Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
425
Beginner
Block International Calls
How do I prevent my users from calling international phone numbers?
CUCM 10.0 + Cisco H.323 gateway
Take into consideration that according to the NL numbering plan:
0 - external
00 - long distance
000 - International
So matching for 000 is preceded by a match for either 0 and 00.
I gather I'll have to do something with a route filter, but so far I haven't been able to create one that actually works.
Everyone's tags (1)
2 REPLIES 2
Hall of Fame Cisco Employee
Simply create just a RP to
Simply create just a RP to match 0 and 00 in your CUCM, you can even create one for 000 to block those calls so your users get a message.
java
if this helps, please rate
Highlighted
Beginner
I wasn't able to use a 000
I wasn't able to use a 000 route pattern, the callmanager seemed to like the match for 0 better.
However, I was able to figure out how to use route filters.
- created a 2nd 0.@ with a 2nd route partition (same calling search space).
- created two route filters: 1: no international, 2: international
- set the two filters on the respective route patterns
- enabled Forced Authorization Code on the international route pattern
This way only users that know the code can call international.
