08-30-2013 04:22 AM - edited 03-21-2019 07:43 AM
It is possible to pickup a call in an IP phone from a FXS extension?
Solved! Go to Solution.
08-30-2013 04:27 AM
Yes, you can search "fac codes".
08-30-2013 04:27 AM
08-30-2013 04:56 AM
I found this: http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefacs.html
So I use the comand "fac standard" the codes works with the IP Phones but doesn't with the analog extension.
08-30-2013 11:53 AM
When the FXS port is configured for SCCP mode, it should work.
09-02-2013 12:45 AM
Hello Paolo.
Now the extension is configured as SCCP mode and it works.
Thanks.
09-02-2013 11:12 AM
Thank you for the nice rating and good luck!
09-16-2013 01:54 AM
Hello Paolo,
Recently I tried this configuration in a custumer with some cordless phone, and for example when I tried to capture a call in another extension, the call is ended, it doesn't happend with a cordle extesión.
