Callpickup on SPA504G
janbendaemailcz
I have problems with Pickup function on
SPA504G and asterisk server 1.4.30
I have configured functions  blf, sd, cp on lines 2-4
(regarding http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/administration/guide/spa500_admin.pdf)
(group="Phone/Line_Key_2">fnc=blf+sd+cp;sub=9190@$PROXY;ext=9190@$PROXY</Extended_Function_2_>).
BLF works well, SD works well, but CP does not.
I make a call from SIP/91413 to SIP/9190 and try to pickup the call on SIP/9199
After pushing blinking linebutton, phone sends only *8 to server. I suppose it should be *89190.
===========captured sip============
<--- SIP read from 192.168.3.208:5060 --->
INVITE sip:*8@192.168.3.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.208:5060;branch=z9hG4bK-97685f99
From: "TestPhone" <sip:9199@192.168.3.1>;tag=3a23f052f32f1a31o0
To: <sip:*8@192.168.3.1>
Call-ID: d6bbafa6-e23042ed@192.168.3.208
CSeq: 101 INVITE
Max-Forwards: 70
Contact: "TestPhone" <sip:9199@192.168.3.208:5060>
Expires: 240
User-Agent: Cisco/SPA504G-7.4.9a
Content-Length: 208
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER, UPDATE
Supported: replaces
Content-Type: application/sdp
Dialing manualy *89190 pickups the call.
Any help would be appreciated
thank you
Jan
see bellow log of communication and Output http://192.168.3.208/admin/spacfg.xml
Product Name:     SPA504G Serial Number:     CBT152103LJ
Software Version:     7.4.9a Hardware Version:     1.0.3
MAC Address:     E8B748160C31 Client Certificate:     Installed,
log
[2011-10-26 16:54:59] VERBOSE[6129] logger.c: [2011-10-26 16:54:59]     -- Executing [9190@from-internal:1]
Macro("SIP/91413-0000027e", "exten-vm|novm|9190") in new stack
[2011-10-26 16:54:59] DEBUG[6129] chan_sip.c: Call to peer '9190' is 1 out of 5
[2011-10-26 16:54:59] VERBOSE[6129] logger.c: [2011-10-26 16:54:59]     -- Called 9190
[2011-10-26 16:54:59] DEBUG[31044] chan_sip.c: Strict routing enforced for session 507f6cfb-e26abfd8@192.168.3.208
[2011-10-26 16:54:59] VERBOSE[31044] logger.c: [2011-10-26 16:54:59] set_destination: set destination
to 192.168.3.208, port 5060
[2011-10-26 16:54:59] VERBOSE[31044] logger.c: [2011-10-26 16:54:59] Reliably Transmitting (no NAT) to
192.168.3.208:5060:
NOTIFY sip:9199@192.168.3.208:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK13ff6ac6
To: "TestPhone" <sip:9199@192.168.3.1>;tag=a349c29ff189c684
Contact: <sip:9190@192.168.3.1>
Call-ID: 507f6cfb-e26abfd8@192.168.3.208
CSeq: 107 NOTIFY
User-Agent: Asterisk PBX
Max-Forwards: 70
Event: dialog
Content-Type: application/dialog-info+xml
Subscription-State: active
Content-Length: 221
<?xml version="1.0"?>
<dialog-info xmlns="urn:ietf:params:xml:ns:dialog-info" version="5" state="full" entity="sip:9190@192.168.3.1">
<dialog id="9190" direction="recipient">
<state>early</state>
</dialog>
</dialog-info>
[2011-10-26 16:54:59] VERBOSE[31044] logger.c: [2011-10-26 16:54:59]  Extension Changed 9190[ext-local]
new state Ringing for Notify User 9199
[2011-10-26 16:54:59] VERBOSE[31072] logger.c: [2011-10-26 16:54:59]
SIP/2.0 200 OK
CSeq: 107 NOTIFY
Server: Cisco/SPA504G-7.4.9a
Content-Length: 0
[2011-10-26 16:54:59] VERBOSE[31072] logger.c: [2011-10-26 16:54:59] --- (8 headers 0 lines) ---
[2011-10-26 16:54:59] VERBOSE[31072] logger.c: [2011-10-26 16:54:59] SIP Response message for INCOMING
dialog NOTIFY arrived
[2011-10-26 16:55:00] VERBOSE[6129] logger.c: [2011-10-26 16:55:00]     -- SIP/9190-0000027f is ringing
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03]
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 208
Supported: replaces
v=0
o=- 420828 420828 IN IP4 192.168.3.208
s=-
c=IN IP4 192.168.3.208
t=0 0
m=audio 16424 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] --- (14 headers 11 lines) ---
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Sending to 192.168.3.208 : 5060
(no NAT)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Using INVITE request as basis request
- d6bbafa6-e23042ed@192.168.3.208
<--- Reliably Transmitting (no NAT) to 192.168.3.208:5060 --->
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.168.3.208:5060;branch=z9hG4bK-97685f99;received=192.168.3.208
To: <sip:*8@192.168.3.1>;tag=as6c193d1c
CSeq: 101 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="46fa88e7"
Content-Length: 0
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Scheduling destruction of SIP dialog
'd6bbafa6-e23042ed@192.168.3.208' in 32000 ms (Method: INVITE)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Found user '9199'
ACK sip:*8@192.168.3.1 SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] --- (10 headers 0 lines) ---
Via: SIP/2.0/UDP 192.168.3.208:5060;branch=z9hG4bK-e61e5fb1
CSeq: 102 INVITE
Max-Forwards: 70
Proxy-Authorization: Digest username="9199",realm="asterisk",nonce="46fa88e7",uri="sip:*8@192.168.3.1",algorithm=MD5,resp
onse="53030feda8fabfe60503b779560d09b1"
Expires: 240
Content-Length: 208
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] --- (15 headers 11 lines) ---
(no NAT)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Found RTP audio format 8
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Found RTP audio format 101
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Found audio description format PCMA
for ID 8
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Found audio description format telephone-event
for ID 101
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Capabilities: us - 0xe (gsm|ulaw|alaw),
peer - audio=0x8 (alaw)/video=0x0 (nothing), combined - 0x8 (alaw)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Non-codec capabilities (dtmf): us
- 0x0 (nothing), peer - 0x1 (telephone-event), combined - 0x0 (nothing)
[2011-10-26 16:55:03] DEBUG[31072] chan_sip.c: Our T38 capability = (0), peer T38 capability (0), joint
T38 capability (0)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Peer audio RTP is at port 192.168.3.208:16424
[2011-10-26 16:55:03] DEBUG[31072] chan_sip.c: Call from peer '9199' is 1 out of 5
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Looking for *8 in from-internal
(domain 192.168.3.1)
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] list_route: hop: <sip:9199@192.168.3.208:5060>
<--- Transmitting (no NAT) to 192.168.3.208:5060 --->
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.3.208:5060;branch=z9hG4bK-e61e5fb1;received=192.168.3.208
CSeq: 102 INVITE
Supported: replaces
Contact: <sip:*8@192.168.3.1>
Content-Length: 0
[2011-10-26 16:55:03] NOTICE[31072] chan_sip.c: Nothing to pick up for d6bbafa6-e23042ed@192.168.3.208
SIP/2.0 503 Unavailable
To: <sip:*8@192.168.3.1>;tag=as144556fd
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
[2011-10-26 16:55:03] DEBUG[31072] chan_sip.c: Call from peer '9199' removed from call limit 5
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] --- (11 headers 0 lines) ---
[2011-10-26 16:55:03] VERBOSE[31072] logger.c: [2011-10-26 16:55:03] Really destroying SIP dialog 'd6bbafa6-e23042ed@192.168.3.208'
Method: ACK
[2011-10-26 16:55:07] DEBUG[6129] chan_sip.c: Call to peer '9190' removed from call limit 5
[2011-10-26 16:55:07] VERBOSE[6129] logger.c: [2011-10-26 16:55:07]   == Spawn extension (from-internal,
9190, 1) exited non-zero on 'SIP/91413-0000027e'
[2011-10-26 16:55:07] DEBUG[31044] chan_sip.c: Strict routing enforced for session 507f6cfb-e26abfd8@192.168.3.208
[2011-10-26 16:55:07] VERBOSE[31044] logger.c: [2011-10-26 16:55:07] set_destination: set destination
[2011-10-26 16:55:07] VERBOSE[31044] logger.c: [2011-10-26 16:55:07] Reliably Transmitting (no NAT) to
192.168.3.208:5060:
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK38c624c3
CSeq: 108 NOTIFY
Max-Forwards: 70
Event: dialog
Content-Length: 204
<dialog-info xmlns="urn:ietf:params:xml:ns:dialog-info" version="6" state="full" entity="sip:9190@192.168.3.1">
<dialog id="9190">
<state>terminated</state>
</dialog>
</dialog-info>
[2011-10-26 16:55:07] VERBOSE[31044] logger.c: [2011-10-26 16:55:07]  Extension Changed 9190[ext-local]
new state Idle for Notify User 9199
[2011-10-26 16:55:07] VERBOSE[31072] logger.c: [2011-10-26 16:55:07]
SIP/2.0 200 OK
CSeq: 108 NOTIFY
Content-Length: 0
[2011-10-26 16:55:07] VERBOSE[31072] logger.c: [2011-10-26 16:55:07] --- (8 headers 0 lines) ---
[2011-10-26 16:55:07] VERBOSE[31072] logger.c: [2011-10-26 16:55:07] SIP Response message for INCOMING
[2011-10-26 16:55:07] DEBUG[31072] chan_sip.c: Call to peer '9190' removed from call limit 5
<flat-profile>
<Connection_Type group="Info/System_Information">DHCP</Connection_Type>
<Current_IP group="Info/System_Information">192.168.3.208</Current_IP>
<Host_Name group="Info/System_Information">VoIP-9199</Host_Name>
<Domain group="Info/System_Information">zepter.cz</Domain>
<Current_Netmask group="Info/System_Information">255.255.255.0</Current_Netmask>
<Current_Gateway group="Info/System_Information">192.168.3.1</Current_Gateway>
<Primary__DNS group="Info/System_Information">192.168.2.101</Primary__DNS>
<Secondary__DNS group="Info/System_Information"/>
<Product_Name group="Info/Product_Information">SPA504G</Product_Name>
<Serial_Number group="Info/Product_Information">CBT152504KI</Serial_Number>
<Software_Version group="Info/Product_Information">7.4.9a</Software_Version>
<Hardware_Version group="Info/Product_Information">1.0.3</Hardware_Version>
<MAC_Address group="Info/Product_Information">30E4DB2A696A</MAC_Address>
<Client_Certificate group="Info/Product_Information">Installed</Client_Certificate>
<Customization group="Info/Product_Information">Open</Customization>
<Licenses group="Info/Product_Information">None</Licenses>
<Current_Time group="Info/Phone_Status">10/26/2011 17:48:07</Current_Time>
<Elapsed_Time group="Info/Phone_Status">00:10:19</Elapsed_Time>
<Broadcast_Pkts_Sent group="Info/Phone_Status">5</Broadcast_Pkts_Sent>
<Broadcast_Bytes_Sent group="Info/Phone_Status">826</Broadcast_Bytes_Sent>
<Broadcast_Pkts_Recv group="Info/Phone_Status">34</Broadcast_Pkts_Recv>
<Broadcast_Bytes_Recv group="Info/Phone_Status">2052</Broadcast_Bytes_Recv>
<Broadcast_Pkts_Dropped group="Info/Phone_Status">0</Broadcast_Pkts_Dropped>
<Broadcast_Bytes_Dropped group="Info/Phone_Status">0</Broadcast_Bytes_Dropped>
<RTP_Packets_Sent group="Info/Phone_Status">0</RTP_Packets_Sent>
<RTP_Bytes_Sent group="Info/Phone_Status">0</RTP_Bytes_Sent>
<RTP_Packets_Recv group="Info/Phone_Status">0</RTP_Packets_Recv>
<RTP_Bytes_Recv group="Info/Phone_Status">0</RTP_Bytes_Recv>
<SIP_Messages_Sent group="Info/Phone_Status">21</SIP_Messages_Sent>
<SIP_Bytes_Sent group="Info/Phone_Status">10244</SIP_Bytes_Sent>
<SIP_Messages_Recv group="Info/Phone_Status">24</SIP_Messages_Recv>
<SIP_Bytes_Recv group="Info/Phone_Status">12462</SIP_Bytes_Recv>
<External_IP group="Info/Phone_Status"/>
<Operational_VLAN_ID group="Info/Phone_Status">N/A</Operational_VLAN_ID>
<SW_Port group="Info/Phone_Status">100M Full Duplex</SW_Port>
<PC_Port group="Info/Phone_Status">Link Down</PC_Port>
<Registration_State group="Info/Ext_1_Status">Registered</Registration_State>
<Last_Registration_At group="Info/Ext_1_Status">10/26/2011 17:45:36</Last_Registration_At>
<Next_Registration_In group="Info/Ext_1_Status">318 s</Next_Registration_In>
<Message_Waiting group="Info/Ext_1_Status">No</Message_Waiting>
<Mapped_SIP_Port group="Info/Ext_1_Status"/>
<Registration_State group="Info/Ext_2_Status">Not Registered</Registration_State>
<Last_Registration_At group="Info/Ext_2_Status"/>
<Next_Registration_In group="Info/Ext_2_Status"/>
<Message_Waiting group="Info/Ext_2_Status">No</Message_Waiting>
<Mapped_SIP_Port group="Info/Ext_2_Status"/>
<Registration_State group="Info/Ext_3_Status">Not Registered</Registration_State>
<Last_Registration_At group="Info/Ext_3_Status"/>
<Next_Registration_In group="Info/Ext_3_Status"/>
<Message_Waiting group="Info/Ext_3_Status">No</Message_Waiting>
