12-12-2013 09:19 AM - edited 03-21-2019 07:58 AM
Hey all. I'm working on a UC560 I installed a couple of weeks ago at a client and while out today to do some user training and final configuration I've run into some issues with contacting the CUE module via telephone. I can get to the CUE GUI and I can connect to the console of the CUE via CLI. I've done basic network connectivity tests in addition to this (ping, telnet, etc) and that side seems fine.
The issue is when I call in to the voicemail pilot. All calls to anything on the CUE (VM, AAs, prompt management) give a fast busy and displays the below debugs (using debug ccsip calls). I have attached the CME running config as well as the output from a debug voip ccapi.
I can attach the config of the CUE module if necessary. Any help you can provide will be greatly appreciated!
000813: Dec 12 17:10:42.111: //85/28BF96608139/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x893F1A60
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number : 410
Called Number : 600
Source IP Address (Sig ): 10.1.10.2
Destn SIP Req Addr:Port : 10.1.10.1:5060
Destn SIP Resp Addr:Port : 10.1.10.1:5060
Destination Name : 10.1.10.1
000814: Dec 12 17:10:42.111: //85/28BF96608139/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : No Codec
Negotiated Codec Bytes : 0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 10.1.10.2
Source IP Port (Media): 17242
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
000815: Dec 12 17:10:42.111: //85/28BF96608139/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 38
Disconnect Cause (SIP) : 503
12-12-2013 10:33 AM
Addtional debugs from "debug ip tcp transaction" available below. This is what I get when calling to 600, the voicemail pilot
002404: Dec 12 18:29:44.011: TCB8BA912C8 created
002405: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP_NO_DELAY (0) 890C8BB4
002406: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP_NONBLOCKING_WRITE (10) 890C8BB0
002407: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP_NONBLOCKING_READ (14) 890C8BB0
002408: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP_NO_DELAY (0) 890C8BB0
002409: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP keepalive timeout (17) 890C8BB0
002410: Dec 12 18:29:44.011: TCB8BA912C8 setting property TCP_ALWAYSPUSH (15) 890C8BB0
002411: Dec 12 18:29:44.011: TCP: Random local port generated 50671, network 1
002412: Dec 12 18:29:44.011: TCB8BA912C8 bound to UNKNOWN.50671
002413: Dec 12 18:29:44.011: Reserved port 50671 in Transport Port Agent for TCP IP type 1
002414: Dec 12 18:29:44.011: TCP: sending SYN, seq 86458800, ack 0
002415: Dec 12 18:29:44.011: TCP0: Connection to 10.1.10.1:5060, advertising MSS 1460
002416: Dec 12 18:29:44.011: TCP0: state was CLOSED -> SYNSENT [50671 -> 10.1.10.1(5060)]
002417: Dec 12 18:29:44.015: Released port 50671 in Transport Port Agent for TCP IP type 1 delay 240000
002418: Dec 12 18:29:44.015: TCP0: state was SYNSENT -> CLOSED [50671 -> 10.1.10.1(5060)]
002419: Dec 12 18:29:44.015: TCP0: bad seg from 10.1.10.1 -- closing connection: port 50671 seq 0 ack 86458801 rcvnxt 0 rcvwnd 0 len 0
002420: Dec 12 18:29:44.015: TCP0: connection closed - remote sent RST
002421: Dec 12 18:29:44.015: TCB 0x8BA912C8 destroyed
12-12-2013 01:14 PM
Hello c.holloway,
If you are not able to reach CUE though the CLI you may try to reset it using:
ser in 0/0 reset
If this is not working and you cannot connect to the CUE cli it is good idea to open a case with SBSC.
HTH,
Alex
*Please rate helpful posts
