10-02-2012 04:32 PM - edited 03-21-2019 06:22 AM
Hi Guys,
I have a UC540 with SIP Trunk porgrammed. I configured "caller ID per Call block code" as "*111" in CCA (Configure-->Telephony->Dial Plan->Outgoing->Caller ID" , then I tried calling outside line from a Cisco SPA500 phone by dialing "0 *111 0283345500" , but the call failed .
Do i need to configure dial plan or something else to get this block code working ?
10-03-2012 03:38 PM
i am not sure, you got it works now, but,,,
you have to dial "*111" before any digits, if your access code is "0" then you dial *111+0+028.........
10-03-2012 03:46 PM
No , i didn't get this one working.....
Cisco Tech had a look at the configuration he said the problem is from the sip provider.
03-18-2013 05:18 PM
Did you ever find a fix for this? running into a very similar issue. Unfortunatley when I trun on debugging the phones starts doing weird and wonderfull things so i cant get a decent SIP debug log of where exactly it is failing.
03-21-2013 09:10 AM
Which debug are you taking? "Debug ccsip message" should not cause any adverse effect.
