B-ACD with wrong ringback tone; american instead german
DetNit1101
I configured a UC560 with the package 8.1.0 and set up the B-ACD in drop-through
Everything works fine - only one problem ...
The UC is located in Germany and I use the german localization package
and all call progress tones are german.
But if someone calls the extension of the hunt-group from the B-ACD
he hears the american ringback tone instead of the german.
I can´t find any commands on the CLI or in the CCA and although in the
TCL-scripts app-b-acd-3.0.0.2.tcl I can´t find somehing that matches this feature.
Kind regards,
Detlef
nalbert
Level 4
Level 4
I would recommend that you open a TAC case for this so that CDET is filed and the correct ring back tone is put in. Thanks.
no further help needed ...
Last day I replaced the commands in the telephony-service
user-locale U4 load CME-locale-de_DE-German-8.1.2.1.tar
network-locale U4
with the following statements
user-locale DE load CME-locale-de_DE-German-8.1.2.1.tar
network-locale DE
and it works.
The U4 settings in the configuration are from the CCA, because I set up the UC
with bilingual settings german/english.
But why this error occured ... I don´t know ... however, now it works correct.
Detlef Nitschkowsky
DetNit1101
network-locale U4
network-locale DE
and it works.
Detlef Nitschkowsky
