-profile-1
bridge irb
interface Loopback0
ip address 10.1.10.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly in
interface Loopback1
ip address 50.50.50.50 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Null0
no ip unreachables
interface FastEthernet0/0
ip address 173.80.80.249 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
switchport mode trunk
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 100 mode ciphers aes-ccm
ssid Apple Network
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Virtual-Template1 type tunnel
ip unnumbered BVI1
tunnel mode ipsec ipv4
tunnel protection ipsec profile SDM_Profile1
interface Virtual-Template2
ip unnumbered Loopback1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface Virtual-Template200 type serial
no ip redirects
no ip unreachables
no ip proxy-arp
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 1
interface Vlan100
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip local pool SDM_WEBVPN_POOL_1 192.168.10.100 192.168.10.105
ip local pool SDM_POOL_1 192.168.10.51 192.168.10.60
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 173.80.80.230
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
logging esm config
logging trap debugging
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.10.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark SDM_ACL Category=4
access-list 101 permit ip 192.168.10.0 0.0.0.255 any
access-list 101 permit ip 10.1.10.0 0.0.0.255 any
access-list 101 permit ip 10.1.1.0 0.0.0.3 any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_23##
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any host 173.80.80.249 eq non500-isakmp
access-list 104 permit udp any host 173.80.80.249 eq isakmp
access-list 104 permit esp any host 173.80.80.249
access-list 104 permit ahp any host 173.80.80.249
access-list 104 permit tcp any host 173.80.80.249 eq 443
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 10.1.1.0 0.0.0.255 any
access-list 104 deny ip 192.168.10.0 0.0.0.255 any
access-list 104 deny ip 51.51.51.0 0.0.0.255 any
access-list 104 permit udp host 8.8.8.8 eq domain any
access-list 104 permit udp host 192.168.10.1 eq domain any
access-list 104 permit icmp any host 173.80.80.249 echo-reply
access-list 104 permit icmp any host 173.80.80.249 time-exceeded
access-list 104 permit icmp any host 173.80.80.249 unreachable
access-list 105 remark SDM_ACL Category=2
access-list 105 deny ip any host 192.168.10.100
access-list 105 deny ip any host 192.168.10.101
access-list 105 deny ip any host 192.168.10.102
access-list 105 deny ip any host 192.168.10.103
access-list 105 deny ip any host 192.168.10.104
access-list 105 deny ip any host 192.168.10.105
access-list 105 deny ip any 192.168.10.48 0.0.0.15
access-list 105 permit ip 10.1.10.0 0.0.0.3 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 105
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/525/spa525g-7-4-8.bin alias spa525g-7-4-8.bin
tftp-server flash:/phones/50x-30x/spa50x-30x-7-4-8a.bin alias spa50x-30x-7-4-8a.bin
tftp-server flash:/phones/7970_7971/apps70.8-5-4TH1-6.sbn alias apps70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/cnu70.8-5-4TH1-6.sbn alias cnu70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.8-5-4TH1-6.sbn alias cvm70sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/dsp70.8-5-4TH1-6.sbn alias dsp70.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.8-5-4TH1-6.sbn alias jar70sccp.8-5-4TH1-6.sbn
tftp-server flash:/phones/7970_7971/SCCP70.8-5-4S.loads alias SCCP70.8-5-4S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
station-id number 401
caller-id enable
voice-port 0/0/1
station-id number 402
caller-id enable
voice-port 0/0/2
station-id number 403
caller-id enable
voice-port 0/0/3
station-id number 404
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
connection plar opx 281
description Configured by CCA 4 FXO-0/1/0-Custom-B_ACD-B_ACD
caller-id enable
voice-port 0/1/1
description Configured by CCA 4 FXO-0/1/1-Custom-B_ACD-B_ACD
caller-id enable
voice-port 0/1/2
description Configured by CCA 4 FXO-0/1/2-Custom-B_ACD-B_ACD
caller-id enable
voice-port 0/1/3
description Configured by CCA 4 FXO-0/1/3-Custom-B_ACD-B_ACD
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register loopback0
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729br8
codec g729r8
associate application SCCP
shutdown
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description catch all dial peer for BRI/PRI^T
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 397
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 58 pots
trunkgroup ALL_FXO
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_FXO
corlist outgoing call-local
description **CCA*North American-10-Digit*10-Digit Local**
preference 5
destination-pattern 9[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
description **CCA*North American-10-Digit*Service Numbers**
preference 5
destination-pattern 9[2-9]11
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_FXO
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
preference 5
destination-pattern 91[2-9]..[2-9]......
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup ALL_FXO
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 5
destination-pattern 9011T
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_FXO
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 5
destination-pattern 91800.......
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91888.......
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91877.......
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91866.......
