06-04-2013 03:16 PM - edited 03-21-2019 07:25 AM
Hello there,
We recently setup a new business and have setup four Cisco SPA525G2 IP phones. We are using a hosted PBX service and SIP accounts for our VOIP service.
I have aproblem getting call pickup to work. In the Line Key extended function i have the following string:
fnc=blf+sd+cp;sub=1640000@$PROXY;ext=164000@$PROXY;nme=Bob
the blf and speed dial functions work well but the call pickup does not work. when i press the line key to pickup and incoming call on another extension i get this message "Invalid call: Bob **1640000"
Can someone please throw somw light on this issue?
Thanks in advance
06-04-2013 03:22 PM
Arnold,
You may want to try the Small Business Voice section of the site. They deal more with the SPA phones. You should be able to transfer the post to there.
Brian
06-05-2013 11:17 AM
This is the string I have used successfully.
What firmware version are you on? This is been tested on 7.5.2
fnc=sd+blf+cp;sub=Ext@$proxy;usr=DN@$Proxy
06-05-2013 02:18 PM
Thanks Brenden,
I am currently on Firmware version 4.3.9c so i will update this.
In your string what does "DN" reffer to? is tht direct number?
06-05-2013 02:41 PM
I have upgraded firmware to 7.5.4
String i am using now is:
fnc=sd+blf+cp;sub=1640000@$proxy;usr=1640000@$Proxy
Still no luck, when i press the line key to pickup the call i get:
Line 1 Forbidden to:*08
*08 being the Att Console call pickup code (on both phones)
08-09-2015 12:51 AM
This is PBX issue, not the phone. You have to add extension to the allowed pickup group.
