07-08-2013 08:13 PM - last edited on 03-25-2019 11:05 PM by ciscomoderator
Can anyone provide me documents,related material, or simple explaination how can BE6K detect or monitor that my setup has multiple remote sites more than it limit of 50. Where does the BE6K monitors this number of remote sites? What happen if it exceed?
07-09-2013 01:08 AM
This is just the maximum number of sites that we have tested with the BE6000 hardware and software specifications.
There are no hard controls that limit the number of sites to 50, but if you have more and run in to performance issues, then technical support may require you to remove some before analysing other fully supported parameters.
Andy
07-09-2013 01:17 AM
Hi Andy,
I appreciate your swift informative response, we will definitely consider your input.
