After many hours of trial and error I give up and ask for help. I am trying to set up an AA script on a SPA9000 that Answers the phone, gives a message with a press 1 for further informaton and after a little while xfers automatically to the reception. I still have to be able to dial extension numbers for other extension but wants the caller to be automatically xferd to the reception if no input is made.
If the reception is busy I need the caller to hear music while waiting for the receptionist to handle the call before that in the cue. The reception phone is a SPA525.
Is this at all possible? If not I would very much appreciate any workaround that could achieve something similar to the functionality I need.
My other problem is a SPA400 refusing to accept any outgoing or incomming pstn calls. The green leds are flashing when I try to call the number, but nothing happens. When I dial 9 to get the line nothing happens. There is an ADSL connected to the line.
Regards, Kristian
