Caller ID mapping to System Directory
rob
So far the UC320 is working well and replacing an existing Panasonic TD816 system for my customer.
Caller ID is being presented on the phones when an external call is received - however in the previous system, the Caller ID would be matched to the System Directory and if present, the name of the caller (from the directory entry) would be displayed instead.
This made it easier for the users to know who was calling without having to memorise lots of numbers!
This seems to be a relatively standard feature on all small business PBX systems - have I just missed how to implement this in the GUI or is it a feature request that could be added to the roadmap?
Rob.
12 Replies 12
Alberto Montilla
Hi Rob;
Thanks for your email. Glad to hear your deployment is going well.
We have detected the caller ID match to directory is too strict, so match is not happening probably since the string coming does not match exactly to the number. We have this enhancement on the next for the next major release 2.3, which is planned (though not committed yet) for summer 2012. Please stay tuned.
Regards;
Alberto
Hi Alberto,
Is there any more detail on what it's matching? The users don't realy use the system directory for making calls, so I have the option to change the numbers in the directory to exactly match what's required for them to match up.
For example - in the Syslog for an incoming SIP call I have:
From: "07775715715" <>07775715715@sipgate.co.uk>;tag=as72458bba
To: <>00441183215369@sipgate.co.uk>
Contact: <07775715715>
And in the system directory I have an entry for 07775715715 which doesn't make the match at the moment.
Is there someway to see in the syslog what the actual number needs to be in the directory to force the match until the 2.3 release is out?
Rob.
Hi Rob;
Can you send me the whole SIP INVITE message and also let me know what number the phone is showing on the screen as caller ID.
Alberto
Hi Alberto,
The phone is showing 07775715715 as callerid on the display - INVITE is below:
Rob.
Mar  8 12:46:37 UC320W user.debug voice: INVITE sip:1479886@86.21.113.230:5071 SIP/2.0
Record-Route: <217.10.79.23>
Record-Route: <172.20.40.1>
Via: SIP/2.0/UDP 217.10.79.23:5060;branch=z9hG4bKe42.7a42af71.0
Via: SIP/2.0/UDP 172.20.40.1;branch=z9hG4bKe42.7a42af71.0
Via: SIP/2.0/UDP 217.10.79.23:5060;received=217.10.68.222;branch=z9hG4bK6cf58628
Via: SIP/2.0/UDP 217.116.117.5:5060;received=217.116.117.5;branch=z9hG4bK6cf58628;rport=5060
Max-Forwards: 67
Call-ID: 590dca256927546555c53c0c15446d02@sipgate.co.uk
CSeq: 102 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces, timer
Content-Type: application/sdp
Content-Length: 430
v=0
o=root 2124718516 2124718516 IN IP4 217.116.117.5
s=sipgate VoIP GW
c=IN IP4 217.116.117.5
t=0 0
m=audio 19854 RTP/AVP 8 0 3 97 18 112 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:112 G726-32/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Dear Rob;
I have escalated your case to engineering as it seems this issue is beyond the strict matching I was talking about. Stay tuned.
Regards;
Alberto
Hi Rob,
We have identified that this feature is currently broken, and we have opened a couple of defects to track this issue.   SPA 50x, SPA30x - CSCty59185, and for the SPA525 we have defect CSCty59171.
The incoming sip call should match your personal directory entry name if the caller phone number matches your entry.
Best regards,
Julio
Thanks for the update Julio - I presume this gets added to the fix list for a future release, or is there a specific patch that will be created?
Kind Regards,
Rob.
Hi Rob,
I believe the fix will be incorporated to a near future Limited Deployment/General release as this should have high priority.
Cheers,
Julio
HI Julio,
Firmware release 2.2.2 seems doesn't solve this issue.
Do you have any news about it ?
Hi Giorgio,
The bug has been already identified as resolved by development team.  However, since this fix has not made it to an official phone firmware release, it was not available for the UC320W 2.2.2 release.   A near future firmware release with newer phone loads may have this fix in.
Cheers,
Julio
Hi Julio,
Are there any news about this issue ?
It seems impossible that you have not released a patch for this...
Giorgio
Hi Cisco Team,
Seems like Firmware release 2.2.3(5) don't fix this issue.
Since the development team has already resolved the bug, why you don't make available a patch ?
Hope we don't have to wait until fall with the release 2.3...
Giorgio