<Mapped_SIP_Port group="Info/Ext_3_Status"/>
<Registration_State group="Info/Ext_4_Status">Not Registered</Registration_State>
<Last_Registration_At group="Info/Ext_4_Status"/>
<Next_Registration_In group="Info/Ext_4_Status"/>
<Message_Waiting group="Info/Ext_4_Status">No</Message_Waiting>
<Mapped_SIP_Port group="Info/Ext_4_Status"/>
<Call_State group="Info/Line_1_Call_1_Status">Idle</Call_State>
<Tone group="Info/Line_1_Call_1_Status">None</Tone>
<Encoder group="Info/Line_1_Call_1_Status">G711u</Encoder>
<Decoder group="Info/Line_1_Call_1_Status">G711u</Decoder>
<Type group="Info/Line_1_Call_1_Status">Outbound</Type>
<Remote_Hold group="Info/Line_1_Call_1_Status">No</Remote_Hold>
<Callback group="Info/Line_1_Call_1_Status"/>
<Peer_Name group="Info/Line_1_Call_1_Status"/>
<Peer_Phone group="Info/Line_1_Call_1_Status">*8</Peer_Phone>
<Duration group="Info/Line_1_Call_1_Status"/>
<Packets_Sent group="Info/Line_1_Call_1_Status">0</Packets_Sent>
<Packets_Recv group="Info/Line_1_Call_1_Status">0</Packets_Recv>
<Bytes_Sent group="Info/Line_1_Call_1_Status">0</Bytes_Sent>
<Bytes_Recv group="Info/Line_1_Call_1_Status">0</Bytes_Recv>
<Mapped_RTP_Port group="Info/Line_1_Call_1_Status"/>
<Media_Loopback group="Info/Line_1_Call_1_Status"/>
<Decode_Latency group="Info/Line_1_Call_1_Status">0 ms</Decode_Latency>
<Jitter group="Info/Line_1_Call_1_Status">0 ms</Jitter>
<Round_Trip_Delay group="Info/Line_1_Call_1_Status">0 ms</Round_Trip_Delay>
<End_System_Delay group="Info/Line_1_Call_1_Status">0 ms</End_System_Delay>
<Packets_Lost group="Info/Line_1_Call_1_Status">0</Packets_Lost>
<Packet_Error group="Info/Line_1_Call_1_Status">0</Packet_Error>
<Loss_Rate group="Info/Line_1_Call_1_Status">0</Loss_Rate>
<Discard_Rate group="Info/Line_1_Call_1_Status">0</Discard_Rate>
<Burst_Duration group="Info/Line_1_Call_1_Status">0 ms</Burst_Duration>
<Gap_Duration group="Info/Line_1_Call_1_Status">0 ms</Gap_Duration>
<R_Factor group="Info/Line_1_Call_1_Status"/>
<MOS_Listening group="Info/Line_1_Call_1_Status"/>
<MOS_Conversational group="Info/Line_1_Call_1_Status"/>
<Call_State group="Info/Line_1_Call_2_Status">Idle</Call_State>
<Tone group="Info/Line_1_Call_2_Status">None</Tone>
<Encoder group="Info/Line_1_Call_2_Status"/>
<Decoder group="Info/Line_1_Call_2_Status"/>
<Type group="Info/Line_1_Call_2_Status"/>
<Remote_Hold group="Info/Line_1_Call_2_Status"/>
<Callback group="Info/Line_1_Call_2_Status"/>
<Peer_Name group="Info/Line_1_Call_2_Status"/>
<Peer_Phone group="Info/Line_1_Call_2_Status"/>
<Duration group="Info/Line_1_Call_2_Status"/>
<Packets_Sent group="Info/Line_1_Call_2_Status"/>
<Packets_Recv group="Info/Line_1_Call_2_Status"/>
<Bytes_Sent group="Info/Line_1_Call_2_Status"/>
<Bytes_Recv group="Info/Line_1_Call_2_Status"/>
<Mapped_RTP_Port group="Info/Line_1_Call_2_Status"/>
<Media_Loopback group="Info/Line_1_Call_2_Status"/>
<Decode_Latency group="Info/Line_1_Call_2_Status"/>
<Jitter group="Info/Line_1_Call_2_Status"/>
<Round_Trip_Delay group="Info/Line_1_Call_2_Status"/>
<End_System_Delay group="Info/Line_1_Call_2_Status"/>
<Packets_Lost group="Info/Line_1_Call_2_Status"/>
<Packet_Error group="Info/Line_1_Call_2_Status"/>
<Loss_Rate group="Info/Line_1_Call_2_Status"/>
<Discard_Rate group="Info/Line_1_Call_2_Status"/>
<Burst_Duration group="Info/Line_1_Call_2_Status"/>
<Gap_Duration group="Info/Line_1_Call_2_Status"/>
<R_Factor group="Info/Line_1_Call_2_Status"/>
<MOS_Listening group="Info/Line_1_Call_2_Status"/>
<MOS_Conversational group="Info/Line_1_Call_2_Status"/>
<Call_State group="Info/Line_2_Call_1_Status">Disabled</Call_State>
<Tone group="Info/Line_2_Call_1_Status">None</Tone>
<Encoder group="Info/Line_2_Call_1_Status"/>
<Decoder group="Info/Line_2_Call_1_Status"/>
<Type group="Info/Line_2_Call_1_Status"/>
<Remote_Hold group="Info/Line_2_Call_1_Status"/>
<Callback group="Info/Line_2_Call_1_Status"/>
<Peer_Name group="Info/Line_2_Call_1_Status"/>
<Peer_Phone group="Info/Line_2_Call_1_Status"/>
<Duration group="Info/Line_2_Call_1_Status"/>
<Packets_Sent group="Info/Line_2_Call_1_Status"/>
<Packets_Recv group="Info/Line_2_Call_1_Status"/>
<Bytes_Sent group="Info/Line_2_Call_1_Status"/>
<Bytes_Recv group="Info/Line_2_Call_1_Status"/>
<Mapped_RTP_Port group="Info/Line_2_Call_1_Status"/>
<Media_Loopback group="Info/Line_2_Call_1_Status"/>
<Decode_Latency group="Info/Line_2_Call_1_Status"/>
<Jitter group="Info/Line_2_Call_1_Status"/>
<Round_Trip_Delay group="Info/Line_2_Call_1_Status"/>
<End_System_Delay group="Info/Line_2_Call_1_Status"/>
<Packets_Lost group="Info/Line_2_Call_1_Status"/>
<Packet_Error group="Info/Line_2_Call_1_Status"/>
<Loss_Rate group="Info/Line_2_Call_1_Status"/>
<Discard_Rate group="Info/Line_2_Call_1_Status"/>
<Burst_Duration group="Info/Line_2_Call_1_Status"/>
<Gap_Duration group="Info/Line_2_Call_1_Status"/>
<R_Factor group="Info/Line_2_Call_1_Status"/>
<MOS_Listening group="Info/Line_2_Call_1_Status"/>
<MOS_Conversational group="Info/Line_2_Call_1_Status"/>
<Call_State group="Info/Line_2_Call_2_Status">Disabled</Call_State>
<Tone group="Info/Line_2_Call_2_Status">None</Tone>
<Encoder group="Info/Line_2_Call_2_Status"/>
<Decoder group="Info/Line_2_Call_2_Status"/>
<Type group="Info/Line_2_Call_2_Status"/>
<Remote_Hold group="Info/Line_2_Call_2_Status"/>
<Callback group="Info/Line_2_Call_2_Status"/>
<Peer_Name group="Info/Line_2_Call_2_Status"/>
<Peer_Phone group="Info/Line_2_Call_2_Status"/>
<Duration group="Info/Line_2_Call_2_Status"/>
<Packets_Sent group="Info/Line_2_Call_2_Status"/>
<Packets_Recv group="Info/Line_2_Call_2_Status"/>
<Bytes_Sent group="Info/Line_2_Call_2_Status"/>
<Bytes_Recv group="Info/Line_2_Call_2_Status"/>
<Mapped_RTP_Port group="Info/Line_2_Call_2_Status"/>
<Media_Loopback group="Info/Line_2_Call_2_Status"/>
<Decode_Latency group="Info/Line_2_Call_2_Status"/>
<Jitter group="Info/Line_2_Call_2_Status"/>
<Round_Trip_Delay group="Info/Line_2_Call_2_Status"/>
<End_System_Delay group="Info/Line_2_Call_2_Status"/>
<Packets_Lost group="Info/Line_2_Call_2_Status"/>
<Packet_Error group="Info/Line_2_Call_2_Status"/>
<Loss_Rate group="Info/Line_2_Call_2_Status"/>
<Discard_Rate group="Info/Line_2_Call_2_Status"/>
<Burst_Duration group="Info/Line_2_Call_2_Status"/>
<Gap_Duration group="Info/Line_2_Call_2_Status"/>
<R_Factor group="Info/Line_2_Call_2_Status"/>
<MOS_Listening group="Info/Line_2_Call_2_Status"/>
<MOS_Conversational group="Info/Line_2_Call_2_Status"/>
<Call_State group="Info/Line_3_Call_1_Status">Disabled</Call_State>
<Tone group="Info/Line_3_Call_1_Status">None</Tone>
<Encoder group="Info/Line_3_Call_1_Status"/>
<Decoder group="Info/Line_3_Call_1_Status"/>
<Type group="Info/Line_3_Call_1_Status"/>
<Remote_Hold group="Info/Line_3_Call_1_Status"/>
<Callback group="Info/Line_3_Call_1_Status"/>
<Peer_Name group="Info/Line_3_Call_1_Status"/>
<Peer_Phone group="Info/Line_3_Call_1_Status"/>
<Duration group="Info/Line_3_Call_1_Status"/>
<Packets_Sent group="Info/Line_3_Call_1_Status"/>
<Packets_Recv group="Info/Line_3_Call_1_Status"/>
<Bytes_Sent group="Info/Line_3_Call_1_Status"/>
<Bytes_Recv group="Info/Line_3_Call_1_Status"/>
<Mapped_RTP_Port group="Info/Line_3_Call_1_Status"/>
<Media_Loopback group="Info/Line_3_Call_1_Status"/>
<Decode_Latency group="Info/Line_3_Call_1_Status"/>
<Jitter group="Info/Line_3_Call_1_Status"/>
<Round_Trip_Delay group="Info/Line_3_Call_1_Status"/>
<End_System_Delay group="Info/Line_3_Call_1_Status"/>
<Packets_Lost group="Info/Line_3_Call_1_Status"/>
<Packet_Error group="Info/Line_3_Call_1_Status"/>
<Loss_Rate group="Info/Line_3_Call_1_Status"/>
<Discard_Rate group="Info/Line_3_Call_1_Status"/>
<Burst_Duration group="Info/Line_3_Call_1_Status"/>
<Gap_Duration group="Info/Line_3_Call_1_Status"/>
<R_Factor group="Info/Line_3_Call_1_Status"/>
<MOS_Listening group="Info/Line_3_Call_1_Status"/>
<MOS_Conversational group="Info/Line_3_Call_1_Status"/>
<Call_State group="Info/Line_3_Call_2_Status">Disabled</Call_State>
<Tone group="Info/Line_3_Call_2_Status">None</Tone>
<Encoder group="Info/Line_3_Call_2_Status"/>
<Decoder group="Info/Line_3_Call_2_Status"/>
<Type group="Info/Line_3_Call_2_Status"/>
<Remote_Hold group="Info/Line_3_Call_2_Status"/>
<Callback group="Info/Line_3_Call_2_Status"/>
<Peer_Name group="Info/Line_3_Call_2_Status"/>
<Peer_Phone group="Info/Line_3_Call_2_Status"/>
<Duration group="Info/Line_3_Call_2_Status"/>
<Packets_Sent group="Info/Line_3_Call_2_Status"/>
<Packets_Recv group="Info/Line_3_Call_2_Status"/>
<Bytes_Sent group="Info/Line_3_Call_2_Status"/>
<Bytes_Recv group="Info/Line_3_Call_2_Status"/>
<Mapped_RTP_Port group="Info/Line_3_Call_2_Status"/>
<Media_Loopback group="Info/Line_3_Call_2_Status"/>
<Decode_Latency group="Info/Line_3_Call_2_Status"/>
<Jitter group="Info/Line_3_Call_2_Status"/>
<Round_Trip_Delay group="Info/Line_3_Call_2_Status"/>
<End_System_Delay group="Info/Line_3_Call_2_Status"/>
<Packets_Lost group="Info/Line_3_Call_2_Status"/>
<Packet_Error group="Info/Line_3_Call_2_Status"/>
<Loss_Rate group="Info/Line_3_Call_2_Status"/>
<Discard_Rate group="Info/Line_3_Call_2_Status"/>
<Burst_Duration group="Info/Line_3_Call_2_Status"/>
<Gap_Duration group="Info/Line_3_Call_2_Status"/>
<R_Factor group="Info/Line_3_Call_2_Status"/>
<MOS_Listening group="Info/Line_3_Call_2_Status"/>
<MOS_Conversational group="Info/Line_3_Call_2_Status"/>
<Call_State group="Info/Line_4_Call_1_Status">Disabled</Call_State>
<Tone group="Info/Line_4_Call_1_Status">None</Tone>
<Encoder group="Info/Line_4_Call_1_Status"/>
<Decoder group="Info/Line_4_Call_1_Status"/>
<Type group="Info/Line_4_Call_1_Status"/>
<Remote_Hold group="Info/Line_4_Call_1_Status"/>
<Callback group="Info/Line_4_Call_1_Status"/>
<Peer_Name group="Info/Line_4_Call_1_Status"/>
<Peer_Phone group="Info/Line_4_Call_1_Status"/>
<Duration group="Info/Line_4_Call_1_Status"/>
<Packets_Sent group="Info/Line_4_Call_1_Status"/>
<Packets_Recv group="Info/Line_4_Call_1_Status"/>
<Bytes_Sent group="Info/Line_4_Call_1_Status"/>
<Bytes_Recv group="Info/Line_4_Call_1_Status"/>
<Mapped_RTP_Port group="Info/Line_4_Call_1_Status"/>
<Media_Loopback group="Info/Line_4_Call_1_Status"/>
<Decode_Latency group="Info/Line_4_Call_1_Status"/>
<Jitter group="Info/Line_4_Call_1_Status"/>
<Round_Trip_Delay group="Info/Line_4_Call_1_Status"/>
<End_System_Delay group="Info/Line_4_Call_1_Status"/>
<Packets_Lost group="Info/Line_4_Call_1_Status"/>
<Packet_Error group="Info/Line_4_Call_1_Status"/>
<Loss_Rate group="Info/Line_4_Call_1_Status"/>
<Discard_Rate group="Info/Line_4_Call_1_Status"/>
<Burst_Duration group="Info/Line_4_Call_1_Status"/>
<Gap_Duration group="Info/Line_4_Call_1_Status"/>
<R_Factor group="Info/Line_4_Call_1_Status"/>
<MOS_Listening group="Info/Line_4_Call_1_Status"/>
<MOS_Conversational group="Info/Line_4_Call_1_Status"/>
<Call_State group="Info/Line_4_Call_2_Status">Disabled</Call_State>
<Tone group="Info/Line_4_Call_2_Status">None</Tone>
<Encoder group="Info/Line_4_Call_2_Status"/>
<Decoder group="Info/Line_4_Call_2_Status"/>
<Type group="Info/Line_4_Call_2_Status"/>
<Remote_Hold group="Info/Line_4_Call_2_Status"/>
<Callback group="Info/Line_4_Call_2_Status"/>
<Peer_Name group="Info/Line_4_Call_2_Status"/>
<Peer_Phone group="Info/Line_4_Call_2_Status"/>
<Duration group="Info/Line_4_Call_2_Status"/>
<Packets_Sent group="Info/Line_4_Call_2_Status"/>
<Packets_Recv group="Info/Line_4_Call_2_Status"/>
<Bytes_Sent group="Info/Line_4_Call_2_Status"/>
<Bytes_Recv group="Info/Line_4_Call_2_Status"/>
<Mapped_RTP_Port group="Info/Line_4_Call_2_Status"/>
<Media_Loopback group="Info/Line_4_Call_2_Status"/>
<Decode_Latency group="Info/Line_4_Call_2_Status"/>
<Jitter group="Info/Line_4_Call_2_Status"/>
<Round_Trip_Delay group="Info/Line_4_Call_2_Status"/>
<End_System_Delay group="Info/Line_4_Call_2_Status"/>
<Packets_Lost group="Info/Line_4_Call_2_Status"/>
<Packet_Error group="Info/Line_4_Call_2_Status"/>
<Loss_Rate group="Info/Line_4_Call_2_Status"/>
