11-01-2011 05:30 AM - edited 03-21-2019 04:53 AM
Hello, I am trying to setup the SIP settings on UC560 to do inbound and outbound calls with a third-part softphone (x-lite), I can make outbound calls, but I cannot receive.
I haven't an external SIP provider.
11-01-2011 05:57 AM
need more infos
add config, net scheme, debug ccsip
try to check IOS and trust list:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080b3e123.shtml
regards
11-01-2011 06:33 AM
I have 3 Cisco IP Phones SPA502G and 3 PCs running X-Lite. The status on UC 560 is "unregistred".
Follow my running-config...
Thanks a lot.
____________________________________________________
Building configuration...
Current configuration : 46608 bytes
! Last configuration change at 09:40:09 PST Tue Nov 1 2011 by admin
! NVRAM config last updated at 08:42:21 PST Tue Nov 1 2011 by admin
version 15.0
parser config cache interface
no service pad
no service timestamps debug uptime
service internal
service compress-config
service sequence-numbers
hostname CISCO_UC560
boot-start-marker
boot-end-marker
card type e1 0 3
no logging buffered
no logging rate-limi!
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone HAA -3
clock summer-time PST recurring
network-clock-participate wic 3
network-clock-select 1 E1 0/3/0
crypto pki trustpoint TP-self-signed-2391895197
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2391895197
revocation-check none
rsakeypair TP-self-signed-2391895197
crypto pki certificate chain TP-self-signed-2391895197
certificate self-signed 01
quit
dot11 syslog
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.3.16 192.168.3.255
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.3.10
ip dhcp excluded-address 192.168.0.1 192.168.0.9
ip dhcp excluded-address 192.168.0.241 192.168.0.255
ip dhcp excluded-address 192.168.4.1 192.168.4.9
ip dhcp pool phone
network 192.168.3.0 255.255.255.0
default-router 192.168.3.10
option 150 ip 192.168.3.10
ip dhcp pool data
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
dns-server 192.168.0.3
ip dhcp pool wifi
import all
network 192.168.4.0 255.255.255.0
default-router 192.168.4.1
ip name-server 189.87.9.54
ip name-server 189.87.9.59
ip inspect log drop-pkt
ip inspect name SDM_MEDIUM appfw SDM_MEDIUM
ip inspect name SDM_MEDIUM cuseeme
ip inspect name SDM_MEDIUM dns
ip inspect name SDM_MEDIUM ftp
ip inspect name SDM_MEDIUM h323
ip inspect name SDM_MEDIUM https
ip inspect name SDM_MEDIUM icmp
ip inspect name SDM_MEDIUM imap reset
ip inspect name SDM_MEDIUM pop3 reset
ip inspect name SDM_MEDIUM netshow
ip inspect name SDM_MEDIUM rcmd
ip inspect name SDM_MEDIUM realaudio
ip inspect name SDM_MEDIUM rtsp
ip inspect name SDM_MEDIUM esmtp
ip inspect name SDM_MEDIUM sqlnet
ip inspect name SDM_MEDIUM streamworks
ip inspect name SDM_MEDIUM tftp
ip inspect name SDM_MEDIUM tcp router-traffic
ip inspect name SDM_MEDIUM udp
ip inspect name SDM_MEDIUM vdolive
no ipv6 cef
appfw policy-name SDM_MEDIUM
application im aol
service default action allow alarm
service text-chat action allow alarm
server permit name login.oscar.aol.com
server permit name toc.oscar.aol.com
server permit name oam-d09a.blue.aol.com
audit-trail on
application im msn
server permit name messenger.hotmail.com
server permit name gateway.messenger.hotmail.com
server permit name webmessenger.msn.com
audit-trail on
application http
strict-http action allow alarm
port-misuse im action reset alarm
port-misuse p2p action reset alarm
port-misuse tunneling action allow alarm
application im yahoo
server permit name scs.msg.yahoo.com
server permit name scsa.msg.yahoo.com
server permit name scsb.msg.yahoo.com
server permit name scsc.msg.yahoo.com
server permit name scsd.msg.yahoo.com
server permit name cs16.msg.dcn.yahoo.com
server permit name cs19.msg.dcn.yahoo.com
server permit name cs42.msg.dcn.yahoo.com
server permit name cs53.msg.dcn.yahoo.com
server permit name cs54.msg.dcn.yahoo.com
server permit name ads1.vip.scd.yahoo.com
server permit name radio1.launch.vip.dal.yahoo.com
server permit name in1.msg.vip.re2.yahoo.com
server permit name data1.my.vip.sc5.yahoo.com
server permit name address1.pim.vip.mud.yahoo.com
server permit name edit.messenger.yahoo.com
server permit name messenger.yahoo.com
server permit name http.pager.yahoo.com
server permit name privacy.yahoo.com
server permit name csa.yahoo.com
server permit name csb.yahoo.com
server permit name csc.yahoo.com
audit-trail on
stcapp ccm-group 1
stcapp
isdn switch-type primary-qsig
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
trunk group ALL_T1E1
translation-profile outgoing PROFILE_ALL_T1E1
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
voice user-profile 1
max-idle-time 30
user mauricio password 123456
number 4001 type normal
voice translation-rule 4
rule 15 /^.*$/ /7370/
voice translation-rule 12
rule 1 /7399/ /7371/
voice translation-rule 13
rule 1 /4000/ /5002/
voice translation-rule 14
rule 1 /7372/ /5003/
voice translation-rule 15
rule 1 /7370/ /5004/
voice translation-rule 16
rule 1 /7371/ /5005/
