Calls randomly dropped with BYE on SPA525G2 + 500S phones running 7.5.4. Please help!
envisionitllc
Hello everyone,
We're running 3CX v.11 SP4 with multiple admins answering the incoming calls on SPA525G2 phones with the 500S console. We're using a Grandstream GXW4108 gateway running the latest firmware connected to 7 PSTN lines. Several times a day, admins will take a call, put the call in one of the park slots using a programmed 500S button, and the call will be disconnected in less the 30 seconds before the intended recipient is able to pickup the parked call. The callers call back thinking they've been hung up on. It happens on all phones randomly.
Has anyone ever seen or experienced this? The client is becoming increasingly frustrated and therefore so am I. I'm working with 3CX engineers currently, but also wanted to know if anyone else has experienced?
Any insight or help would be greatly appreciated. If there's more info you need from me, please just let me know.
Thanks very much,
Nathan
Envision IT, LLC
There's a NOTIFY that comes to the phone with the same Call ID as the BYE.    It says content type as message but with Event : refer.
When the phone sends the BYE during the other call drops, do you see this NOTIFY as well?
6 Replies 6
nseto
Level 6
Level 6
Can you get a debug log of the call?
https://supportforums.cisco.com/docs/DOC-9862
Need to see if there's a BYE being sent in the SIP transaction between the phone and the proxy.
nseto,
Thank you so much for the response, and I'm sorry for the delay in answering. I have all the options for debug set on the receptionist SPA525G2 with a 500S attendant console. I'll post the contents of a disconnected hold / parked call as soon as we have another confirmed.
Thanks again,
Nathan
Envision IT, LLC
envisionitllc
Nseto,
Here's a log of an incoming call that was parked and subsequently disconnected before anyone had the chance to pick it up. Let me know if you need more of the debug log. Thanks!
[0:5060]<<192.168.1.50:5060
NOTIFY sip:10@192.168.1.202:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.50:5060;branch=z9hG4bK-d8754z-785c3a5f4303d010-1---d8754z-;rport
Max-Forwards: 70
Contact:
To: "Reception"<10>;tag=5f2b4817689ab5d
Call-ID: 351b7651-2a7b53cd@192.168.1.202
CSeq: 34 NOTIFY
Content-Type: application/dialog-info+xml
User-Agent: 3CXPhoneSystem 11.0.28976.849 (28862)
Subscription-State: active;expires=52
Event: dialog
Content-Length: 557
confirmed
sip:SP1@192.168.1.50:5060sip:XXXXXXXXXX@192.168.1.50:5060
OP ext'd 15 3185
OP ext'd 15 3186
OP ext'd 15 3187
OP ext'd 15 3188
OP ext'd 15 3189
OP ext'd 15 3190
OP ext'd 15 3191
OP ext'd 15 3192
OP ext'd 15 3193
OP ext'd 7 598
OP ext'd 1 2147
[0:5060]->192.168.1.50:5060{314)
SIP/2.0 200 OK
CSeq: 34 NOTIFY
Server: Cisco/SPA525G2-7.5.4
Content-Length: 0
Via: SIP/2.0/UDP 192.168.1.50:5060;branch=z9hG4bK-d8754z-f4027a2b84431f5c-1---d8754z-;rport
Max-Forwards: 70
Contact:
To: <10>;tag=9b31f622aadd83f9i0
Call-ID: YzIxNDhhNGNhNjUxYjY0MmRjNjg0ZTgwNjVkNDQyNzc.
CSeq: 3 NOTIFY
Content-Type: message/sipfrag
Subscription-State: terminated;reason=noResource
Event: refer
Content-Length: 18
SIP/2.0 200 OK
[0]CC:NewCallState 0/13
PHN_setAudioPath(0)
[0:0]AUD Rel Call
OP ext'd 7 599
OP ext'd 1 2148
[0:5060]->192.168.1.50:5060{352)
SIP/2.0 200 OK
CSeq: 3 NOTIFY
Content-Length: 0
OP ext'd 6 491
OP ext'd 1 2149
OP ext'd 1 2150
[0:5060]->192.168.1.50:5060{373)
BYE sip:XXXXXXXXXX@192.168.1.50:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.202:5060;branch=z9hG4bK-8a711173
To: "INCOMING CALLER ID NAME" ;tag=326bea6d
CSeq: 102 BYE
Max-Forwards: 70
User-Agent: Cisco/SPA525G2-7.5.4
Content-Length: 0
SIP/2.0 200 OK
Contact:
To: "INCOMING CALLER ID NAME";tag=326bea6d
CSeq: 102 BYE
Content-Length: 0
OP ext'd 1 2151
Via: SIP/2.0/UDP 192.168.1.50:5060;branch=z9hG4bK-d8754z-84660b7b2b76ac20-1---d8754z-;rport
Max-Forwards: 70
Contact: <10>
To: "Reception"<10>;tag=cd465f3cc09207dd
Call-ID: 56ba4de8-c490921@192.168.1.202
CSeq: 55 NOTIFY
Event: dialog
Content-Length: 566
terminated
sip:XXXXXXXXXX@192.168.1.50sip:10@192.168.1.50
The issue has seemingly worsened, and it does appear the SPA525G2 + 500S phones are saying BYE to active calls. Now the issue is occuring when users making outgoing calls and when incoming calls are even muted. Is there anyone who's seen this behavior on these SPA phones? Or tell me where I should look next?
Thanks very much,
Nathan
Envision IT, LLC
nseto,
You were exactly on the right track. The Grandstream PSTN gateway had a silence timeout on phone calls set to 60 seconds. Incoming calls on hold or parked (no hold music) were being disconnected by the gateway causing the phones to lose the call. Outgoing calls were being disconnected when people were on silent hold for people they dialed. I very much appreciate your helping point me the right way in approaching this issue.
Nathan
Envision IT, LLC