<Discard_Rate group="Info/Line_4_Call_2_Status"/>
<Burst_Duration group="Info/Line_4_Call_2_Status"/>
<Gap_Duration group="Info/Line_4_Call_2_Status"/>
<R_Factor group="Info/Line_4_Call_2_Status"/>
<MOS_Listening group="Info/Line_4_Call_2_Status"/>
<MOS_Conversational group="Info/Line_4_Call_2_Status"/>
<Status group="Info/Downloaded_Ring_Tone">Idle</Status>
<Ring_Tone_1 group="Info/Downloaded_Ring_Tone">Not Installed</Ring_Tone_1>
<Ring_Tone_2 group="Info/Downloaded_Ring_Tone">Not Installed</Ring_Tone_2>
<Restricted_Access_Domains group="System/System_Configuration"/>
<Enable_Web_Server group="System/System_Configuration">Yes</Enable_Web_Server>
<Web_Server_Port group="System/System_Configuration">80</Web_Server_Port>
<Enable_Web_Admin_Access group="System/System_Configuration">Yes</Enable_Web_Admin_Access>
<Admin_Passwd group="System/System_Configuration"/>
<User_Password group="System/System_Configuration"/>
<Signaling_Protocol group="System/System_Configuration">SIP</Signaling_Protocol>
<SPCP_Auto-detect group="System/System_Configuration">Yes</SPCP_Auto-detect>
<Phone-UI-readonly group="System/System_Configuration">No</Phone-UI-readonly>
<Phone-UI-user-mode group="System/System_Configuration">No</Phone-UI-user-mode>
<PoE_Power_Required group="System/Power_Setting">Normal</PoE_Power_Required>
<Connection_Type group="System/Internet_Connection_Type_">DHCP</Connection_Type>
<Static_IP group="System/_Static_IP_Settings"/>
<NetMask group="System/_Static_IP_Settings"/>
<Gateway group="System/_Static_IP_Settings"/>
<HostName group="System/Optional_Network_Configuration">VoIP-9199</HostName>
<Domain group="System/Optional_Network_Configuration"/>
<Primary_DNS group="System/Optional_Network_Configuration"/>
<Secondary_DNS group="System/Optional_Network_Configuration"/>
<DNS_Server_Order group="System/Optional_Network_Configuration">DHCP,Manual</DNS_Server_Order>
<DNS_Query_Mode group="System/Optional_Network_Configuration">Parallel</DNS_Query_Mode>
<DNS_Query_TTL_Ignore group="System/Optional_Network_Configuration">No</DNS_Query_TTL_Ignore>
<Syslog_Server group="System/Optional_Network_Configuration">192.168.3.1</Syslog_Server>
<Debug_Server group="System/Optional_Network_Configuration">192.168.3.1</Debug_Server>
<Debug_Level group="System/Optional_Network_Configuration">1</Debug_Level>
<Layer_2_Logging group="System/Optional_Network_Configuration">No</Layer_2_Logging>
<Primary_NTP_Server group="System/Optional_Network_Configuration">192.168.2.101</Primary_NTP_Server>
<Secondary_NTP_Server group="System/Optional_Network_Configuration"/>
<Enable_VLAN group="System/VLAN_Settings">No</Enable_VLAN>
<Enable_CDP group="System/VLAN_Settings">Yes</Enable_CDP>
<Enable_LLDP-MED group="System/VLAN_Settings">Yes</Enable_LLDP-MED>
<Network_Startup_Delay group="System/VLAN_Settings">3</Network_Startup_Delay>
<VLAN_ID group="System/VLAN_Settings">1</VLAN_ID>
<PC_Port_VLAN_Highest_Priority group="System/VLAN_Settings">No Limit</PC_Port_VLAN_Highest_Priority>
<Enable_PC_Port_VLAN_Tagging group="System/VLAN_Settings">No</Enable_PC_Port_VLAN_Tagging>
<PC_Port_VLAN_ID group="System/VLAN_Settings">1</PC_Port_VLAN_ID>
<Asset_ID group="System/Inventory_Settings"/>
<Max_Forward group="SIP/SIP_Parameters">70</Max_Forward>
<Max_Redirection group="SIP/SIP_Parameters">5</Max_Redirection>
<Max_Auth group="SIP/SIP_Parameters">2</Max_Auth>
<SIP_User_Agent_Name group="SIP/SIP_Parameters">$VERSION</SIP_User_Agent_Name>
<SIP_Server_Name group="SIP/SIP_Parameters">$VERSION</SIP_Server_Name>
<SIP_Reg_User_Agent_Name group="SIP/SIP_Parameters"/>
<SIP_Accept_Language group="SIP/SIP_Parameters"/>
<DTMF_Relay_MIME_Type group="SIP/SIP_Parameters">application/dtmf-relay</DTMF_Relay_MIME_Type>
<Hook_Flash_MIME_Type group="SIP/SIP_Parameters">application/hook-flash</Hook_Flash_MIME_Type>
<Remove_Last_Reg group="SIP/SIP_Parameters">No</Remove_Last_Reg>
<Use_Compact_Header group="SIP/SIP_Parameters">No</Use_Compact_Header>
<Escape_Display_Name group="SIP/SIP_Parameters">No</Escape_Display_Name>
<SIP-B_Enable group="SIP/SIP_Parameters">No</SIP-B_Enable>
<Talk_Package group="SIP/SIP_Parameters">No</Talk_Package>
<Hold_Package group="SIP/SIP_Parameters">No</Hold_Package>
<Conference_Package group="SIP/SIP_Parameters">No</Conference_Package>
<Notify_Conference group="SIP/SIP_Parameters">No</Notify_Conference>
<RFC_2543_Call_Hold group="SIP/SIP_Parameters">Yes</RFC_2543_Call_Hold>
<Random_REG_CID_On_Reboot group="SIP/SIP_Parameters">No</Random_REG_CID_On_Reboot>
<Mark_All_AVT_Packets group="SIP/SIP_Parameters">Yes</Mark_All_AVT_Packets>
<SIP_TCP_Port_Min group="SIP/SIP_Parameters">5060</SIP_TCP_Port_Min>
<SIP_TCP_Port_Max group="SIP/SIP_Parameters">5080</SIP_TCP_Port_Max>
<CTI_Enable group="SIP/SIP_Parameters">No</CTI_Enable>
<Caller_ID_Header group="SIP/SIP_Parameters">PAID-RPID-FROM</Caller_ID_Header>
<SRTP_Method group="SIP/SIP_Parameters">x-sipura</SRTP_Method>
<Hold_Target_Before_REFER group="SIP/SIP_Parameters">No</Hold_Target_Before_REFER>
<Dialog_SDP_Enable group="SIP/SIP_Parameters">No</Dialog_SDP_Enable>
<Keep_Referee_When_REFER_Failed group="SIP/SIP_Parameters">No</Keep_Referee_When_REFER_Failed>
<Display_Diversion_Info group="SIP/SIP_Parameters">No</Display_Diversion_Info>
<SIP_T1 group="SIP/SIP_Timer_Values__sec_">.5</SIP_T1>
<SIP_T2 group="SIP/SIP_Timer_Values__sec_">4</SIP_T2>
<SIP_T4 group="SIP/SIP_Timer_Values__sec_">5</SIP_T4>
<SIP_Timer_B group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_B>
<SIP_Timer_F group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_F>
<SIP_Timer_H group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_H>
<SIP_Timer_D group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_D>
<SIP_Timer_J group="SIP/SIP_Timer_Values__sec_">16</SIP_Timer_J>
<INVITE_Expires group="SIP/SIP_Timer_Values__sec_">240</INVITE_Expires>
<ReINVITE_Expires group="SIP/SIP_Timer_Values__sec_">30</ReINVITE_Expires>
<Reg_Min_Expires group="SIP/SIP_Timer_Values__sec_">1</Reg_Min_Expires>
<Reg_Max_Expires group="SIP/SIP_Timer_Values__sec_">7200</Reg_Max_Expires>
<Reg_Retry_Intvl group="SIP/SIP_Timer_Values__sec_">30</Reg_Retry_Intvl>
<Reg_Retry_Long_Intvl group="SIP/SIP_Timer_Values__sec_">1200</Reg_Retry_Long_Intvl>
<Reg_Retry_Random_Delay group="SIP/SIP_Timer_Values__sec_"/>
<Reg_Retry_Long_Random_Delay group="SIP/SIP_Timer_Values__sec_"/>
<Reg_Retry_Intvl_Cap group="SIP/SIP_Timer_Values__sec_"/>
<Sub_Min_Expires group="SIP/SIP_Timer_Values__sec_">10</Sub_Min_Expires>
<Sub_Max_Expires group="SIP/SIP_Timer_Values__sec_">7200</Sub_Max_Expires>
<Sub_Retry_Intvl group="SIP/SIP_Timer_Values__sec_">10</Sub_Retry_Intvl>
<SIT1_RSC group="SIP/Response_Status_Code_Handling"/>
<SIT2_RSC group="SIP/Response_Status_Code_Handling"/>
<SIT3_RSC group="SIP/Response_Status_Code_Handling"/>
<SIT4_RSC group="SIP/Response_Status_Code_Handling"/>
<Try_Backup_RSC group="SIP/Response_Status_Code_Handling"/>
<Retry_Reg_RSC group="SIP/Response_Status_Code_Handling"/>
<RTP_Port_Min group="SIP/RTP_Parameters">16384</RTP_Port_Min>
<RTP_Port_Max group="SIP/RTP_Parameters">16482</RTP_Port_Max>
<RTP_Packet_Size group="SIP/RTP_Parameters">0.020</RTP_Packet_Size>
<Max_RTP_ICMP_Err group="SIP/RTP_Parameters">0</Max_RTP_ICMP_Err>
<RTCP_Tx_Interval group="SIP/RTP_Parameters">0</RTCP_Tx_Interval>
<No_UDP_Checksum group="SIP/RTP_Parameters">No</No_UDP_Checksum>
<Symmetric_RTP group="SIP/RTP_Parameters">No</Symmetric_RTP>
<Stats_In_BYE group="SIP/RTP_Parameters">No</Stats_In_BYE>
<AVT_Dynamic_Payload group="SIP/SDP_Payload_Types">101</AVT_Dynamic_Payload>
<INFOREQ_Dynamic_Payload group="SIP/SDP_Payload_Types"/>
<G726r16_Dynamic_Payload group="SIP/SDP_Payload_Types">98</G726r16_Dynamic_Payload>
<G726r24_Dynamic_Payload group="SIP/SDP_Payload_Types">97</G726r24_Dynamic_Payload>
<G726r32_Dynamic_Payload group="SIP/SDP_Payload_Types">2</G726r32_Dynamic_Payload>
<G726r40_Dynamic_Payload group="SIP/SDP_Payload_Types">96</G726r40_Dynamic_Payload>
<G729b_Dynamic_Payload group="SIP/SDP_Payload_Types">99</G729b_Dynamic_Payload>
<EncapRTP_Dynamic_Payload group="SIP/SDP_Payload_Types">112</EncapRTP_Dynamic_Payload>
<RTP-Start-Loopback_Dynamic_Payload group="SIP/SDP_Payload_Types">113</RTP-Start-Loopback_Dynamic_Payload>
<RTP-Start-Loopback_Codec group="SIP/SDP_Payload_Types">G711u</RTP-Start-Loopback_Codec>
<AVT_Codec_Name group="SIP/SDP_Payload_Types">telephone-event</AVT_Codec_Name>
<G711u_Codec_Name group="SIP/SDP_Payload_Types">PCMU</G711u_Codec_Name>
<G711a_Codec_Name group="SIP/SDP_Payload_Types">PCMA</G711a_Codec_Name>
<G726r16_Codec_Name group="SIP/SDP_Payload_Types">G726-16</G726r16_Codec_Name>
<G726r24_Codec_Name group="SIP/SDP_Payload_Types">G726-24</G726r24_Codec_Name>
<G726r32_Codec_Name group="SIP/SDP_Payload_Types">G726-32</G726r32_Codec_Name>
<G726r40_Codec_Name group="SIP/SDP_Payload_Types">G726-40</G726r40_Codec_Name>
<G729a_Codec_Name group="SIP/SDP_Payload_Types">G729a</G729a_Codec_Name>
<G729b_Codec_Name group="SIP/SDP_Payload_Types">G729ab</G729b_Codec_Name>
<G722_Codec_Name group="SIP/SDP_Payload_Types">G722</G722_Codec_Name>
<EncapRTP_Codec_Name group="SIP/SDP_Payload_Types">encaprtp</EncapRTP_Codec_Name>
<Handle_VIA_received group="SIP/NAT_Support_Parameters">No</Handle_VIA_received>
<Handle_VIA_rport group="SIP/NAT_Support_Parameters">No</Handle_VIA_rport>
<Insert_VIA_received group="SIP/NAT_Support_Parameters">No</Insert_VIA_received>
<Insert_VIA_rport group="SIP/NAT_Support_Parameters">No</Insert_VIA_rport>
<Substitute_VIA_Addr group="SIP/NAT_Support_Parameters">No</Substitute_VIA_Addr>
<Send_Resp_To_Src_Port group="SIP/NAT_Support_Parameters">Yes</Send_Resp_To_Src_Port>
<STUN_Enable group="SIP/NAT_Support_Parameters">No</STUN_Enable>
<STUN_Test_Enable group="SIP/NAT_Support_Parameters">No</STUN_Test_Enable>
<STUN_Server group="SIP/NAT_Support_Parameters"/>
<EXT_IP group="SIP/NAT_Support_Parameters"/>
<EXT_RTP_Port_Min group="SIP/NAT_Support_Parameters"/>
<NAT_Keep_Alive_Intvl group="SIP/NAT_Support_Parameters">15</NAT_Keep_Alive_Intvl>
<Linksys_Key_System group="SIP/Linksys_Key_System_Parameters">No</Linksys_Key_System>
<Multicast_Address group="SIP/Linksys_Key_System_Parameters">224.168.168.168:6061</Multicast_Address>
<Key_System_Auto_Discovery group="SIP/Linksys_Key_System_Parameters">Yes</Key_System_Auto_Discovery>
<Key_System_IP_Address group="SIP/Linksys_Key_System_Parameters"/>
<Force_LAN_Codec group="SIP/Linksys_Key_System_Parameters">none</Force_LAN_Codec>
<Provision_Enable group="Provisioning/Configuration_Profile">Yes</Provision_Enable>
<Resync_On_Reset group="Provisioning/Configuration_Profile">Yes</Resync_On_Reset>
<Resync_Random_Delay group="Provisioning/Configuration_Profile">0</Resync_Random_Delay>
<Resync_At__HHmm_ group="Provisioning/Configuration_Profile"/>
<Resync_At_Random_Delay group="Provisioning/Configuration_Profile">600</Resync_At_Random_Delay>
<Resync_Periodic group="Provisioning/Configuration_Profile">0</Resync_Periodic>
<Resync_Error_Retry_Delay group="Provisioning/Configuration_Profile">0</Resync_Error_Retry_Delay>
<Forced_Resync_Delay group="Provisioning/Configuration_Profile">0</Forced_Resync_Delay>
<Resync_From_SIP group="Provisioning/Configuration_Profile">No</Resync_From_SIP>
<Resync_After_Upgrade_Attempt group="Provisioning/Configuration_Profile">No</Resync_After_Upgrade_Attempt>
<Resync_Trigger_1 group="Provisioning/Configuration_Profile"/>
<Resync_Trigger_2 group="Provisioning/Configuration_Profile"/>
<Resync_Fails_On_FNF group="Provisioning/Configuration_Profile">No</Resync_Fails_On_FNF>
<Profile_Rule group="Provisioning/Configuration_Profile">http://192.168.3.1/provisioning/linksys.xml</Profile_Rule>
<Profile_Rule_B group="Provisioning/Configuration_Profile">http://192.168.3.1/provisioning/user_$MAC.xml</Profile_Rule_B>
<Profile_Rule_C group="Provisioning/Configuration_Profile"/>
<Profile_Rule_D group="Provisioning/Configuration_Profile"/>
