04-17-2012 04:24 AM - edited 03-21-2019 05:40 AM
I have a tricky issue where outside caller calls in and when the call is forwareded to voicemail because of CFNA, the FXO do not disconnect. I have a setup where a Etisalat Analog lines are directly connected to UC560 FXO ports using RJ11.
When a call comes in over the PSTN to an FXO port on my UC560 and the call is answered by the user and after that user goes on-hook, FXO disconnects or gets released normally . When the user does not answer the call and becuse of CFNA timeout the call is forwarded to users voicemail box , then CUE answers, a voicemail is recorded, but when the calling party hangs up FXO doesnot disconnect instead it stays in OFFHOOK state (HANGS). Because of this no more calls are possible on that FXO line. I have to issue shut and no shut command on the FXO to get it released.
The IOS version as follows
uc500-advipservicesk9-mz.151-2.T4
and CME and CUE version are as follows 8.0.2
The follwing is the configuration on my UC560
voice class dualtone-detect-params 1
freq-max-deviation 25
freq-max-power 0
freq-min-power 13
freq-power-twist 4
cadence-variation 4
voice class custom-cptone UAE-CUSTOM-SIEMENS
dualtone disconnect
frequency 425
cadence 425 325 250 500
voice-port 0/1/0
trunk-group ALL_FXO 61
translation-profile incoming INCOMING_CallerID_PROFILE
supervisory disconnect dualtone mid-call
supervisory custom-cptone UAE-CUSTOM-SIEMENS
supervisory dualtone-detect-params 1
no battery-reversal
input gain 14
cptone AE
timeouts call-disconnect 2
timeouts wait-release 2
timing min-ring 62
connection plar opx 202
description Configured by CCA 4 FXO-0/1/0-Custom-BG
caller-id enable
This the dial peer for viocemail
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
Solved! Go to Solution.
04-19-2012 01:01 AM
Hi Abdul,
Can you please do a "debug vpm signal" once you have finished apply the
recommendations from the other guys, I want to see what takes place on a
hung call when the "A" end circuit closes.
On Apr 18, 2012 7:03 PM, "abdulbari_cisco" <
04-19-2012 04:12 AM
HI David,
Here is the debug vpm signal information that i have taken for two scenarios
the configuration on voice-port is as follows
dualtone disconnect
frequency 425
cadence 400 350 225 525
voice-port 0/1/1
input gain 14
cptone AE
description Configured by CCA 4 FXO-0/1/1-Custom-OP
caller-id enable
the came same configuration above with battery reversal answer but no use sitll same issue.
The other tricky thing that is happening is when the call is forwarded to voicemail of the user and after the external caller disconnects the FXO on UC540 does not disconnect immediately, instead it disconnects after the default messgae size is reached. ie the default message size of voicemail box is 240 sec so after 240 sec the FXO port is released or disconnects and a large amount of silence is being recorded in the users mailbox for about 240 seconds.
the following is the debug capture taken
When the call comes in and call is forwarded to voicemail because of CFNA on the user phone
UC_540#
000691: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
000692: htsp_timer - 125 msec
000693: htsp_process_event: [0/1/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
000694: htsp_timer - 10000 msec
000695: htsp_timer3 - 5600 msec
000696: [0/1/1] htsp_start_caller_id_rx:BELLCORE
000697: htsp_start_caller_id_rx create dsp_stream_manager
000698: [0/1/1] htsp_dsm_create_success returns 1
UC_540#
000699: htsp_process_event: [0/1/1, FXOLS_RINGING, E_DSP_SIG_0100]
000700: fxols_ringing_not
000701: htsp_timer_stop
000702: htsp_timer - 10000 msec
000703: [0/1/1] htsp_dsm_feature_notify_cb returns 2 id=DSM_FEATURE_SM_CALLERID_RX
000704: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
000705: htsp_timer_stop
000706: htsp_timer_stop3
000707: [0/1/1] htsp_stop_caller_id_rx. message length 25htsp_setup_ind
000708: [0/1/1] get_fxo_caller_id:Caller ID received. Message type=128 length=25 checksum=B1
000709: [0/1/1] Caller ID String 80 16 01 08 30 34 31 39 31 33 34 30 02 0A 30 35 30 39 35 37 38 33 30 39 B1
000710: [0/1/1] get_fxo_caller_id calling num=0509856909 calling name= calling time=04/19 13:40
000711: fxols_callerid_done: call being answered
000712: [0/1/1] htsp_dsm_close_done
000713: htsp_process_event: [0/1/1, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
000714: fxols_wait_setup_ack:
000715: htsp_timer - 6000 msec
000716: htsp_timer_stop
UC_540#3
000717: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_prochtsp_setup_req
000718: htsp_process_event: [50/0/30.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
000719: htsp_ephone_start_caller_id_tx calling num=90509578309 calling name = called num=201 orig called num=
000720: [50/0/30.1] set signal state = 0x0 timestamp = 0
000721: efxs_onhook_setup: local target is available
htsp_alerthtsp_alert_notify
000722: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
UC_540#
000723: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000724: htsp_timer_stop
000725: htsp_timer_stop2
UC_540#
000726: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000727: htsp_timer_stop2
000728: htsp_timer - 6000 msec
UC_540#
000729: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000730: htsp_timer_stop
000731: htsp_timer_stop2
UC_540#
000732: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000733: htsp_timer_stop2
000734: htsp_timer - 6000 msec
UC_540#
000735: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000736: htsp_timer_stop
000737: htsp_timer_stop2
UC_540#
000738: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000739: htsp_timer_stop2
000740: htsp_timer - 6000 msec
UC_540#
000741: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
000742: htsp_timer_stop
000743: htsp_timer_stop2
UC_540#
000744: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
000745: htsp_timer_stop2
000746: htsp_timer - 6000 msec
UC_540#
000747: htsp_timer_stop3
000748: htsp_process_event: [50/0/30.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
000749: [50/0/30.1] set signal state = 0x4 timestamp = 0
000750: htsp_call_bridged invoked
000751: htsp_process_event: [0/1/1, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
000752: [0/1/1] set signal state = 0xC timestamp = 0
000753: htsp_timer_stop
000754: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
000755: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
000756: htsp_timer_stop2
000757: htsp_timer_stop2
UC_540#
After the voicemail box, default message size is reached ie after 240 seconds the FXO port disconnects and following is the continuation of debug vpm signal cmd.
