03-17-2009 05:58 PM - last edited on 03-25-2019 10:34 PM by ciscomoderator
What is the best free ware software to use to size yoru image to png to fit onto the ip phone? I am really hit and miss with the sizing use vista, the fiels are loaded on the flash, the tn shows up in the image background on the phone, but not all of them will apply. It says cannot find file. Yes the xml are correct, I guess it is the sizing of the png file.
03-17-2009 07:48 PM
Any image editor is ok, as long as you honor the following:
Full size image—320 pixels (width) by 212 pixels (height)
Thumbnail image—80 pixels (width) by 53 pixels (height)
The size ratio of these two images is 4 to 1. More info on:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_tech_note09186a008062495a.shtml
Marcos Hernandez
Technical Marketing Engineer
Cisco Systems, Inc.
03-18-2009 07:18 AM
Yep. Great link for 7970.
Just to add, remember that some other phones require different sizes and hence the png and TN need to be TFTPed to other directories on flash...
Example:
7970 - 7971 - 12 Bits - /Desktops/320x212x12
*Full size image - 320 pixels (width) X 212 pixels (height).
*Thumbnail image-80 pixels (width) X 53 pixels (height).
7945 - 7965 - 16 Bits - /Desktops/320x212x16
*Full size image-320 pixels (width) X 212 pixels (height).
7975 - 16 Bits - /Desktops/320x216x16
*Full size image-320 pixels (width) X 216 pixels (height).
