Showing results forĀ
Search instead forĀ
Did you mean:Ā
Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1634
marck_renton
Beginner
Call ID SPA9X2
HI,
I'm using the phones SPA9X2 with Asterisk PBX and when a user A make the first call to User B only the called number of user B is displayed on the screen of the user A that make the call.
Why the phones are  not taken the caller id from asterisk? How can I fix this problem??
Thanks.
5 REPLIES 5
icastrov
Dear Sir,
first thing I'd ask you is to upgrade the phone to latest/greatest firmware which is 6.1.5a:
http://www.cisco.com/en/US/prod/voicesw/ps6788/phones/ps10033/ps10036/SPA922_Firmware.zip
Once there, please start playing with the value of the Caller ID Header, under the SIP tab until you get the caller id correctly shown in the phone.
Thanks!
-nacho
the phones already have the latest firmware. i made changes in the value of caller id header but nothings happens.
Dear Sir,
can you please send me the trace on where we can see the SIP INVITE message that is getting the phone? The SPA9x2 configuration will also help...
Thanks!
-nacho
SIP trace the call from extension 5002 to extension 3608. on the screen of extension 5002 I only view the number 3608, not the name of the user..
OK... problem seems to be with the To field in the 180 Ringing message, that's the one the phone will show in the display:
From your trace:
To: <>3608@voip.cl>;tag=as7e178948
As you can see above, only the uri_user (3608) is being shown there... You'd need to change that in your Asterisk PBX in order to also include the uri user in that field.
Thanks!
-nacho
