Adding 1 to all outgoing calls
pennautomotive
I have recently set up a new SIP provider on a UC560 that requires all numbers be 11-digit numbers starting with a 1. Is there any good way to have an outgoing dial-peer to translate all numbers dialed without 1 to add a 1 and the same time if someone does add a 1 a to the number they are dialing that system will treat it normally?
Mario Garcia
Level 3
Level 3
Via CLI you can in the dial-peer to prefix a 1
Do you mind providing an example? Even sudo-code would be appreciated.
Mario Garcia
Level 3
Level 3
Basically gain access via CLI
Located the dial-peer, commands as follows when in enable mode
Conf t
Dial-peer voice XX pots
Prefix 1
End
"XX" is the dial peer number you want to edit.
Let me know if you need additional commands
-Mario
That's perfect. Thank you very much.
Sent from my iPhone
