assign static ip to devices (uc 540)
leonardo paredes
Beginner
Beginner
I have a uc540, I want to assign static ip to devices, which is the procedure? Thank you. computers go through an access point.
2 REPLIES 2
Darren DeCroock
Enthusiast
Enthusiast
If you want to use a "static" ip address on the computer, it would have to be set on each computer individually.
If you want to set DHCP bindings for each computer.   In CCA -  Configure > Routing > DHCP Server - DHCP bindings Tab.
Thank you,
Darren
thank you very much
