I added a 4 port FXS card to a UC500 and I can not seem to find the MAC address of the ports on the card. I want to assign directory number to the FXS ports but I need to create a corresponding ephone with MAC address of the port to assign the number? How can I find this information on the card? I tried "show inv" - "show diag" etc. and I can not figure out how to get this card to show up...
maybe I have to type a global commnad that tells the system the FXS card is in the Uc500? When I add T1 PRI cards I have to add the command "card type t1 0 3" (or something like that) to initialize the PRI card.... but the FXS is confusing me...
Solved! Go to Solution.
If the port is already configured for SCCP you can use "show stcapp device summary". If not, find out what interface SCCP binds to. I think the command is "sccp local
E.g.
UC540#sh int fa 0/0
FastEthernet0/0 is up, line protocol is up
Hardware is PQII_PRO_UEC, address is 5475.d0c6.0bc0 (bia 5475.d0c6.0bc0)
Description: $FW_OUTSIDE$
Internet address is 173.37.196.251/29
Fa 0/1 MAC = 5475.d0c6.0bc0
Take off the first three and suffix 00, 02, 03 to represent each fxs.
5d0c60bc0000
5d0c60bc0001
5d0c60bc0002
5d0c60bc0003
UC540#sh stcapp dev sum
Total Devices: 4
Total Calls in Progress: 0
Total Call Legs in Use: 0
Port Device Device Call Dev Directory Dev
Identifier Name State State Type Number Cntl
0/0/0 AN75D0C60BC0000 IS IDLE ALG 304 CME
0/0/1 AN75D0C60BC0001 IS IDLE ALG 301 CME
0/0/2 AN75D0C60BC0002 IS IDLE ALG 302 CME
0/0/3 AN75D0C60BC0003 IS IDLE ALG 303 CME
UC540#sh ephone reg
ephone-1[0] Mac:5D0C.60BC.0001 TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 9/9 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.1.10.2 * 13121 SCCP Gateway (AN) keepalive 17704 max_line 1 available_line 1
port 0/0/1
button 1: cw:1 ccw:(0 0)
dn 5 number 301 CH1 IDLE CH2 IDLE
Preferred Codec: g711ulaw
Lpcor Type: none Username: anlpha Password: 123456
This is documented somewhere. I'll have to dig to find it.
Anthony Yeung
Technical Marketing Engineer
Small Business Technolog Group
antyeung@cisco.com
Phone: 469.255.7597
E.g.
UC540#sh int fa 0/0
5d0c60bc0000
5d0c60bc0001
5d0c60bc0002
5d0c60bc0003
Total Devices: 4
UC540#sh ephone reg
port 0/0/1
Anthony Yeung
antyeung@cisco.com
Phone: 469.255.7597
That helped. That lead me to add the dial-peers as well (below) and then the system added auto configured ephones with MACs.
dial-peer voice 6 pots
service stcapp
port 0/2/1
dial-peer voice 7 pots
service stcapp
port 0/2/2
dial-peer voice 8 pots
service stcapp
port 0/2/3
dial-peer voice 9 pots
service stcapp
port 0/2/0
