Can't call Analog Sets
chris parkinson
All,
     I have configured the UC540 FXS with 2 user and 2 fax type extensions.
All the FXS ports can call the IP Sets.
However whenever an IP Set or Analog set tries to call an Analog set I just get a busy tone.
Nothing can call my analog sets.
I'm guessing I'm missing something in the config.
I'd appreciate any pointers.
Chris
Steven DiStefano
Hi Chris,
Did you use TSW (Telephpony Setup Wizard) to configure FXS analog stations?
Did you configure them as User Mode?
What extensions did you assign them?
Steve
Here's the current config:
Port          Role      Sig     Ext
0/0/0          User     LS     221
0/0/1          FAX     LS     222
0/0/2          User     LS     223
0/0/3          User     LS     224
Chris
Ok, now check to see that there is one, and only one ephone-dn for each user mode analog phone.
If you have more that one, we need to remove one.
how did this end up?
