Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
525
Highlighted
Beginner
Can you set a distinct ringtone for an incoming number?
We have a client with a UC560. There is a sip-based call box on extension 321 that can unlock a door. We want the calls to come a specific 7962 handset that sits next to a screen that shows a security camera pointed at that door. We would like the call box to have a different ringtone from all the other calls that come into the 7962 so that the ladies know to look at the camera before picking up the phone (which would unlock the door). Is there a way to assign a unique ringtone to an internal extension?
Thanks!!
3 REPLIES 3
Highlighted
Beginner
Hi Tracy,
I am not aware of a way to do this with a specific incoming number.  However, you could create a seperate button on the phone that the SIP box only calls.  You can assign a custom ringtone to that specific button.
This works on the SPA525G I have sitting in front of me unfortunately I don't have a 7962 with me.
Let me know if you have any questions.
-Trent Good
-Trent Good ** Please rate useful posts! **
Highlighted
Beginner
What might that look like? I'm trying to follow your line of thinking here..The callbox is on an internal extension.
Highlighted
Beginner
Re: Can you set a distinct ringtone for an incoming number?
7962:
button 1: ext300  <---- used as primary line
button 2: ext301  <---- used only for opening door.
The normal calls will go to extension 300.  ONLY the callbox will call 301. Therefore when she receives calls on 301 they should only be coming from the callbox. Therefore when you assign a ringtone to that button it will ring differently for calls from the callbox.
EDIT: This may be of help when configuring a different ringtone:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7962g_7961g_7961g-ge_7942g_7941g_7941g-ge/8_0/english/user/guide/62614241cus.html
