07-01-2013 11:37 PM - last edited on 03-25-2019 11:05 PM by ciscomoderator
Dear all,
At the moment I'm setting up two BE6000 v 9.1 in HA with 200 CUWL licenses.
During configuration of Cisco Unity Connection 9.1 I noticed that the maximum number of voicemail ports that I can configure is 8 per CUCx.
The maximum of voice ports supported is 24 per CUCx.
How is the number of available voicemail ports determined? I would have expected to see all 24 ports not only 8.
Is the number of available voice ports linked to the number of CUWL licenses?
JP
Solved! Go to Solution.
07-02-2013 01:17 AM
Hi JP,
Please see the following post regarding this issue:
http://www.cisco.com/web/software/282204704/18582/Readmeforciscocm.cuc_license_patchCOPfile.pdf
The COP file required to fix this is available from:
(ciscocm.cuc_license_patch.cop.sgn)
Andy
07-02-2013 01:17 AM
Hi JP,
Andy
07-02-2013 05:43 AM
Thanks Andy, this was the patch that I needed. I have now on both BE6000 24 voicemail ports.
JP