<DHCP_Option_To_Use group="Provisioning/Configuration_Profile">66,160,159,150</DHCP_Option_To_Use>
<Transport_Protocol group="Provisioning/Configuration_Profile">https</Transport_Protocol>
<Log_Resync_Request_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Requesting resync $SCHEME://$SERVIP:$PORT$PATH</Log_Resync_Request_Msg>
<Log_Resync_Success_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Successful resync $SCHEME://$SERVIP:$PORT$PATH</Log_Resync_Success_Msg>
<Log_Resync_Failure_Msg group="Provisioning/Configuration_Profile">$PN $MAC -- Resync failed: $ERR</Log_Resync_Failure_Msg>
<Report_Rule group="Provisioning/Configuration_Profile"/>
<User_Configurable_Resync group="Provisioning/Configuration_Profile">Yes</User_Configurable_Resync>
<Upgrade_Enable group="Provisioning/Firmware_Upgrade">Yes</Upgrade_Enable>
<Upgrade_Error_Retry_Delay group="Provisioning/Firmware_Upgrade">0</Upgrade_Error_Retry_Delay>
<Downgrade_Rev_Limit group="Provisioning/Firmware_Upgrade"/>
<Upgrade_Rule group="Provisioning/Firmware_Upgrade">http://192.168.3.1/provisioning/fw/spa$PSN.bin</Upgrade_Rule>
<Log_Upgrade_Request_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Requesting upgrade $SCHEME://$SERVIP:$PORT$PATH</Log_Upgrade_Request_Msg>
<Log_Upgrade_Success_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Successful upgrade $SCHEME://$SERVIP:$PORT$PATH -- $ERR</Log_Upgrade_Success_Msg>
<Log_Upgrade_Failure_Msg group="Provisioning/Firmware_Upgrade">$PN $MAC -- Upgrade failed: $ERR</Log_Upgrade_Failure_Msg>
<License_Keys group="Provisioning/Firmware_Upgrade"/>
<GPP_A group="Provisioning/General_Purpose_Parameters"/>
<GPP_B group="Provisioning/General_Purpose_Parameters"/>
<GPP_C group="Provisioning/General_Purpose_Parameters"/>
<GPP_D group="Provisioning/General_Purpose_Parameters"/>
<GPP_E group="Provisioning/General_Purpose_Parameters"/>
<GPP_F group="Provisioning/General_Purpose_Parameters"/>
<GPP_G group="Provisioning/General_Purpose_Parameters"/>
<GPP_H group="Provisioning/General_Purpose_Parameters"/>
<GPP_I group="Provisioning/General_Purpose_Parameters"/>
<GPP_J group="Provisioning/General_Purpose_Parameters"/>
<GPP_K group="Provisioning/General_Purpose_Parameters"/>
<GPP_L group="Provisioning/General_Purpose_Parameters"/>
<GPP_M group="Provisioning/General_Purpose_Parameters"/>
<GPP_N group="Provisioning/General_Purpose_Parameters"/>
<GPP_O group="Provisioning/General_Purpose_Parameters"/>
<GPP_P group="Provisioning/General_Purpose_Parameters"/>
<Dial_Tone group="Regional/Call_Progress_Tones">425@-10;30(0.33/0.33/1,0.66/0.66/1)</Dial_Tone>
<Outside_Dial_Tone group="Regional/Call_Progress_Tones">420@-16;10(*/0/1)</Outside_Dial_Tone>
<Prompt_Tone group="Regional/Call_Progress_Tones">520@-19,620@-19;10(*/0/1+2)</Prompt_Tone>
<Busy_Tone group="Regional/Call_Progress_Tones">425@-10;10(0.33/0.33/1)</Busy_Tone>
<Reorder_Tone group="Regional/Call_Progress_Tones">480@-19,620@-19;10(.25/.25/1+2)</Reorder_Tone>
<Off_Hook_Warning_Tone group="Regional/Call_Progress_Tones">480@-10,620@0;10(.125/.125/1+2)</Off_Hook_Warning_Tone>
<Ring_Back_Tone group="Regional/Call_Progress_Tones">425@-10;60(1/4/1)</Ring_Back_Tone>
<Call_Waiting_Tone group="Regional/Call_Progress_Tones">440@-10;30(.3/9.7/1)</Call_Waiting_Tone>
<Confirm_Tone group="Regional/Call_Progress_Tones">600@-16;1(.25/.25/1)</Confirm_Tone>
<SIT1_Tone group="Regional/Call_Progress_Tones">985@-16,1428@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)</SIT1_Tone>
<SIT2_Tone group="Regional/Call_Progress_Tones">914@-16,1371@-16,1777@-16;20(.274/0/1,.274/0/2,.380/0/3,0/4/0)</SIT2_Tone>
<SIT3_Tone group="Regional/Call_Progress_Tones">914@-16,1371@-16,1777@-16;20(.380/0/1,.380/0/2,.380/0/3,0/4/0)</SIT3_Tone>
<SIT4_Tone group="Regional/Call_Progress_Tones">985@-16,1371@-16,1777@-16;20(.380/0/1,.274/0/2,.380/0/3,0/4/0)</SIT4_Tone>
<MWI_Dial_Tone group="Regional/Call_Progress_Tones">350@-19,440@-19;2(.1/.1/1+2);10(*/0/1+2)</MWI_Dial_Tone>
<Cfwd_Dial_Tone group="Regional/Call_Progress_Tones">350@-19,440@-19;2(.2/.2/1+2);10(*/0/1+2)</Cfwd_Dial_Tone>
<Holding_Tone group="Regional/Call_Progress_Tones">600@-19;*(.1/.1/1,.1/.1/1,.1/9.5/1)</Holding_Tone>
<Conference_Tone group="Regional/Call_Progress_Tones">350@-19;20(.1/.1/1,.1/9.7/1)</Conference_Tone>
<Secure_Call_Indication_Tone group="Regional/Call_Progress_Tones">397@-19,507@-19;15(0/2/0,.2/.1/1,.1/2.1/2)</Secure_Call_Indication_Tone>
<Page_Tone group="Regional/Call_Progress_Tones">600@-16;.3(.05/0.05/1)</Page_Tone>
<Alert_Tone group="Regional/Call_Progress_Tones">600@-19;.2(.05/0.05/1)</Alert_Tone>
<Call_Pickup_Tone group="Regional/Call_Progress_Tones">440@-10;30(.3/9.7/1)</Call_Pickup_Tone>
<Cadence_1 group="Regional/Distinctive_Ring_Patterns">60(2/4)</Cadence_1>
<Cadence_2 group="Regional/Distinctive_Ring_Patterns">60(.3/.2,1/.2,.3/4)</Cadence_2>
<Cadence_3 group="Regional/Distinctive_Ring_Patterns">60(.8/.4,.8/4)</Cadence_3>
<Cadence_4 group="Regional/Distinctive_Ring_Patterns">60(.4/.2,.3/.2,.8/4)</Cadence_4>
<Cadence_5 group="Regional/Distinctive_Ring_Patterns">60(.2/.2,.2/.2,.2/.2,1/4)</Cadence_5>
<Cadence_6 group="Regional/Distinctive_Ring_Patterns">60(.2/.4,.2/.4,.2/4)</Cadence_6>
<Cadence_7 group="Regional/Distinctive_Ring_Patterns">60(4.5/4)</Cadence_7>
<Cadence_8 group="Regional/Distinctive_Ring_Patterns">60(0.25/9.75)</Cadence_8>
<Cadence_9 group="Regional/Distinctive_Ring_Patterns">60(.4/.2,.4/2)</Cadence_9>
<Reorder_Delay group="Regional/Control_Timer_Values__sec_">5</Reorder_Delay>
<Call_Back_Expires group="Regional/Control_Timer_Values__sec_">1800</Call_Back_Expires>
<Call_Back_Retry_Intvl group="Regional/Control_Timer_Values__sec_">30</Call_Back_Retry_Intvl>
<Call_Back_Delay group="Regional/Control_Timer_Values__sec_">.5</Call_Back_Delay>
<Interdigit_Long_Timer group="Regional/Control_Timer_Values__sec_">10</Interdigit_Long_Timer>
<Interdigit_Short_Timer group="Regional/Control_Timer_Values__sec_">3</Interdigit_Short_Timer>
<Call_Return_Code group="Regional/Vertical_Service_Activation_Codes">*69</Call_Return_Code>
<Blind_Transfer_Code group="Regional/Vertical_Service_Activation_Codes">*98</Blind_Transfer_Code>
<Call_Back_Act_Code group="Regional/Vertical_Service_Activation_Codes">*66</Call_Back_Act_Code>
<Call_Back_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*86</Call_Back_Deact_Code>
<Cfwd_All_Act_Code group="Regional/Vertical_Service_Activation_Codes">*72</Cfwd_All_Act_Code>
<Cfwd_All_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*73</Cfwd_All_Deact_Code>
<Cfwd_Busy_Act_Code group="Regional/Vertical_Service_Activation_Codes">*90</Cfwd_Busy_Act_Code>
<Cfwd_Busy_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*91</Cfwd_Busy_Deact_Code>
<Cfwd_No_Ans_Act_Code group="Regional/Vertical_Service_Activation_Codes">*92</Cfwd_No_Ans_Act_Code>
<Cfwd_No_Ans_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*93</Cfwd_No_Ans_Deact_Code>
<CW_Act_Code group="Regional/Vertical_Service_Activation_Codes">*56</CW_Act_Code>
<CW_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*57</CW_Deact_Code>
<CW_Per_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes">*71</CW_Per_Call_Act_Code>
<CW_Per_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*70</CW_Per_Call_Deact_Code>
<Block_CID_Act_Code group="Regional/Vertical_Service_Activation_Codes">*67</Block_CID_Act_Code>
<Block_CID_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*68</Block_CID_Deact_Code>
<Block_CID_Per_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes">*81</Block_CID_Per_Call_Act_Code>
<Block_CID_Per_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*82</Block_CID_Per_Call_Deact_Code>
<Block_ANC_Act_Code group="Regional/Vertical_Service_Activation_Codes">*77</Block_ANC_Act_Code>
<Block_ANC_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*87</Block_ANC_Deact_Code>
<DND_Act_Code group="Regional/Vertical_Service_Activation_Codes">*78</DND_Act_Code>
<DND_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*79</DND_Deact_Code>
<Secure_All_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes">*16</Secure_All_Call_Act_Code>
<Secure_No_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes">*17</Secure_No_Call_Act_Code>
<Secure_One_Call_Act_Code group="Regional/Vertical_Service_Activation_Codes">*18</Secure_One_Call_Act_Code>
<Secure_One_Call_Deact_Code group="Regional/Vertical_Service_Activation_Codes">*19</Secure_One_Call_Deact_Code>
<Paging_Code group="Regional/Vertical_Service_Activation_Codes">*96</Paging_Code>
<Call_Park_Code group="Regional/Vertical_Service_Activation_Codes">*38</Call_Park_Code>
<Call_Pickup_Code group="Regional/Vertical_Service_Activation_Codes">*36</Call_Pickup_Code>
<Call_UnPark_Code group="Regional/Vertical_Service_Activation_Codes">*39</Call_UnPark_Code>
<Group_Call_Pickup_Code group="Regional/Vertical_Service_Activation_Codes">*37</Group_Call_Pickup_Code>
<Media_Loopback_Code group="Regional/Vertical_Service_Activation_Codes">*03</Media_Loopback_Code>
<Referral_Services_Codes group="Regional/Vertical_Service_Activation_Codes"/>
<Feature_Dial_Services_Codes group="Regional/Vertical_Service_Activation_Codes"/>
<Service_Annc_Base_Number group="Regional/Vertical_Service_Announcement_Codes"/>
<Service_Annc_Extension_Codes group="Regional/Vertical_Service_Announcement_Codes"/>
<Prefer_G711u_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*017110</Prefer_G711u_Code>
<Force_G711u_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*027110</Force_G711u_Code>
<Prefer_G711a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*017111</Prefer_G711a_Code>
<Force_G711a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*027111</Force_G711a_Code>
<Prefer_G722_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*01722</Prefer_G722_Code>
<Force_G722_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*02722</Force_G722_Code>
<Prefer_G726r16_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172616</Prefer_G726r16_Code>
<Force_G726r16_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272616</Force_G726r16_Code>
<Prefer_G726r24_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172624</Prefer_G726r24_Code>
<Force_G726r24_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272624</Force_G726r24_Code>
<Prefer_G726r32_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172632</Prefer_G726r32_Code>
<Force_G726r32_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272632</Force_G726r32_Code>
<Prefer_G726r40_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0172640</Prefer_G726r40_Code>
<Force_G726r40_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*0272640</Force_G726r40_Code>
<Prefer_G729a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*01729</Prefer_G729a_Code>
<Force_G729a_Code group="Regional/Outbound_Call_Codec_Selection_Codes">*02729</Force_G729a_Code>
<Set_Local_Date__mm_dd_ group="Regional/Miscellaneous"/>
<Set_Local_Time__HH_mm_ group="Regional/Miscellaneous"/>
<Time_Zone group="Regional/Miscellaneous">GMT+01:00</Time_Zone>
<Time_Offset__HH_mm_ group="Regional/Miscellaneous"/>
<Ignore_DHCP_Time_Offset group="Regional/Miscellaneous">Yes</Ignore_DHCP_Time_Offset>
<Daylight_Saving_Time_Rule group="Regional/Miscellaneous">start=3/-1/7/2:0:0;end=10/-1/7/2:0:0;save=1</Daylight_Saving_Time_Rule>
<Daylight_Saving_Time_Enable group="Regional/Miscellaneous">Yes</Daylight_Saving_Time_Enable>
<DTMF_Playback_Level group="Regional/Miscellaneous">-16</DTMF_Playback_Level>
<DTMF_Playback_Length group="Regional/Miscellaneous">.1</DTMF_Playback_Length>
<Inband_DTMF_Boost group="Regional/Miscellaneous">12dB</Inband_DTMF_Boost>
<Dictionary_Server_Script group="Regional/Miscellaneous">serv=http://192.168.2.7/provisioning/;d0=English;x0=en.xml;d1=Czech;x1=cz.xml;d2=Slovak;x2=sk.xml;</Dictionary_Server_Script>
<Language_Selection group="Regional/Miscellaneous">Czech</Language_Selection>
