04-01-2015 12:39 PM - edited 03-21-2019 08:36 AM
I have a partner with the following question, they are positioning a BE6000S and they’re asking if the BE6000S supports redundancy, and if so what type of redundancy.
Solved! Go to Solution.
08-04-2015 08:50 AM
Is clustering supported on the BE6000 S for ver 10.5?
08-04-2015 09:12 AM
Yes, it's supported.
- Adrian.
06-19-2015 02:06 PM
Can I use intercluster trunking between a pair of 6Ks's and 7K's? Is this supported?
06-22-2015 10:24 AM
Yes, there is no limitation of features on CUCM.
05-29-2015 01:45 PM
If BE6KS supports only five fixed applications, what is the point of clustering here then?