UC_540#
000758: htsp_timer_stop3 htsp_setup_req
000759: htsp_process_event: [50/0/300.1, EFXS_ONHOOK, E_HTSP_SETUP_REQ]efxs_onhook_setup
000760: htsp_ephone_start_caller_id_tx calling num=399 calling name = called num=A800201 orig called num=
000761: [50/0/300.1] set signal state = 0x0 timestamp = 0
000762: efxs_onhook_setup: local target is available
htsp_alerthtsp_call_feature:feature 25
htsp_call_feature: caller id enable 0x3 call_connected 0
000763: htsp_process_event: [50/0/300.1, EFXS_WAIT_OFFHOOK, E_HTSP_CALLERID_WAITING]
000764: efxs_callerid_update
000765: efxs_callerid_update process caller_id_string
000766: efxs_callerid_update process caller_id_string OK
UC_540#
000767: efxs_callerid_update number= [399] name= []
UC_540#
000768: htsp_timer_stop3
000769: htsp_process_event: [0/1/1, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
000770: htsp_timer_stop
000771: htsp_timer_stop2
000772: htsp_timer_stop3
000773: [0/1/1] set signal state = 0x4 timestamp = 0
000774: htsp_timer - 2000 msec
000775: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
UC_540#
000776: htsp_process_event: [0/1/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
000777: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
000778: htsp_timer_stop3
000779: htsp_process_event: [50/0/300.1, EFXS_WAIT_OFFHOOK, E_HTSP_RELEASE_REQ]efxs_waitoff_release
000780: [50/0/300.1] set signal state = 0x4 timestamp = 0
UC_540#
Can any one let me know what is happing here. when the call is forwarded to voicemail of the user, why FXO Port on UC540 not getting disconnected soon after the external caller disconnects the call.and insted it disconnects approximately after 240 seconds of call forwarded to voicemail.
I tried the same cofiguration as above with battery reversal answer in voice-port configuration but no use sitll same issue.
04-19-2012 04:21 AM
Hi Abdul,
Let me look at various configurations I have saved and see if I can find
one for your region, no promises as I don't normally keep configurations of
systems I don't manage.
I will update you again tomorrow.
On Apr 19, 2012 9:13 PM, "abdulbari_cisco" <
04-19-2012 04:59 AM
HI David,
Did you check the debug messages i have posted. what do you thing might be problem here with CUE.
04-20-2012 10:51 PM
HI David,
Have you seen the debug captures that i have posted. Could you please help me out what we have to look at in these debug message to fix this issue.Or any conclusion we can derive from these debug messages of VPM signal.
Thanks David
04-21-2012 12:20 AM
Hi Abdul,
My previous post asked if you would be willing to post your configuration
up, if you are please do it as a text file and make sure you remove
sensitive information like user name and passwords.
I do not believe thus is a FXO configuration issue, it has something to do
with the session to the CUE so I need to see your configuration to
determine if it is
On Apr 21, 2012 3:52 PM, "abdulbari_cisco" <
09-26-2012 05:52 AM
I have the same problem.
09-26-2012 06:56 AM
This is often asked.
You need to configure the exact disconnect tones, otherwise the router will never know that the outside caller has hung-up.
09-26-2012 07:32 AM
Hello Paolo,
I want to explane better ma issue:
I have a simple configuration with a provide (telecom italia) direct connect to FXO. I noticed that when i choose to redirecting incomming call to a Iphone, and I bring down the call (for example from my cel phone), evrything works fine.
Instead when I redirect a incomming call to the Cue (for a AVR simple menu) and this works redirecting call to iphone, and from my cel bring down the call, the iphone still ring and after the No aswer timeout the call was passed again to cue for voicemail.
This is my configuration of FXO
voice class custom-cptone IT-CUSTOM
dualtone disconnect
frequency 425
voice-port 0/1/0
trunk-group ALL_FXO 64
supervisory custom-cptone IT-CUSTOM
input gain 14
cptone IT
connection plar opx 396
impedance complex2
caller-id enable
09-26-2012 08:00 AM
Disconnect for italy should be
frequency 425
cadence 200 200
If you want everything work 10 times better, use ISDN BRI not FXO.
11-26-2013 07:50 AM
Hi guys,
abdulbari_cisco, did you resolve your issue? I have the same disconnect problem with a router 2951 with FXO and CUE 8.6.
Thanks a best regards.
David
09-26-2012 10:32 AM
Thanks for replay Paolo, and for paramiters but still not working.
I noticed that isdn is better but in this case the only solutions is fxo. Another old pbx (not cisco) work without problems!
09-26-2012 09:59 PM
I used the configuration above with TI and it was ok.
You may want to update UC500 software, and check the disconnect tones again.
09-27-2012 12:29 AM
I have the last version, 8.6. I noticed this problem happens when CUE is involved in to the call. Is maybe a autoattendant script problem ?
09-27-2012 02:55 AM
I don't think so, the router is supposed to recognize disconnect tones either the call is in CUE AA, or to an IP phone.
Anyway a good CUE AA script is supposed to close the call if no caller input after a while.