<Default_Character_Encoding group="Regional/Miscellaneous">ISO-8859-1</Default_Character_Encoding>
<Station_Name group="Phone/General"/>
<Station_Display_Name group="Phone/General"/>
<Voice_Mail_Number group="Phone/General"/>
<Text_Logo group="Phone/General"/>
<BMP_Picture_Download_URL group="Phone/General"/>
<Select_Logo group="Phone/General">Default</Select_Logo>
<Select_Background_Picture group="Phone/General">None</Select_Background_Picture>
<Softkey_Labels_Font group="Phone/General">Auto</Softkey_Labels_Font>
<Screen_Saver_Enable group="Phone/General">No</Screen_Saver_Enable>
<Screen_Saver_Wait group="Phone/General">300</Screen_Saver_Wait>
<Screen_Saver_Icon group="Phone/General">Background Picture</Screen_Saver_Icon>
<Extension_1_ group="Phone/Line_Key_1">1</Extension_1_>
<Short_Name_1_ group="Phone/Line_Key_1">$USER</Short_Name_1_>
<Share_Call_Appearance_1_ group="Phone/Line_Key_1">private</Share_Call_Appearance_1_>
<Extended_Function_1_ group="Phone/Line_Key_1"/>
<Extension_2_ group="Phone/Line_Key_2">Disabled</Extension_2_>
<Short_Name_2_ group="Phone/Line_Key_2">190</Short_Name_2_>
<Share_Call_Appearance_2_ group="Phone/Line_Key_2">private</Share_Call_Appearance_2_>
<Extended_Function_2_ group="Phone/Line_Key_2">fnc=blf+sd+cp;sub=9190@$PROXY;ext=9190@$PROXY</Extended_Function_2_>
<Extension_3_ group="Phone/Line_Key_3">Disabled</Extension_3_>
<Short_Name_3_ group="Phone/Line_Key_3">161</Short_Name_3_>
<Share_Call_Appearance_3_ group="Phone/Line_Key_3">private</Share_Call_Appearance_3_>
<Extended_Function_3_ group="Phone/Line_Key_3">fnc=blf+sd+cp;sub=9161@$PROXY;ext=9161@$PROXY</Extended_Function_3_>
<Extension_4_ group="Phone/Line_Key_4">Disabled</Extension_4_>
<Short_Name_4_ group="Phone/Line_Key_4">163</Short_Name_4_>
<Share_Call_Appearance_4_ group="Phone/Line_Key_4">private</Share_Call_Appearance_4_>
<Extended_Function_4_ group="Phone/Line_Key_4">fnc=blf+sd+cp;sub=9163@$PROXY;ext=9163@$PROXY</Extended_Function_4_>
<Line_ID_Mapping group="Phone/Miscellaneous_Line_Key_Settings">Vertical First</Line_ID_Mapping>
<SCA_Barge-In_Enable group="Phone/Miscellaneous_Line_Key_Settings">No</SCA_Barge-In_Enable>
<SCA_Sticky_Auto_Line_Seize group="Phone/Miscellaneous_Line_Key_Settings">No</SCA_Sticky_Auto_Line_Seize>
<Line_Navigation group="Phone/Miscellaneous_Line_Key_Settings">Per Line</Line_Navigation>
<Call_Appearance_Per_Line group="Phone/Miscellaneous_Line_Key_Settings">2</Call_Appearance_Per_Line>
<Idle_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Undefined_LED group="Phone/Line_Key_LED_Pattern"/>
<Local_Seized_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Seized_LED group="Phone/Line_Key_LED_Pattern"/>
<Local_Progressing_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Progressing_LED group="Phone/Line_Key_LED_Pattern"/>
<Local_Ringing_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Ringing_LED group="Phone/Line_Key_LED_Pattern"/>
<Local_Active_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Active_LED group="Phone/Line_Key_LED_Pattern"/>
<Local_Held_LED group="Phone/Line_Key_LED_Pattern"/>
<Remote_Held_LED group="Phone/Line_Key_LED_Pattern"/>
<Register_Failed_LED group="Phone/Line_Key_LED_Pattern"/>
<Disabled_LED group="Phone/Line_Key_LED_Pattern"/>
<Registering_LED group="Phone/Line_Key_LED_Pattern"/>
<Call_Back_Active_LED group="Phone/Line_Key_LED_Pattern"/>
<Trunk_In-use_LED group="Phone/Line_Key_LED_Pattern"/>
<Trunk_No_Service_LED group="Phone/Line_Key_LED_Pattern"/>
<Trunk_Reserved_LED group="Phone/Line_Key_LED_Pattern"/>
<Conference_Serv group="Phone/Supplementary_Services">No</Conference_Serv>
<Attn_Transfer_Serv group="Phone/Supplementary_Services">Yes</Attn_Transfer_Serv>
<Blind_Transfer_Serv group="Phone/Supplementary_Services">No</Blind_Transfer_Serv>
<DND_Serv group="Phone/Supplementary_Services">No</DND_Serv>
<Block_ANC_Serv group="Phone/Supplementary_Services">No</Block_ANC_Serv>
<Call_Back_Serv group="Phone/Supplementary_Services">No</Call_Back_Serv>
<Block_CID_Serv group="Phone/Supplementary_Services">No</Block_CID_Serv>
<Secure_Call_Serv group="Phone/Supplementary_Services">No</Secure_Call_Serv>
<Cfwd_All_Serv group="Phone/Supplementary_Services">No</Cfwd_All_Serv>
<Cfwd_Busy_Serv group="Phone/Supplementary_Services">No</Cfwd_Busy_Serv>
<Cfwd_No_Ans_Serv group="Phone/Supplementary_Services">No</Cfwd_No_Ans_Serv>
<Paging_Serv group="Phone/Supplementary_Services">No</Paging_Serv>
<Call_Park_Serv group="Phone/Supplementary_Services">No</Call_Park_Serv>
<Call_Pick_Up_Serv group="Phone/Supplementary_Services">No</Call_Pick_Up_Serv>
<ACD_Login_Serv group="Phone/Supplementary_Services">No</ACD_Login_Serv>
<Group_Call_Pick_Up_Serv group="Phone/Supplementary_Services">No</Group_Call_Pick_Up_Serv>
<ACD_Ext group="Phone/Supplementary_Services">1</ACD_Ext>
<Service_Annc_Serv group="Phone/Supplementary_Services">No</Service_Annc_Serv>
<Ring1 group="Phone/Ring_Tone">n=Classic-1;w=3;c=1</Ring1>
<Ring2 group="Phone/Ring_Tone">n=Classic-2;w=3;c=2</Ring2>
<Ring3 group="Phone/Ring_Tone">n=Classic-3;w=3;c=3</Ring3>
<Ring4 group="Phone/Ring_Tone">n=Classic-4;w=3;c=4</Ring4>
<Ring5 group="Phone/Ring_Tone">n=Simple-1;w=2;c=1</Ring5>
<Ring6 group="Phone/Ring_Tone">n=Simple-2;w=2;c=2</Ring6>
<Ring7 group="Phone/Ring_Tone">n=Simple-3;w=2;c=3</Ring7>
<Ring8 group="Phone/Ring_Tone">n=Simple-4;w=2;c=4</Ring8>
<Ring9 group="Phone/Ring_Tone">n=Simple-5;w=2;c=5</Ring9>
<Ring10 group="Phone/Ring_Tone">n=Office;w=4;c=1</Ring10>
<Ring11 group="Phone/Ring_Tone">n=Pulse;w=5;c=1</Ring11>
<Ring12 group="Phone/Ring_Tone">n=Du-dut;w=6;c=1</Ring12>
<Handset_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Handset_Input_Gain>
<Headset_Input_Gain group="Phone/Audio_Input_Gain__dB_">6</Headset_Input_Gain>
<Speakerphone_Input_Gain group="Phone/Audio_Input_Gain__dB_">6</Speakerphone_Input_Gain>
<Handset_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Handset_Additional_Input_Gain>
<Headset_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Headset_Additional_Input_Gain>
<Speakerphone_Additional_Input_Gain group="Phone/Audio_Input_Gain__dB_">0</Speakerphone_Additional_Input_Gain>
<Group_Paging_Script group="Phone/Multiple_Paging_Group_Parameters">pggrp=224.168.168.168:34560;name=All;num=800;listen=yes;</Group_Paging_Script>
<Directory_Enable group="Phone/Broadsoft_Settings">No</Directory_Enable>
<XSI_Host_Server group="Phone/Broadsoft_Settings"/>
<Directory_Name group="Phone/Broadsoft_Settings"/>
<Directory_Type group="Phone/Broadsoft_Settings">Enterprise</Directory_Type>
<Directory_UserID group="Phone/Broadsoft_Settings"/>
<Directory_Password group="Phone/Broadsoft_Settings"/>
<LDAP_Dir_Enable group="Phone/LDAP_Corporate_Directory_Search">No</LDAP_Dir_Enable>
<LDAP_Corp_Dir_Name group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Server group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Auth_Method group="Phone/LDAP_Corporate_Directory_Search">None</LDAP_Auth_Method>
<LDAP_Client_DN group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Username group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Password group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Search_Base group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Last_Name_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_First_Name_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Search_Item_3 group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Item_3_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Search_Item_4 group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_item_4_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Display_Attrs group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Number_Mapping group="Phone/LDAP_Corporate_Directory_Search"/>
<XML_Directory_Service_Name group="Phone/XML_Service"/>
<XML_Directory_Service_URL group="Phone/XML_Service"/>
<XML_Application_Service_Name group="Phone/XML_Service"/>
<XML_Application_Service_URL group="Phone/XML_Service"/>
<EM_Enable group="Phone/Extension_Mobility">No</EM_Enable>
<EM_User_Domain group="Phone/Extension_Mobility"/>
<Programmable_Softkey_Enable group="Phone/Programmable_Softkeys">No</Programmable_Softkey_Enable>
<Idle_Key_List group="Phone/Programmable_Softkeys">em_login|1;acd_login|1;acd_logout|1;redial|5;resume|5;dir|6;avail|6;unavail|6;cfwd|7;chkcfwd|7;dnd|8;chkdnd|8;lcr|9;pickup|10;gpickup|11;unpark|12;em_logout</Idle_Key_List>
<Missed_Call_Key_List group="Phone/Programmable_Softkeys">lcr|1;miss|4</Missed_Call_Key_List>
<Off_Hook_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;cfwd|3;dnd|4;lcr|5;unpark|6;pickup|7;gpickup|8;starcode|11;alpha|12</Off_Hook_Key_List>
<Dialing_Input_Key_List group="Phone/Programmable_Softkeys">dial|1;delchar|2;clear|3;cancel|4;left|5;right|6;starcode|7;alpha|8</Dialing_Input_Key_List>
<Progressing_Key_List group="Phone/Programmable_Softkeys">endcall|2</Progressing_Key_List>
<Connected_Key_List group="Phone/Programmable_Softkeys">confLx|1;flash|1;xferLx|2;conf|3;xfer|4;toggle|4;redial|5;dir|6;bxfer|7;park|8;phold</Connected_Key_List>
<Start-Xfer_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;xfer|4;callCancel</Start-Xfer_Key_List>
<Start-Conf_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;conf|3;callCancel</Start-Conf_Key_List>
<Conferencing_Key_List group="Phone/Programmable_Softkeys">redial|1;dir|2;join|3</Conferencing_Key_List>
<Releasing_Key_List group="Phone/Programmable_Softkeys">endcall|2;</Releasing_Key_List>
<Hold_Key_List group="Phone/Programmable_Softkeys">resume|1;endcall|2;newcall|3;redial;dir;cfwd;dnd</Hold_Key_List>
<Ringing_Key_List group="Phone/Programmable_Softkeys">answer|1;ignore|2;toggle|4</Ringing_Key_List>
<Shared_Active_Key_List group="Phone/Programmable_Softkeys">newcall|1;barge|2;cfwd|3;dnd|4</Shared_Active_Key_List>
<Shared_Held_Key_List group="Phone/Programmable_Softkeys">resume|1;barge|2;cfwd|3;dnd|4</Shared_Held_Key_List>
<PSK_1 group="Phone/Programmable_Softkeys"/>
<PSK_2 group="Phone/Programmable_Softkeys"/>
<PSK_3 group="Phone/Programmable_Softkeys"/>
<PSK_4 group="Phone/Programmable_Softkeys"/>
<PSK_5 group="Phone/Programmable_Softkeys"/>
<PSK_6 group="Phone/Programmable_Softkeys"/>
<Line_Enable_1_ group="Ext_1/General">Yes</Line_Enable_1_>
<Share_Ext_1_ group="Ext_1/Share_Line_Appearance">private</Share_Ext_1_>
<Shared_User_ID_1_ group="Ext_1/Share_Line_Appearance"/>
<Subscription_Expires_1_ group="Ext_1/Share_Line_Appearance">3600</Subscription_Expires_1_>
<Restrict_MWI_1_ group="Ext_1/Share_Line_Appearance">No</Restrict_MWI_1_>
<Monitor_User_ID_1_ group="Ext_1/Share_Line_Appearance"/>
<NAT_Mapping_Enable_1_ group="Ext_1/NAT_Settings">No</NAT_Mapping_Enable_1_>
<NAT_Keep_Alive_Enable_1_ group="Ext_1/NAT_Settings">No</NAT_Keep_Alive_Enable_1_>
<NAT_Keep_Alive_Msg_1_ group="Ext_1/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_1_>
<NAT_Keep_Alive_Dest_1_ group="Ext_1/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_1_>
<SIP_TOS_DiffServ_Value_1_ group="Ext_1/Network_Settings">0x68</SIP_TOS_DiffServ_Value_1_>
<SIP_CoS_Value_1_ group="Ext_1/Network_Settings">3</SIP_CoS_Value_1_>
<RTP_TOS_DiffServ_Value_1_ group="Ext_1/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_1_>
<RTP_CoS_Value_1_ group="Ext_1/Network_Settings">6</RTP_CoS_Value_1_>
<Network_Jitter_Level_1_ group="Ext_1/Network_Settings">low</Network_Jitter_Level_1_>
<Jitter_Buffer_Adjustment_1_ group="Ext_1/Network_Settings">disable</Jitter_Buffer_Adjustment_1_>
<SIP_Transport_1_ group="Ext_1/SIP_Settings">UDP</SIP_Transport_1_>
<SIP_Port_1_ group="Ext_1/SIP_Settings">5060</SIP_Port_1_>
<SIP_100REL_Enable_1_ group="Ext_1/SIP_Settings">No</SIP_100REL_Enable_1_>
<EXT_SIP_Port_1_ group="Ext_1/SIP_Settings"/>
<Auth_Resync-Reboot_1_ group="Ext_1/SIP_Settings">Yes</Auth_Resync-Reboot_1_>
<SIP_Proxy-Require_1_ group="Ext_1/SIP_Settings"/>
<SIP_Remote-Party-ID_1_ group="Ext_1/SIP_Settings">No</SIP_Remote-Party-ID_1_>
