Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
1926
Can Call Volume be adjusted for incoming FXO lines?
First, thank you for reading this.
We have a UC540 in a small retail environment.  SPA508G, SPA501G, and 7925 wireless phones are being used.
The incoming voice is over 4 AT&T POTS lines to the FXO ports.  AT&T "rolls over" the lines for multiple calls at a time.
The customer complains that they can not hear the callers and must turn the SPA's volume up.
The problem now becomes that the "comfort noise" on the lines also increases and they hear "humming".
We have tested the POTS lines with an analog phone and call quality is good.  Also, AT&T has checked the lines for "crossing" etc... to the dmarc.
Is there a way in the UC540 to increase the voice traffic volume coming in the FXO so the users do not have to raise the handset volume as much?
Thank you, Paul
P.S. config info can be provided if needed.
1 ACCEPTED SOLUTION
Adjust the gain, reduce attentuation.
Click on the help for that window.
Sorry I wasnt so clear :-)
Steve
4 REPLIES 4
Steven, thank you, but the setting are the same as on "Page 55".
What adjustments can be made here?
Steve
Thanks Steven.  I will let you know how it goes.  Paul
