03-18-2011 02:53 PM - edited 03-21-2019 03:49 AM
Just a quick question: we're using Catalyst switches instead of EWS switches, and none of our IP phones show up in CCA's "topology view." The box is checked to display IP phones, but non show up. Is there any way I can get them to appear? I have heard that you can reset them from CCA, like after you've pushed a new firmware, rather than having to unplug them all (a pain). Thanks in advance.
Bill
Solved! Go to Solution.
03-20-2011 03:12 PM
Hi Bill,
Have you looked at using Cisco Network Assistance? (CNA)
http://www.cisco.com/en/US/products/ps5931/index.html
Now to me it looks and feels exactly like CCA but it might have different functionality??
Cheers,
David.
03-18-2011 11:24 PM
The topology view shows what CDP discovers in the underlying network, but if you had a few unsupported switches linked together, then you cannot 'add to site' on CCA and allow it to display it's adjacent devices.
You are using a CCA 'site' right and not just connecting with 'connect' to an ip address, right?
The reset all phones capability that used to appear as an option when you right mouse click the UC5xx icon in the topology view was removed (there were problems with it) and is being considered to be put back in the Troubleshooting drawer, where you can select the phones to reset.
Other that that, it would be one at a time in the topology view.
Steve
03-18-2011 11:55 PM
Hi Steven, thanks for your reply. CCA is setup on the initial login screen as a site, and all the check marks are enabled to discover IP phones and CDP. However in the "Topology View" it only shows the Catalyst 3560v2 its directly connected to as an "unsupported device," which I understand, but it shows no IP phones anywhere, even connected to the Catalyst switch it is showing, nor does it show any other Cisco devices on the network. I was expecting it to be able to at least discover other Cisco devices, but it doesn't appear able to do so. It does show Bonjour devices all over the network, even 4 or 5 switches downrange from it, so I was surprised to see it couldn't do the same with CDP devices Thanks again.
Bill
03-20-2011 03:12 PM
Hi Bill,
Cheers,
David.
03-21-2011 12:07 AM
David, I never thought about CNA. Sure enough they show right up. Can't reboot them but can just click and get to the internal webserver on the phone, a nice touch. Thanks!
Bill
