It is possible to pickup a call in an IP phone from a FXS extension?
Solved! Go to Solution.
I found this: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefacs.html
So I use the comand "fac standard" the codes works with the IP Phones but doesn't with the analog extension.
When the FXS port is configured for SCCP mode, it should work.
Hello Paolo.
Now the extension is configured as SCCP mode and it works.
Thanks.
Thank you for the nice rating and good luck!
Hello Paolo,
Recently I tried this configuration in a custumer with some cordless phone, and for example when I tried to capture a call in another extension, the call is ended, it doesn't happend with a cordle extesión.
