04-15-2010 12:11 PM - edited 03-21-2019 02:26 AM
I have a client that has bought a uc540 and wants his two depts to have a diffrent source of MOH. Is it possible?
Solved! Go to Solution.
04-15-2010 12:31 PM
You can configure up to 5 music on hold groups and 6 music on hold sources total (the default MoH source, which is CCA configurable, plus the 5 MoH groups) on the UC540 if you are using audio files uploaded to the UC540 unit for music on hold. Here are the limitations for using multiple music on hold sources on the UC500 platform:
Details on configuring the music on hold groups can be found here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemoh.html#wp1022742
04-15-2010 12:17 PM
I heard this being discussed for CME but have not seen it discussed for UC500....
Will ask around, but dont think so.
04-15-2010 12:31 PM
04-15-2010 12:54 PM
Thanks!
