Adding phone firmware to UC540
graeme
We are looking to upgrade our SPA508G firmware in the lab from 7.5.2b  to the latest 7.5.4
I know you are supposed to be able to drag and drop the bin file to the UC in topology view in CCA, but that only works in Window s XP.
We dont have an XP systems around, and I would like to know if there is a way of doing it without having to get and XP machine or install XP Mode.
Any suggestions welcome
Graeme
tftp-server flash:/phones/50x-30x/spa50x-30x-7-5-4.bin alias spa50x-30x-7-5-4
Should be
tftp-server flash:/phones/50x-30x/spa50x-30x-7-5-4.bin alias spa50x-30x-7-5-4.bin
6 Replies 6
danplacek
Level 4
Level 4
You can always do it manually --
1. Upload phone firmware image to proper folder in flash. (Can be done via tftp/ftp or using the file manager in CCA)
2. Add appropriate "tftp-server" lines in config so the file can be found on the tftp server.
3. Update the "load 508G X" line in telephony-service.
4. Restart phones.
-Dan
Please rate useful posts.
Hi Daniel,
I have tried that and it doesnt work.
the phones are still loading the .2b firware.
Graeme
1. In `sh run`, is the "load" statement in telephony service correct?
2. Have you done "no cre cnf" and "cre cnf" under telephony-service?
3. Have you tried "debug tftp events" while a phone is booting to see what files it is looking for?
-Dan
Hi Dan,
the TFTP Line is
and the load is
load 501G spa50x-30x-7-5-4
load 502G spa50x-30x-7-5-4
load 504G spa50x-30x-7-5-4
load 508G spa50x-30x-7-5-4
load 509G spa50x-30x-7-5-4
Which is how the origianl load was and TFTP was written.
TFTP debug is showing
000528: Apr 15 14:23:23.745: TFTP: Looking for spa50x-30x-7-5-4.BIN
and in the flash
Graeme
Should be
Hi Daniel,
that appears to be it.
funny the original line had no .bin on the end, which is the one I changed
and when I tried to pu .bin on the end it wouldnt accept it, now it is..
ah Well
thanks
graeme
