10-18-2011 02:14 PM - edited 03-21-2019 04:49 AM
WHAT:
Today we are announcing the General Availability of the Cisco UC320W 2.1.2 Firmware release. This release addresses a critical compatibility issue with Adobe Flash Player version 11. If you try to access a UC320W that is running a firmware version lower than 2.1.2 with Adobe Flash Player 11, you will only see a blue screen when trying to access the UC320W Configuration Utility. This compatibility issue prevents the UC320W Configuration Utility from launching.
WHEN:
The 2.1.2 firmware version is available via the Cloud today. This will be posted on CCO in a few days.
HOW:
Log into the UC320W Configuration Utility on a system that has the WAN connected. The 2.1.2 firmware version will appear as an upgrade option.
Please see this discussion for more information and a workaround for the Adobe Flash Player version 11 compatibility issue:
https://supportforums.cisco.com/thread/2112911
Please see the below release notes for upgrade instructions.
Release notes for the Cisco UC320W 2.1.2 firmware release can be found here.
Message was edited by: Chris Edgeworth
10-18-2011 04:06 PM
Are there any other bug fixes, new features, known issues, etc?
10-18-2011 05:46 PM
Check the notes which are linked by the last word of Chris' posting above.
10-19-2011 06:14 AM
Changes Since Firmware Version 2.1.1
• Enhanced the Configuration Utility to work with Flash Player Version 11.
Only one fix...
10-19-2011 06:51 AM
This is a single fix for all customers (GA release). We will have a 2.1.3 Limited Deployment firmware release via a PMF file with a few select bug fixes/improvments posted on the community shortly. Stay tuned.
Chris
10-19-2011 07:47 AM
The thought of 2.1.3 Limited Deployment has me all excited...
Though, I keep checking for updates to see when 2.1.2 will show up on the cloud for me. Still no go...
I know, patience is a virtue. 8-)
10-19-2011 02:45 PM
John,
You should see the 2.1.2 build now. We had a Cloud rule that needed updating for those who had the Release Candidate PMF installed.
Limited Deployment release announcement has been posted: https://supportforums.cisco.com/thread/2111030
Chris
10-19-2011 02:47 PM
Chris,
Yes sir... All updated here to 2.1.2 and Adobe Flash 11 works well.
Grabbing 2.1.3 too!
Thank you!
