11-28-2011 07:29 PM - edited 03-21-2019 05:00 AM
Anyone know how to block the caller ID on one SIP DID?
I see the setting to set what number you want to use for the DID outbound calls but not an option to block the caller ID.
Anyone know how?
Thanks!
11-29-2011 11:33 AM
Hi Tony,
Have you tried asking your SIP Service provider if they can provision your account to block caller ID for your specific DID?
Chris
01-09-2012 08:52 AM
Did you ever get an answer to this? We want to do the same thing.
We can have the provider block but we want to control it.
Rob
01-09-2012 09:26 AM
We currently have a bug open where *67 Block Caller ID is not working, this also means that the Block CID phone button is not working as well. Engineering is looking at the problem.
Chris
01-09-2012 09:30 AM
Thank for the reply - I think we are looking to do this on a per extension as a permanant setting not on a per call basis.
01-09-2012 09:28 AM
No, there really inst a good way.
I have a workaround.
I setup an inbound route of +6191111111 and assigned it to the extension, so it had this bogus one and the real DID, then I checked marked the +6191111111 to be the outgoing CID (you have to do this is a certain order to get the +6191111111 VS the real DID to show up as checkable, a flaw I think)
There needs to be some better options for setting outbound caller ID. This was easy in FREEPBX/Asterisk.
Good luck.