<Referor_Bye_Delay_1_ group="Ext_1/SIP_Settings">4</Referor_Bye_Delay_1_>
<Refer-To_Target_Contact_1_ group="Ext_1/SIP_Settings">No</Refer-To_Target_Contact_1_>
<Referee_Bye_Delay_1_ group="Ext_1/SIP_Settings">0</Referee_Bye_Delay_1_>
<SIP_Debug_Option_1_ group="Ext_1/SIP_Settings">none</SIP_Debug_Option_1_>
<Refer_Target_Bye_Delay_1_ group="Ext_1/SIP_Settings">0</Refer_Target_Bye_Delay_1_>
<Sticky_183_1_ group="Ext_1/SIP_Settings">No</Sticky_183_1_>
<Auth_INVITE_1_ group="Ext_1/SIP_Settings">No</Auth_INVITE_1_>
<Ntfy_Refer_On_1xx-To-Inv_1_ group="Ext_1/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_1_>
<Use_Anonymous_With_RPID_1_ group="Ext_1/SIP_Settings">Yes</Use_Anonymous_With_RPID_1_>
<Set_G729_annexb_1_ group="Ext_1/SIP_Settings">none</Set_G729_annexb_1_>
<Voice_Quality_Report_Address_1_ group="Ext_1/SIP_Settings"/>
<Blind_Attn-Xfer_Enable_1_ group="Ext_1/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_1_>
<MOH_Server_1_ group="Ext_1/Call_Feature_Settings"/>
<Message_Waiting_1_ group="Ext_1/Call_Feature_Settings">No</Message_Waiting_1_>
<Auth_Page_1_ group="Ext_1/Call_Feature_Settings">No</Auth_Page_1_>
<Default_Ring__1__ group="Ext_1/Call_Feature_Settings">1</Default_Ring__1__>
<Auth_Page_Realm_1_ group="Ext_1/Call_Feature_Settings"/>
<Conference_Bridge_URL_1_ group="Ext_1/Call_Feature_Settings"/>
<Auth_Page_Password_1_ group="Ext_1/Call_Feature_Settings"/>
<Mailbox_ID_1_ group="Ext_1/Call_Feature_Settings"/>
<Voice_Mail_Server_1_ group="Ext_1/Call_Feature_Settings"/>
<Voice_Mail_Subscribe_Interval_1_ group="Ext_1/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_1_>
<State_Agent_1_ group="Ext_1/Call_Feature_Settings"/>
<CFWD_Notify_Serv_1_ group="Ext_1/Call_Feature_Settings">No</CFWD_Notify_Serv_1_>
<CFWD_Notifier_1_ group="Ext_1/Call_Feature_Settings"/>
<User_ID_with_Domain_1_ group="Ext_1/Call_Feature_Settings">No</User_ID_with_Domain_1_>
<Broadsoft_ACD_1_ group="Ext_1/Call_Feature_Settings">No</Broadsoft_ACD_1_>
<Auto_Ans_Page_On_Active_Call_1_ group="Ext_1/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_1_>
<Feature_Key_Sync_1_ group="Ext_1/Call_Feature_Settings">No</Feature_Key_Sync_1_>
<Proxy_1_ group="Ext_1/Proxy_and_Registration">192.168.3.1</Proxy_1_>
<Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration"/>
<Alternate_Proxy_1_ group="Ext_1/Proxy_and_Registration"/>
<Alternate_Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration"/>
<Use_Outbound_Proxy_1_ group="Ext_1/Proxy_and_Registration">No</Use_Outbound_Proxy_1_>
<Use_OB_Proxy_In_Dialog_1_ group="Ext_1/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_1_>
<Register_1_ group="Ext_1/Proxy_and_Registration">Yes</Register_1_>
<Make_Call_Without_Reg_1_ group="Ext_1/Proxy_and_Registration">No</Make_Call_Without_Reg_1_>
<Register_Expires_1_ group="Ext_1/Proxy_and_Registration">600</Register_Expires_1_>
<Ans_Call_Without_Reg_1_ group="Ext_1/Proxy_and_Registration">No</Ans_Call_Without_Reg_1_>
<Use_DNS_SRV_1_ group="Ext_1/Proxy_and_Registration">No</Use_DNS_SRV_1_>
<DNS_SRV_Auto_Prefix_1_ group="Ext_1/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_1_>
<Proxy_Fallback_Intvl_1_ group="Ext_1/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_1_>
<Proxy_Redundancy_Method_1_ group="Ext_1/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_1_>
<Dual_Registration_1_ group="Ext_1/Proxy_and_Registration">No</Dual_Registration_1_>
<Display_Name_1_ group="Ext_1/Subscriber_Information">TestPhone</Display_Name_1_>
<User_ID_1_ group="Ext_1/Subscriber_Information">9199</User_ID_1_>
<Password_1_ group="Ext_1/Subscriber_Information">*************</Password_1_>
<Use_Auth_ID_1_ group="Ext_1/Subscriber_Information">No</Use_Auth_ID_1_>
<Auth_ID_1_ group="Ext_1/Subscriber_Information"/>
<Reversed_Auth_Realm_1_ group="Ext_1/Subscriber_Information"/>
<Mini_Certificate_1_ group="Ext_1/Subscriber_Information"/>
<SRTP_Private_Key_1_ group="Ext_1/Subscriber_Information"/>
<Preferred_Codec_1_ group="Ext_1/Audio_Configuration">G711a</Preferred_Codec_1_>
<Use_Pref_Codec_Only_1_ group="Ext_1/Audio_Configuration">Yes</Use_Pref_Codec_Only_1_>
<Second_Preferred_Codec_1_ group="Ext_1/Audio_Configuration">Unspecified</Second_Preferred_Codec_1_>
<Third_Preferred_Codec_1_ group="Ext_1/Audio_Configuration">Unspecified</Third_Preferred_Codec_1_>
<G729a_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G729a_Enable_1_>
<G722_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G722_Enable_1_>
<G726-16_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-16_Enable_1_>
<G726-24_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-24_Enable_1_>
<G726-32_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-32_Enable_1_>
<G726-40_Enable_1_ group="Ext_1/Audio_Configuration">Yes</G726-40_Enable_1_>
<Release_Unused_Codec_1_ group="Ext_1/Audio_Configuration">Yes</Release_Unused_Codec_1_>
<DTMF_Process_AVT_1_ group="Ext_1/Audio_Configuration">Yes</DTMF_Process_AVT_1_>
<Silence_Supp_Enable_1_ group="Ext_1/Audio_Configuration">No</Silence_Supp_Enable_1_>
<DTMF_Tx_Method_1_ group="Ext_1/Audio_Configuration">InBand</DTMF_Tx_Method_1_>
<DTMF_Tx_Volume_for_AVT_Packet_1_ group="Ext_1/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_1_>
<Use_Remote_Pref_Codec_1_ group="Ext_1/Audio_Configuration">No</Use_Remote_Pref_Codec_1_>
<Codec_Negotiation_1_ group="Ext_1/Audio_Configuration">Default</Codec_Negotiation_1_>
<Dial_Plan_1_ group="Ext_1/Dial_Plan">(*x.|*2|xxx|xxxxx|xxxxxx|[2-8]xxxxxxxxS0|xx.|xx.*x.|09x.*|09x.**|**77|11*)</Dial_Plan_1_>
<Caller_ID_Map_1_ group="Ext_1/Dial_Plan"/>
<Enable_IP_Dialing_1_ group="Ext_1/Dial_Plan">Yes</Enable_IP_Dialing_1_>
<Emergency_Number_1_ group="Ext_1/Dial_Plan"/>
<Line_Enable_2_ group="Ext_2/General">Yes</Line_Enable_2_>
<Share_Ext_2_ group="Ext_2/Share_Line_Appearance">private</Share_Ext_2_>
<Shared_User_ID_2_ group="Ext_2/Share_Line_Appearance"/>
<Subscription_Expires_2_ group="Ext_2/Share_Line_Appearance">3600</Subscription_Expires_2_>
<Restrict_MWI_2_ group="Ext_2/Share_Line_Appearance">No</Restrict_MWI_2_>
<Monitor_User_ID_2_ group="Ext_2/Share_Line_Appearance"/>
<NAT_Mapping_Enable_2_ group="Ext_2/NAT_Settings">No</NAT_Mapping_Enable_2_>
<NAT_Keep_Alive_Enable_2_ group="Ext_2/NAT_Settings">No</NAT_Keep_Alive_Enable_2_>
<NAT_Keep_Alive_Msg_2_ group="Ext_2/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_2_>
<NAT_Keep_Alive_Dest_2_ group="Ext_2/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_2_>
<SIP_TOS_DiffServ_Value_2_ group="Ext_2/Network_Settings">0x68</SIP_TOS_DiffServ_Value_2_>
<SIP_CoS_Value_2_ group="Ext_2/Network_Settings">3</SIP_CoS_Value_2_>
<RTP_TOS_DiffServ_Value_2_ group="Ext_2/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_2_>
<RTP_CoS_Value_2_ group="Ext_2/Network_Settings">6</RTP_CoS_Value_2_>
<Network_Jitter_Level_2_ group="Ext_2/Network_Settings">high</Network_Jitter_Level_2_>
<Jitter_Buffer_Adjustment_2_ group="Ext_2/Network_Settings">up and down</Jitter_Buffer_Adjustment_2_>
<SIP_Transport_2_ group="Ext_2/SIP_Settings">UDP</SIP_Transport_2_>
<SIP_Port_2_ group="Ext_2/SIP_Settings">5061</SIP_Port_2_>
<SIP_100REL_Enable_2_ group="Ext_2/SIP_Settings">No</SIP_100REL_Enable_2_>
<EXT_SIP_Port_2_ group="Ext_2/SIP_Settings"/>
<Auth_Resync-Reboot_2_ group="Ext_2/SIP_Settings">Yes</Auth_Resync-Reboot_2_>
<SIP_Proxy-Require_2_ group="Ext_2/SIP_Settings"/>
<SIP_Remote-Party-ID_2_ group="Ext_2/SIP_Settings">No</SIP_Remote-Party-ID_2_>
<Referor_Bye_Delay_2_ group="Ext_2/SIP_Settings">4</Referor_Bye_Delay_2_>
<Refer-To_Target_Contact_2_ group="Ext_2/SIP_Settings">No</Refer-To_Target_Contact_2_>
<Referee_Bye_Delay_2_ group="Ext_2/SIP_Settings">0</Referee_Bye_Delay_2_>
<SIP_Debug_Option_2_ group="Ext_2/SIP_Settings">none</SIP_Debug_Option_2_>
<Refer_Target_Bye_Delay_2_ group="Ext_2/SIP_Settings">0</Refer_Target_Bye_Delay_2_>
<Sticky_183_2_ group="Ext_2/SIP_Settings">No</Sticky_183_2_>
<Auth_INVITE_2_ group="Ext_2/SIP_Settings">No</Auth_INVITE_2_>
<Ntfy_Refer_On_1xx-To-Inv_2_ group="Ext_2/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_2_>
<Use_Anonymous_With_RPID_2_ group="Ext_2/SIP_Settings">Yes</Use_Anonymous_With_RPID_2_>
<Set_G729_annexb_2_ group="Ext_2/SIP_Settings">none</Set_G729_annexb_2_>
<Voice_Quality_Report_Address_2_ group="Ext_2/SIP_Settings"/>
<Blind_Attn-Xfer_Enable_2_ group="Ext_2/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_2_>
<MOH_Server_2_ group="Ext_2/Call_Feature_Settings"/>
<Message_Waiting_2_ group="Ext_2/Call_Feature_Settings">No</Message_Waiting_2_>
<Auth_Page_2_ group="Ext_2/Call_Feature_Settings">No</Auth_Page_2_>
<Default_Ring__2__ group="Ext_2/Call_Feature_Settings">1</Default_Ring__2__>
<Auth_Page_Realm_2_ group="Ext_2/Call_Feature_Settings"/>
<Conference_Bridge_URL_2_ group="Ext_2/Call_Feature_Settings"/>
<Auth_Page_Password_2_ group="Ext_2/Call_Feature_Settings"/>
<Mailbox_ID_2_ group="Ext_2/Call_Feature_Settings"/>
<Voice_Mail_Server_2_ group="Ext_2/Call_Feature_Settings"/>
<Voice_Mail_Subscribe_Interval_2_ group="Ext_2/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_2_>
<State_Agent_2_ group="Ext_2/Call_Feature_Settings"/>
<CFWD_Notify_Serv_2_ group="Ext_2/Call_Feature_Settings">No</CFWD_Notify_Serv_2_>
<CFWD_Notifier_2_ group="Ext_2/Call_Feature_Settings"/>
<User_ID_with_Domain_2_ group="Ext_2/Call_Feature_Settings">No</User_ID_with_Domain_2_>
<Broadsoft_ACD_2_ group="Ext_2/Call_Feature_Settings">No</Broadsoft_ACD_2_>
<Auto_Ans_Page_On_Active_Call_2_ group="Ext_2/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_2_>
<Feature_Key_Sync_2_ group="Ext_2/Call_Feature_Settings">No</Feature_Key_Sync_2_>
<Proxy_2_ group="Ext_2/Proxy_and_Registration"/>
<Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration"/>
<Alternate_Proxy_2_ group="Ext_2/Proxy_and_Registration"/>
<Alternate_Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration"/>
<Use_Outbound_Proxy_2_ group="Ext_2/Proxy_and_Registration">No</Use_Outbound_Proxy_2_>
<Use_OB_Proxy_In_Dialog_2_ group="Ext_2/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_2_>
<Register_2_ group="Ext_2/Proxy_and_Registration">Yes</Register_2_>
<Make_Call_Without_Reg_2_ group="Ext_2/Proxy_and_Registration">No</Make_Call_Without_Reg_2_>
<Register_Expires_2_ group="Ext_2/Proxy_and_Registration">3600</Register_Expires_2_>
<Ans_Call_Without_Reg_2_ group="Ext_2/Proxy_and_Registration">No</Ans_Call_Without_Reg_2_>
<Use_DNS_SRV_2_ group="Ext_2/Proxy_and_Registration">No</Use_DNS_SRV_2_>
<DNS_SRV_Auto_Prefix_2_ group="Ext_2/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_2_>
<Proxy_Fallback_Intvl_2_ group="Ext_2/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_2_>
<Proxy_Redundancy_Method_2_ group="Ext_2/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_2_>
<Dual_Registration_2_ group="Ext_2/Proxy_and_Registration">No</Dual_Registration_2_>
<Display_Name_2_ group="Ext_2/Subscriber_Information"/>
<User_ID_2_ group="Ext_2/Subscriber_Information"/>
<Password_2_ group="Ext_2/Subscriber_Information"/>
<Use_Auth_ID_2_ group="Ext_2/Subscriber_Information">No</Use_Auth_ID_2_>
<Auth_ID_2_ group="Ext_2/Subscriber_Information"/>
<Reversed_Auth_Realm_2_ group="Ext_2/Subscriber_Information"/>
<Mini_Certificate_2_ group="Ext_2/Subscriber_Information"/>
<SRTP_Private_Key_2_ group="Ext_2/Subscriber_Information"/>
<Preferred_Codec_2_ group="Ext_2/Audio_Configuration">G711a</Preferred_Codec_2_>
<Use_Pref_Codec_Only_2_ group="Ext_2/Audio_Configuration">No</Use_Pref_Codec_Only_2_>
<Second_Preferred_Codec_2_ group="Ext_2/Audio_Configuration">Unspecified</Second_Preferred_Codec_2_>
<Third_Preferred_Codec_2_ group="Ext_2/Audio_Configuration">Unspecified</Third_Preferred_Codec_2_>
<G729a_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G729a_Enable_2_>
<G722_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G722_Enable_2_>
<G726-16_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-16_Enable_2_>