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_FXO
preference 5
destination-pattern 91855.......
forward-digits all
no sip-register
dial-peer voice 5000 voip
description *** CCA BACD ***
service aaservice0
destination-pattern 280
session target ipv4:192.168.10.1
incoming called-number 280
no voice-class sip outbound-proxy
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 5001 voip
service aaservice1
destination-pattern 281
incoming called-number 281
codec g711ulaw
no vad
dial-peer voice 2002 voip
destination-pattern 390
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 70 voip
description *H323 8800 TRUNK INCOM*
translation-profile incoming incoming8800
shutdown
destination-pattern 565678001007772
session target ipv4:213.145.43.46
incoming called-number 565678001007772
dtmf-relay h245-signal
codec g711ulaw
dial-peer voice 7737370 voip
description *INCOMING_TELFIN*
translation-profile incoming inside74957737370
answer-address .T
session target ipv4:213.170.81.130
session transport udp
incoming called-number 74957737370
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 7775498 voip
description *INCOMING 7775498*
translation-profile incoming inside74957775498
answer-address [7-8]4957775498
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 41 voip
description *TELPHIN*
translation-profile outgoing outside_telphin
preference 5
destination-pattern 41T
session target dns:sip.telphin.com
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 42 voip
description *SIPNET*
translation-profile outgoing outside_sipnet
preference 5
destination-pattern 42T
session target dns:etc.tario.ru
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 71 voip
answer-address .T
codec g729br8
dial-peer voice 2001 voip
description ** cue auto attendant number **
shutdown
b2bua
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 5002 voip
service aaservice2
destination-pattern 283
incoming called-number 283
codec g711ulaw
no vad
dial-peer voice 5003 voip
service aaservice3
destination-pattern 284
incoming called-number 284
codec g711ulaw
no vad
no dial-peer outbound status-check pots
sip-ua
credentials username 0027357408 password 7 111 realm etc.tario.ru
credentials username 00056700 password 7 111 realm sip.telphin.com
credentials username 84957775498 password 7 111 realm qwerty.cnt.ru
authentication username 0027357408 password 7 111 realm etc.tario.ru
no remote-party-id
no redirection
retry invite 3
retry bye 2
retry cancel 2
retry register 10
retry options 1
timers trying 1000
timers connect 1000
timers refer 100
timers register 600
registrar 1 dns:sip.sipnet.ru expires 3600
registrar 2 dns:sip.telphin.com expires 1800
registrar 4 dns:qwerty.cnt.ru expires 1800
registrar 5 ipv4:213.85.168.66 expires 3600
sip-server dns:etc.tario.ru
no suspend-resume
host-registrar
telephony-service
sdspfarm units 1
sdspfarm transcode sessions 4
sdspfarm tag 1 loopback0
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 0
service phone ehookenable 1
service phone SPA525-Encryption-key duwhheda2005
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID cisco-voice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message Company
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
cnf-file perphone
load 7970 SCCP70.8-5-4S
load 7971 SCCP70.8-5-4S
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-8
load 501G spa50x-30x-7-4-8a
load 502G spa50x-30x-7-4-8a
load 504G spa50x-30x-7-4-8a
load 508G spa50x-30x-7-4-8a
load 509G spa50x-30x-7-4-8a
load 525G2 spa525g-7-4-8
load 301 spa50x-30x-7-4-8a
load 303 spa50x-30x-7-4-8a
time-zone 5
keepalive 30 auxiliary 4
live-record 222
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 111
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
night-service date Jan 1 00:00 23:59
night-service date Sep 5 00:00 23:59
night-service date Dec 25 00:00 23:59
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM LiveRcd Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn 299
number A801... no-reg primary
mwi off
ephone-dn 300
number A800... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address E8B7.4815.E9F9
ephone-template 16
max-calls-per-button 2
username "YKhitrykh" password 123456
type 504G
button 1:292
ephone-hunt 1 sequential
pilot 701
list 208, 203, 204, 205, 206, 202
timeout 8, 8, 8, 8, 8, 8
no-reg pilot
statistics collect
description company
ephone-hunt 2 sequential
pilot 702
list 203, 206, 202, 205
timeout 8, 8, 8, 8
no-reg pilot
statistics collect
ephone-hunt 3 sequential
pilot 703
list 201, 202, 210
timeout 8, 8, 8
no-reg pilot
statistics collect
ephone-hunt 50 sequential
pilot A280
list 203, 204, 202, 205, 206, 208
no-reg pilot
statistics collect
auto logout 3
display-logout All agents logged out
ephone-hunt 51 sequential
pilot A281
list 202, 203, 206
timeout 8, 8, 8
no-reg pilot
statistics collect
ephone-hunt 52 sequential
final 390
description *** Reserved for CCA BACD ***
ephone-hunt 53 sequential
ephone-hunt 54 sequential
ephone-hunt 55 sequential
ephone-hunt 56 sequential
ephone-hunt 57 sequential
ephone-hunt 58 sequential
ephone-hunt 59 sequential
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.1 (1). Sat Sep 03 19:34:31 PDT 2011^^C
line con 0
no modem enable
transport output telnet
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input telnet ssh
line vty 5 100
scheduler allocate 4000 1000
scheduler interval 500
ntp master
webvpn gateway SDM_WEBVPN_GATEWAY_1
ip address 173.80.80.249 port 443
ssl trustpoint TP-self-signed-1455436669
inservice
webvpn install svc flash:/webvpn/anyconnect-dart-win-2.5.2001-k9.pkg sequence 1
webvpn context SDM_WEBVPN_CONTEXT_1
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group SDM_WEBVPN_POLICY_1
functions svc-enabled
svc address-pool "SDM_WEBVPN_POOL_1"
virtual-template 2
default-group-policy SDM_WEBVPN_POLICY_1
aaa authentication list sdm_vpn_xauth_ml_1
max-users 10
inservice
end
