Please be advised, the GuideMe Wizard is no longer available on the Small Business Support Community. For search capability please use the community search field to find content related to Cisco Small Business documents, videos, and discussions.
329
call routing
i'm new in CUCM configuration
i just want to route all incoming calls from PSTN to one DN (reception number) , my environment consisted of
1- CUCM 7.1
2- i'm going  outside via VG 2921 connected to primacell
3- VG 2921 is registerd on the CUCM via MGCP
i have no problem in make calls from any DN to outside
thanks
2 REPLIES 2
Highlighted
Enthusiast
Re: call routing
Ahmed,
You just need to setup some translation patterns to make this happen. Nothing CUCC can do to help here. Needs to be done the UCM GUI.
call routing
here i changed all the configuration again on my VG but H323 this time and i got same action i can make call outside but can't get call from PSTN , as i mentioned before i have GSM wireless terminator instead of land line and when i read its manual i got that its port is FXS  , may be the problem is i connect it to FXO port in my VG , but i'm wonder how i can make call to outside .
by the way i have other action occurred , when i call from PSTN to inside i got dial tone but no thing happen inside , and during this if i make call to outside i accidentally answer the PSTN call.
plz help and give me any example of those translation patterns i need to apply