<G726-24_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-24_Enable_2_>
<G726-32_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-32_Enable_2_>
<G726-40_Enable_2_ group="Ext_2/Audio_Configuration">Yes</G726-40_Enable_2_>
<Release_Unused_Codec_2_ group="Ext_2/Audio_Configuration">Yes</Release_Unused_Codec_2_>
<DTMF_Process_AVT_2_ group="Ext_2/Audio_Configuration">Yes</DTMF_Process_AVT_2_>
<Silence_Supp_Enable_2_ group="Ext_2/Audio_Configuration">No</Silence_Supp_Enable_2_>
<DTMF_Tx_Method_2_ group="Ext_2/Audio_Configuration">Auto</DTMF_Tx_Method_2_>
<DTMF_Tx_Volume_for_AVT_Packet_2_ group="Ext_2/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_2_>
<Use_Remote_Pref_Codec_2_ group="Ext_2/Audio_Configuration">No</Use_Remote_Pref_Codec_2_>
<Codec_Negotiation_2_ group="Ext_2/Audio_Configuration">Default</Codec_Negotiation_2_>
<Dial_Plan_2_ group="Ext_2/Dial_Plan">(*x.|*2|xxx|xxxxx|xxxxxx|[2-8]xxxxxxxxS0|xx.|xx.*x.|09x.*|09x.**|**77|11*)</Dial_Plan_2_>
<Caller_ID_Map_2_ group="Ext_2/Dial_Plan"/>
<Enable_IP_Dialing_2_ group="Ext_2/Dial_Plan">Yes</Enable_IP_Dialing_2_>
<Emergency_Number_2_ group="Ext_2/Dial_Plan"/>
<Line_Enable_3_ group="Ext_3/General">Yes</Line_Enable_3_>
<Share_Ext_3_ group="Ext_3/Share_Line_Appearance">private</Share_Ext_3_>
<Shared_User_ID_3_ group="Ext_3/Share_Line_Appearance"/>
<Subscription_Expires_3_ group="Ext_3/Share_Line_Appearance">3600</Subscription_Expires_3_>
<Restrict_MWI_3_ group="Ext_3/Share_Line_Appearance">No</Restrict_MWI_3_>
<Monitor_User_ID_3_ group="Ext_3/Share_Line_Appearance"/>
<NAT_Mapping_Enable_3_ group="Ext_3/NAT_Settings">No</NAT_Mapping_Enable_3_>
<NAT_Keep_Alive_Enable_3_ group="Ext_3/NAT_Settings">No</NAT_Keep_Alive_Enable_3_>
<NAT_Keep_Alive_Msg_3_ group="Ext_3/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_3_>
<NAT_Keep_Alive_Dest_3_ group="Ext_3/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_3_>
<SIP_TOS_DiffServ_Value_3_ group="Ext_3/Network_Settings">0x68</SIP_TOS_DiffServ_Value_3_>
<SIP_CoS_Value_3_ group="Ext_3/Network_Settings">3</SIP_CoS_Value_3_>
<RTP_TOS_DiffServ_Value_3_ group="Ext_3/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_3_>
<RTP_CoS_Value_3_ group="Ext_3/Network_Settings">6</RTP_CoS_Value_3_>
<Network_Jitter_Level_3_ group="Ext_3/Network_Settings">high</Network_Jitter_Level_3_>
<Jitter_Buffer_Adjustment_3_ group="Ext_3/Network_Settings">up and down</Jitter_Buffer_Adjustment_3_>
<SIP_Transport_3_ group="Ext_3/SIP_Settings">UDP</SIP_Transport_3_>
<SIP_Port_3_ group="Ext_3/SIP_Settings">5062</SIP_Port_3_>
<SIP_100REL_Enable_3_ group="Ext_3/SIP_Settings">No</SIP_100REL_Enable_3_>
<EXT_SIP_Port_3_ group="Ext_3/SIP_Settings"/>
<Auth_Resync-Reboot_3_ group="Ext_3/SIP_Settings">Yes</Auth_Resync-Reboot_3_>
<SIP_Proxy-Require_3_ group="Ext_3/SIP_Settings"/>
<SIP_Remote-Party-ID_3_ group="Ext_3/SIP_Settings">No</SIP_Remote-Party-ID_3_>
<Referor_Bye_Delay_3_ group="Ext_3/SIP_Settings">4</Referor_Bye_Delay_3_>
<Refer-To_Target_Contact_3_ group="Ext_3/SIP_Settings">No</Refer-To_Target_Contact_3_>
<Referee_Bye_Delay_3_ group="Ext_3/SIP_Settings">0</Referee_Bye_Delay_3_>
<SIP_Debug_Option_3_ group="Ext_3/SIP_Settings">none</SIP_Debug_Option_3_>
<Refer_Target_Bye_Delay_3_ group="Ext_3/SIP_Settings">0</Refer_Target_Bye_Delay_3_>
<Sticky_183_3_ group="Ext_3/SIP_Settings">No</Sticky_183_3_>
<Auth_INVITE_3_ group="Ext_3/SIP_Settings">No</Auth_INVITE_3_>
<Ntfy_Refer_On_1xx-To-Inv_3_ group="Ext_3/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_3_>
<Use_Anonymous_With_RPID_3_ group="Ext_3/SIP_Settings">Yes</Use_Anonymous_With_RPID_3_>
<Set_G729_annexb_3_ group="Ext_3/SIP_Settings">none</Set_G729_annexb_3_>
<Voice_Quality_Report_Address_3_ group="Ext_3/SIP_Settings"/>
<Blind_Attn-Xfer_Enable_3_ group="Ext_3/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_3_>
<MOH_Server_3_ group="Ext_3/Call_Feature_Settings"/>
<Message_Waiting_3_ group="Ext_3/Call_Feature_Settings">No</Message_Waiting_3_>
<Auth_Page_3_ group="Ext_3/Call_Feature_Settings">No</Auth_Page_3_>
<Default_Ring__3__ group="Ext_3/Call_Feature_Settings">1</Default_Ring__3__>
<Auth_Page_Realm_3_ group="Ext_3/Call_Feature_Settings"/>
<Conference_Bridge_URL_3_ group="Ext_3/Call_Feature_Settings"/>
<Auth_Page_Password_3_ group="Ext_3/Call_Feature_Settings"/>
<Mailbox_ID_3_ group="Ext_3/Call_Feature_Settings"/>
<Voice_Mail_Server_3_ group="Ext_3/Call_Feature_Settings"/>
<Voice_Mail_Subscribe_Interval_3_ group="Ext_3/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_3_>
<State_Agent_3_ group="Ext_3/Call_Feature_Settings"/>
<CFWD_Notify_Serv_3_ group="Ext_3/Call_Feature_Settings">No</CFWD_Notify_Serv_3_>
<CFWD_Notifier_3_ group="Ext_3/Call_Feature_Settings"/>
<User_ID_with_Domain_3_ group="Ext_3/Call_Feature_Settings">No</User_ID_with_Domain_3_>
<Broadsoft_ACD_3_ group="Ext_3/Call_Feature_Settings">No</Broadsoft_ACD_3_>
<Auto_Ans_Page_On_Active_Call_3_ group="Ext_3/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_3_>
<Feature_Key_Sync_3_ group="Ext_3/Call_Feature_Settings">No</Feature_Key_Sync_3_>
<Proxy_3_ group="Ext_3/Proxy_and_Registration"/>
<Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration"/>
<Alternate_Proxy_3_ group="Ext_3/Proxy_and_Registration"/>
<Alternate_Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration"/>
<Use_Outbound_Proxy_3_ group="Ext_3/Proxy_and_Registration">No</Use_Outbound_Proxy_3_>
<Use_OB_Proxy_In_Dialog_3_ group="Ext_3/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_3_>
<Register_3_ group="Ext_3/Proxy_and_Registration">Yes</Register_3_>
<Make_Call_Without_Reg_3_ group="Ext_3/Proxy_and_Registration">No</Make_Call_Without_Reg_3_>
<Register_Expires_3_ group="Ext_3/Proxy_and_Registration">3600</Register_Expires_3_>
<Ans_Call_Without_Reg_3_ group="Ext_3/Proxy_and_Registration">No</Ans_Call_Without_Reg_3_>
<Use_DNS_SRV_3_ group="Ext_3/Proxy_and_Registration">No</Use_DNS_SRV_3_>
<DNS_SRV_Auto_Prefix_3_ group="Ext_3/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_3_>
<Proxy_Fallback_Intvl_3_ group="Ext_3/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_3_>
<Proxy_Redundancy_Method_3_ group="Ext_3/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_3_>
<Dual_Registration_3_ group="Ext_3/Proxy_and_Registration">No</Dual_Registration_3_>
<Display_Name_3_ group="Ext_3/Subscriber_Information"/>
<User_ID_3_ group="Ext_3/Subscriber_Information"/>
<Password_3_ group="Ext_3/Subscriber_Information"/>
<Use_Auth_ID_3_ group="Ext_3/Subscriber_Information">No</Use_Auth_ID_3_>
<Auth_ID_3_ group="Ext_3/Subscriber_Information"/>
<Reversed_Auth_Realm_3_ group="Ext_3/Subscriber_Information"/>
<Mini_Certificate_3_ group="Ext_3/Subscriber_Information"/>
<SRTP_Private_Key_3_ group="Ext_3/Subscriber_Information"/>
<Preferred_Codec_3_ group="Ext_3/Audio_Configuration">G711a</Preferred_Codec_3_>
<Use_Pref_Codec_Only_3_ group="Ext_3/Audio_Configuration">No</Use_Pref_Codec_Only_3_>
<Second_Preferred_Codec_3_ group="Ext_3/Audio_Configuration">Unspecified</Second_Preferred_Codec_3_>
<Third_Preferred_Codec_3_ group="Ext_3/Audio_Configuration">Unspecified</Third_Preferred_Codec_3_>
<G729a_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G729a_Enable_3_>
<G722_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G722_Enable_3_>
<G726-16_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-16_Enable_3_>
<G726-24_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-24_Enable_3_>
<G726-32_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-32_Enable_3_>
<G726-40_Enable_3_ group="Ext_3/Audio_Configuration">Yes</G726-40_Enable_3_>
<Release_Unused_Codec_3_ group="Ext_3/Audio_Configuration">Yes</Release_Unused_Codec_3_>
<DTMF_Process_AVT_3_ group="Ext_3/Audio_Configuration">Yes</DTMF_Process_AVT_3_>
<Silence_Supp_Enable_3_ group="Ext_3/Audio_Configuration">No</Silence_Supp_Enable_3_>
<DTMF_Tx_Method_3_ group="Ext_3/Audio_Configuration">Auto</DTMF_Tx_Method_3_>
<DTMF_Tx_Volume_for_AVT_Packet_3_ group="Ext_3/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_3_>
<Use_Remote_Pref_Codec_3_ group="Ext_3/Audio_Configuration">No</Use_Remote_Pref_Codec_3_>
<Codec_Negotiation_3_ group="Ext_3/Audio_Configuration">Default</Codec_Negotiation_3_>
<Dial_Plan_3_ group="Ext_3/Dial_Plan">(*x.|*2|xxx|xxxxx|xxxxxx|[2-8]xxxxxxxxS0|xx.|xx.*x.|09x.*|09x.**|**77|11*)</Dial_Plan_3_>
<Caller_ID_Map_3_ group="Ext_3/Dial_Plan"/>
<Enable_IP_Dialing_3_ group="Ext_3/Dial_Plan">Yes</Enable_IP_Dialing_3_>
<Emergency_Number_3_ group="Ext_3/Dial_Plan"/>
<Line_Enable_4_ group="Ext_4/General">Yes</Line_Enable_4_>
<Share_Ext_4_ group="Ext_4/Share_Line_Appearance">private</Share_Ext_4_>
<Shared_User_ID_4_ group="Ext_4/Share_Line_Appearance"/>
<Subscription_Expires_4_ group="Ext_4/Share_Line_Appearance">3600</Subscription_Expires_4_>
<Restrict_MWI_4_ group="Ext_4/Share_Line_Appearance">No</Restrict_MWI_4_>
<Monitor_User_ID_4_ group="Ext_4/Share_Line_Appearance"/>
<NAT_Mapping_Enable_4_ group="Ext_4/NAT_Settings">No</NAT_Mapping_Enable_4_>
<NAT_Keep_Alive_Enable_4_ group="Ext_4/NAT_Settings">No</NAT_Keep_Alive_Enable_4_>
<NAT_Keep_Alive_Msg_4_ group="Ext_4/NAT_Settings">$NOTIFY</NAT_Keep_Alive_Msg_4_>
<NAT_Keep_Alive_Dest_4_ group="Ext_4/NAT_Settings">$PROXY</NAT_Keep_Alive_Dest_4_>
<SIP_TOS_DiffServ_Value_4_ group="Ext_4/Network_Settings">0x68</SIP_TOS_DiffServ_Value_4_>
<SIP_CoS_Value_4_ group="Ext_4/Network_Settings">3</SIP_CoS_Value_4_>
<RTP_TOS_DiffServ_Value_4_ group="Ext_4/Network_Settings">0xb8</RTP_TOS_DiffServ_Value_4_>
<RTP_CoS_Value_4_ group="Ext_4/Network_Settings">6</RTP_CoS_Value_4_>
<Network_Jitter_Level_4_ group="Ext_4/Network_Settings">high</Network_Jitter_Level_4_>
<Jitter_Buffer_Adjustment_4_ group="Ext_4/Network_Settings">up and down</Jitter_Buffer_Adjustment_4_>
<SIP_Transport_4_ group="Ext_4/SIP_Settings">UDP</SIP_Transport_4_>
<SIP_Port_4_ group="Ext_4/SIP_Settings">5063</SIP_Port_4_>
<SIP_100REL_Enable_4_ group="Ext_4/SIP_Settings">No</SIP_100REL_Enable_4_>
<EXT_SIP_Port_4_ group="Ext_4/SIP_Settings"/>
<Auth_Resync-Reboot_4_ group="Ext_4/SIP_Settings">Yes</Auth_Resync-Reboot_4_>
<SIP_Proxy-Require_4_ group="Ext_4/SIP_Settings"/>
<SIP_Remote-Party-ID_4_ group="Ext_4/SIP_Settings">No</SIP_Remote-Party-ID_4_>
<Referor_Bye_Delay_4_ group="Ext_4/SIP_Settings">4</Referor_Bye_Delay_4_>
<Refer-To_Target_Contact_4_ group="Ext_4/SIP_Settings">No</Refer-To_Target_Contact_4_>
<Referee_Bye_Delay_4_ group="Ext_4/SIP_Settings">0</Referee_Bye_Delay_4_>
<SIP_Debug_Option_4_ group="Ext_4/SIP_Settings">none</SIP_Debug_Option_4_>
<Refer_Target_Bye_Delay_4_ group="Ext_4/SIP_Settings">0</Refer_Target_Bye_Delay_4_>
<Sticky_183_4_ group="Ext_4/SIP_Settings">No</Sticky_183_4_>
<Auth_INVITE_4_ group="Ext_4/SIP_Settings">No</Auth_INVITE_4_>
<Ntfy_Refer_On_1xx-To-Inv_4_ group="Ext_4/SIP_Settings">Yes</Ntfy_Refer_On_1xx-To-Inv_4_>
<Use_Anonymous_With_RPID_4_ group="Ext_4/SIP_Settings">Yes</Use_Anonymous_With_RPID_4_>
<Set_G729_annexb_4_ group="Ext_4/SIP_Settings">none</Set_G729_annexb_4_>
<Voice_Quality_Report_Address_4_ group="Ext_4/SIP_Settings"/>
<Blind_Attn-Xfer_Enable_4_ group="Ext_4/Call_Feature_Settings">No</Blind_Attn-Xfer_Enable_4_>
<MOH_Server_4_ group="Ext_4/Call_Feature_Settings"/>
<Message_Waiting_4_ group="Ext_4/Call_Feature_Settings">No</Message_Waiting_4_>
<Auth_Page_4_ group="Ext_4/Call_Feature_Settings">No</Auth_Page_4_>
<Default_Ring__4__ group="Ext_4/Call_Feature_Settings">1</Default_Ring__4__>
<Auth_Page_Realm_4_ group="Ext_4/Call_Feature_Settings"/>
<Conference_Bridge_URL_4_ group="Ext_4/Call_Feature_Settings"/>
<Auth_Page_Password_4_ group="Ext_4/Call_Feature_Settings"/>
<Mailbox_ID_4_ group="Ext_4/Call_Feature_Settings"/>
<Voice_Mail_Server_4_ group="Ext_4/Call_Feature_Settings"/>
<Voice_Mail_Subscribe_Interval_4_ group="Ext_4/Call_Feature_Settings">86400</Voice_Mail_Subscribe_Interval_4_>
<State_Agent_4_ group="Ext_4/Call_Feature_Settings"/>
<CFWD_Notify_Serv_4_ group="Ext_4/Call_Feature_Settings">No</CFWD_Notify_Serv_4_>
