Barcode format
Gilles Girard
What barcode format is used on boxes from Cisco?
I'm not looking to find a device I need to know if it's UPC CODE or EAN CODE or anything else from a long list of possible type.
I found multiple posts but they are old and could not find the answer.
Ref of barcodes types:
https://www.scandit.com/types-barcodes-choosing-right-barcode/
Gilles
Gilles Girard
Using scanner app for android scanning a box of Cisco Nexus 5548P Fan Module
most codes including part and serial #s are using code 128 on this fan module.
Other equipement scanned also included UPC-A and Code 39.
Trying APP from scandit.com. This is the first of 5 software tested that can handle all bar codes + output of the scan can be into anything as they offer a keyboard app that loads the output as keyboards input into anything.
Not sure Android app is the best solution but it was a good start to find what codes are used on Cisco boxes.
Any inputs would be welcome.
