Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
669
Beginner
Adding 1 to all outgoing calls
I have recently set up a new SIP provider on a UC560 that requires all numbers be 11-digit numbers starting with a 1. Is there any good way to have an outgoing dial-peer to translate all numbers dialed without 1 to add a 1 and the same time if someone does add a 1 a to the number they are dialing that system will treat it normally?
4 REPLIES 4
Participant
Re: Adding 1 to all outgoing calls
Via CLI you can in the dial-peer to prefix a 1
Highlighted
Beginner
Do you mind providing an example? Even sudo-code would be appreciated.
Participant
Basically gain access via CLI
Located the dial-peer, commands as follows when in enable mode
Conf t
Dial-peer voice XX pots
Prefix 1
End
"XX" is the dial peer number you want to edit.
Let me know if you need additional commands
-Mario
Beginner
That's perfect. Thank you very much.
Sent from my iPhone