<CFWD_Notifier_4_ group="Ext_4/Call_Feature_Settings"/>
<User_ID_with_Domain_4_ group="Ext_4/Call_Feature_Settings">No</User_ID_with_Domain_4_>
<Broadsoft_ACD_4_ group="Ext_4/Call_Feature_Settings">No</Broadsoft_ACD_4_>
<Auto_Ans_Page_On_Active_Call_4_ group="Ext_4/Call_Feature_Settings">Yes</Auto_Ans_Page_On_Active_Call_4_>
<Feature_Key_Sync_4_ group="Ext_4/Call_Feature_Settings">No</Feature_Key_Sync_4_>
<Proxy_4_ group="Ext_4/Proxy_and_Registration"/>
<Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration"/>
<Alternate_Proxy_4_ group="Ext_4/Proxy_and_Registration"/>
<Alternate_Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration"/>
<Use_Outbound_Proxy_4_ group="Ext_4/Proxy_and_Registration">No</Use_Outbound_Proxy_4_>
<Use_OB_Proxy_In_Dialog_4_ group="Ext_4/Proxy_and_Registration">Yes</Use_OB_Proxy_In_Dialog_4_>
<Register_4_ group="Ext_4/Proxy_and_Registration">Yes</Register_4_>
<Make_Call_Without_Reg_4_ group="Ext_4/Proxy_and_Registration">No</Make_Call_Without_Reg_4_>
<Register_Expires_4_ group="Ext_4/Proxy_and_Registration">3600</Register_Expires_4_>
<Ans_Call_Without_Reg_4_ group="Ext_4/Proxy_and_Registration">No</Ans_Call_Without_Reg_4_>
<Use_DNS_SRV_4_ group="Ext_4/Proxy_and_Registration">No</Use_DNS_SRV_4_>
<DNS_SRV_Auto_Prefix_4_ group="Ext_4/Proxy_and_Registration">No</DNS_SRV_Auto_Prefix_4_>
<Proxy_Fallback_Intvl_4_ group="Ext_4/Proxy_and_Registration">3600</Proxy_Fallback_Intvl_4_>
<Proxy_Redundancy_Method_4_ group="Ext_4/Proxy_and_Registration">Normal</Proxy_Redundancy_Method_4_>
<Dual_Registration_4_ group="Ext_4/Proxy_and_Registration">No</Dual_Registration_4_>
<Display_Name_4_ group="Ext_4/Subscriber_Information"/>
<User_ID_4_ group="Ext_4/Subscriber_Information"/>
<Password_4_ group="Ext_4/Subscriber_Information"/>
<Use_Auth_ID_4_ group="Ext_4/Subscriber_Information">No</Use_Auth_ID_4_>
<Auth_ID_4_ group="Ext_4/Subscriber_Information"/>
<Reversed_Auth_Realm_4_ group="Ext_4/Subscriber_Information"/>
<Mini_Certificate_4_ group="Ext_4/Subscriber_Information"/>
<SRTP_Private_Key_4_ group="Ext_4/Subscriber_Information"/>
<Preferred_Codec_4_ group="Ext_4/Audio_Configuration">G711a</Preferred_Codec_4_>
<Use_Pref_Codec_Only_4_ group="Ext_4/Audio_Configuration">No</Use_Pref_Codec_Only_4_>
<Second_Preferred_Codec_4_ group="Ext_4/Audio_Configuration">Unspecified</Second_Preferred_Codec_4_>
<Third_Preferred_Codec_4_ group="Ext_4/Audio_Configuration">Unspecified</Third_Preferred_Codec_4_>
<G729a_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G729a_Enable_4_>
<G722_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G722_Enable_4_>
<G726-16_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-16_Enable_4_>
<G726-24_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-24_Enable_4_>
<G726-32_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-32_Enable_4_>
<G726-40_Enable_4_ group="Ext_4/Audio_Configuration">Yes</G726-40_Enable_4_>
<Release_Unused_Codec_4_ group="Ext_4/Audio_Configuration">Yes</Release_Unused_Codec_4_>
<DTMF_Process_AVT_4_ group="Ext_4/Audio_Configuration">Yes</DTMF_Process_AVT_4_>
<Silence_Supp_Enable_4_ group="Ext_4/Audio_Configuration">No</Silence_Supp_Enable_4_>
<DTMF_Tx_Method_4_ group="Ext_4/Audio_Configuration">Auto</DTMF_Tx_Method_4_>
<DTMF_Tx_Volume_for_AVT_Packet_4_ group="Ext_4/Audio_Configuration">0</DTMF_Tx_Volume_for_AVT_Packet_4_>
<Use_Remote_Pref_Codec_4_ group="Ext_4/Audio_Configuration">No</Use_Remote_Pref_Codec_4_>
<Codec_Negotiation_4_ group="Ext_4/Audio_Configuration">Default</Codec_Negotiation_4_>
<Dial_Plan_4_ group="Ext_4/Dial_Plan">(*x.|*2|xxx|xxxxx|xxxxxx|[2-8]xxxxxxxxS0|xx.|xx.*x.|09x.*|09x.**|**77|11*)</Dial_Plan_4_>
<Caller_ID_Map_4_ group="Ext_4/Dial_Plan"/>
<Enable_IP_Dialing_4_ group="Ext_4/Dial_Plan">Yes</Enable_IP_Dialing_4_>
<Emergency_Number_4_ group="Ext_4/Dial_Plan"/>
<Cfwd_All_Dest group="User/Call_Forward"/>
<Cfwd_Busy_Dest group="User/Call_Forward"/>
<Cfwd_No_Ans_Dest group="User/Call_Forward"/>
<Cfwd_No_Ans_Delay group="User/Call_Forward">20</Cfwd_No_Ans_Delay>
<Speed_Dial_2 group="User/Speed_Dial"/>
<Speed_Dial_3 group="User/Speed_Dial"/>
<Speed_Dial_4 group="User/Speed_Dial"/>
<Speed_Dial_5 group="User/Speed_Dial"/>
<Speed_Dial_6 group="User/Speed_Dial"/>
<Speed_Dial_7 group="User/Speed_Dial"/>
<Speed_Dial_8 group="User/Speed_Dial"/>
<Speed_Dial_9 group="User/Speed_Dial"/>
<CW_Setting group="User/Supplementary_Services">No</CW_Setting>
<Block_CID_Setting group="User/Supplementary_Services">No</Block_CID_Setting>
<Block_ANC_Setting group="User/Supplementary_Services">No</Block_ANC_Setting>
<DND_Setting group="User/Supplementary_Services">No</DND_Setting>
<Secure_Call_Setting group="User/Supplementary_Services">No</Secure_Call_Setting>
<Dial_Assistance group="User/Supplementary_Services">No</Dial_Assistance>
<Auto_Answer_Page group="User/Supplementary_Services">Yes</Auto_Answer_Page>
<Preferred_Audio_Device group="User/Supplementary_Services">Speaker</Preferred_Audio_Device>
<Send_Audio_To_Speaker group="User/Supplementary_Services">No</Send_Audio_To_Speaker>
<Time_Format group="User/Supplementary_Services">24hr</Time_Format>
<Date_Format group="User/Supplementary_Services">day/month</Date_Format>
<Miss_Call_Shortcut group="User/Supplementary_Services">Yes</Miss_Call_Shortcut>
<Miss_Call_Banner group="User/Supplementary_Services">Yes</Miss_Call_Banner>
<Accept_Media_Loopback_Request group="User/Supplementary_Services">automatic</Accept_Media_Loopback_Request>
<Media_Loopback_Mode group="User/Supplementary_Services">source</Media_Loopback_Mode>
<Media_Loopback_Type group="User/Supplementary_Services">media</Media_Loopback_Type>
<Text_Message group="User/Supplementary_Services">Yes</Text_Message>
<Text_Message_From_3rd_Party group="User/Supplementary_Services">No</Text_Message_From_3rd_Party>
<Alert_Tone_Off group="User/Supplementary_Services">No</Alert_Tone_Off>
<Log_Missed_Calls_for_EXT_1 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_1>
<Log_Missed_Calls_for_EXT_2 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_2>
<Log_Missed_Calls_for_EXT_3 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_3>
<Log_Missed_Calls_for_EXT_4 group="User/Supplementary_Services">Yes</Log_Missed_Calls_for_EXT_4>
<Ringer_Volume group="User/Audio_Volume">8</Ringer_Volume>
<Speaker_Volume group="User/Audio_Volume">8</Speaker_Volume>
<Handset_Volume group="User/Audio_Volume">10</Handset_Volume>
<Headset_Volume group="User/Audio_Volume">10</Headset_Volume>
<Handset_Version group="User/Audio_Volume">Auto</Handset_Version>
<Deep_Bass group="User/Audio_Volume">Default</Deep_Bass>
<LCD_Contrast group="User/LCD">8</LCD_Contrast>
<Back_Light_Timer group="User/LCD">10 s</Back_Light_Timer>
<Subscribe_Expires group="Attendant_Console/General">1800</Subscribe_Expires>
<Subscribe_Retry_Interval group="Attendant_Console/General">30</Subscribe_Retry_Interval>
<Unit_1_Enable group="Attendant_Console/General">No</Unit_1_Enable>
<Subscribe_Delay group="Attendant_Console/General">1</Subscribe_Delay>
<Unit_2_Enable group="Attendant_Console/General">No</Unit_2_Enable>
<Server_Type group="Attendant_Console/General">Asterisk</Server_Type>
<Test_Mode_Enable group="Attendant_Console/General">No</Test_Mode_Enable>
<Attendant_Console_Call_Pickup_Code group="Attendant_Console/General">*8</Attendant_Console_Call_Pickup_Code>
<BLF_List_URI group="Attendant_Console/General"/>
<Call_Pickup_Audio_Notification group="Attendant_Console/General">No</Call_Pickup_Audio_Notification>
<Application_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Serv_Subscribe_Failed_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Serv_Subscribing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<SNRM_Day_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<SNRM_Night_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Parking_Lot_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Parking_Lot_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Ringing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Held_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Unit_1_Key_1 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_2 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_3 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_4 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_5 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_6 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_7 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_8 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_9 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_10 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_11 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_12 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_13 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_14 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_15 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_16 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_17 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_18 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_19 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_20 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_21 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_22 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_23 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_24 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_25 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_26 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_27 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_28 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_29 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_30 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_31 group="Attendant_Console/Unit_1"/>
<Unit_1_Key_32 group="Attendant_Console/Unit_1"/>
<Unit_2_Key_1 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_2 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_3 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_4 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_5 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_6 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_7 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_8 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_9 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_10 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_11 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_12 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_13 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_14 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_15 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_16 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_17 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_18 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_19 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_20 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_21 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_22 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_23 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_24 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_25 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_26 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_27 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_28 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_29 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_30 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_31 group="Attendant_Console/Unit_2"/>
<Unit_2_Key_32 group="Attendant_Console/Unit_2"/>
</flat-profile>
paolo bevilacqua
Try Small Business forum.
This one is for true cisco products.
Thank you,
I have open the thread at
https://supportforums.cisco.com/thread/2112414?tstart=0
