09-22-2009 09:46 AM - edited 03-21-2019 01:32 AM
I have a smaller client that is on a tight budget that has a need for 9 voice users (currently). The quick pricing tool shows that the 8user UC520 and UC540 come with 2 additional licenses for a total of 10 licenses. Can these two additional licenses be used for hardware phones as long as a capable switch is added to the system (i.e. power supply on phone plus 10/100 switch or PoE switch is added)?
Thanks in advance,
Seth
Solved! Go to Solution.
09-22-2009 09:52 AM
You can use these two extra SCCP licenses any way you wish. We call them Soft Phone/Teleworker since people usually dont remember those and we toss them in for good will. But the system doesnt mind how you use them.
Steve DiStefano
SE, US Sales
09-22-2009 09:52 AM
Steve DiStefano
SE, US Sales
09-22-2009 09:54 AM
Hi Seth,
Yes, you can use these floating licenses, however, there will not be any room for growth if we go with the 8-user system. I would strongly recommend that we position a 16-user solution for the customer.
Saurabh