voice translation-rule 20
rule 1 /7373/ /5001/
voice translation-rule 25
rule 1 /7374/ /7374/
rule 2 /7375/ /7375/
rule 3 /7376/ /7376/
rule 4 /7377/ /7377/
rule 5 /7378/ /7378/
rule 6 /7379/ /7379/
voice translation-rule 26
rule 1 /7380/ /7380/
rule 2 /7381/ /7381/
rule 3 /7382/ /7382/
rule 4 /7383/ /7383/
rule 5 /7384/ /7384/
rule 6 /7385/ /7385/
rule 7 /7386/ /7386/
rule 8 /7387/ /7387/
rule 9 /7388/ /7388/
rule 10 /7389/ /7389/
voice translation-rule 27
rule 1 /7390/ /7390/
rule 2 /7391/ /7391/
rule 3 /7392/ /7392/
rule 4 /7393/ /7393/
rule 5 /7394/ /7394/
rule 6 /7395/ /7395/
rule 7 /7396/ /7396/
rule 8 /7397/ /7397/
rule 9 /7398/ /7398/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 2 /^0/ //
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile Comercial-HG_Called_13
translate calling 3265
translate called 13
voice translation-profile Diretoria-HG_Called_12
translate called 12
voice translation-profile Financeiro-HG_Called_14
translate called 14
voice translation-profile Geral_Called_25
translate called 25
voice translation-profile Geral_Called_26
translate called 26
voice translation-profile Geral_Called_27
translate called 27
voice translation-profile Mauricio-HG_Called_20
translate called 20
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PROFILE_ALL_T1E1
translate calling 4
voice translation-profile Relacionamento-HG_Called_15
translate called 15
voice translation-profile Suporte-HG_Called_16
translate called 16
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
license udi pid UC560-T1E1-K9 sn FGL152610LW
archive
log config
logging enable
logging size 600
hidekeys
username admin privilege 15 secret 5 $1$..RG$843GyEuoILovS/dBjDFOr/
controller E1 0/3/0
pri-group timeslots 1-24
ip tftp source-interface Vlan90
class-map match-any sdm_p2p_kazaa
match protocol fasttrack
match protocol kazaa2
class-map match-any sdm_p2p_edonkey
match protocol edonkey
class-map match-any sdm_p2p_gnutella
match protocol gnutella
class-map match-any sdm_p2p_bittorrent
match protocol bittorrent
policy-map sdmappfwp2p_SDM_MEDIUM
class sdm_p2p_gnutella
class sdm_p2p_bittorrent
class sdm_p2p_edonkey
class sdm_p2p_kazaa
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address 189.87.9.54 255.255.255.248
ip access-group 106 in
ip verify unicast reverse-path
ip nat outside
ip inspect SDM_MEDIUM out
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
service-policy input sdmappfwp2p_SDM_MEDIUM
service-policy output sdmappfwp2p_SDM_MEDIUM
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan90
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface GigabitEthernet0/1/0
switchport access vlan 200
macro description cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/1
switchport voice vlan 100
macro description cisco-phone
interface GigabitEthernet0/1/2
switchport trunk native vlan 10
switchport mode trunk
macro description cisco-wireless
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 90
interface Serial0/3/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn supp-service name calling profile Network-Extension operation-value-tag local
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
ip access-group 101 in
ip nat inside
interface Vlan10
ip address 192.168.4.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface Vlan90
ip address 10.1.10.2 255.255.255.252
ip access-group 105 in
ip nat inside
interface Vlan100
ip address 192.168.3.10 255.255.255.0
ip access-group 103 in
ip nat inside
interface Vlan200
ip address 192.168.2.1 255.255.255.0
ip access-group 104 in
ip nat inside
interface Vlan300
ip address 186.8.94.42 255.255.255.248
ip nat inside
ip forward-protocol nd
ip http server
ip http port 8080
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 189.87.9.51
ip route 10.1.10.1 255.255.255.255 Vlan90
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 186.8.94.40 0.0.0.7
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip 192.168.0.0 0.0.0.255 any
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 186.8.94.40 0.0.0.7 any
access-list 101 deny ip 192.168.4.0 0.0.0.255 any
access-list 101 deny ip 189.87.9.50 0.0.0.7 any
access-list 101 deny ip 192.168.2.0 0.0.0.255 any
access-list 101 deny ip 10.1.10.0 0.0.0.3 any
access-list 101 deny ip 192.168.3.0 0.0.0.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 189.87.9.54 0.0.0.7 any
access-list 102 deny ip 192.168.2.0 0.0.0.255 any
access-list 102 deny ip 192.168.0.0 0.0.0.255 any
access-list 102 deny ip 10.1.10.0 0.0.0.3 any
access-list 102 deny ip 192.168.3.0 0.0.0.255 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_11##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny ip 189.87.9.54 0.0.0.7 any
access-list 103 deny ip 192.168.4.0 0.0.0.255 any
access-list 103 deny ip 189.87.9.50 0.0.0.7 any
access-list 103 deny ip 192.168.2.0 0.0.0.255 any
access-list 103 deny ip 192.168.0.0 0.0.0.255 any
access-list 103 deny ip 10.1.10.0 0.0.0.3 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_9##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny ip 186.8.94.40 0.0.0.7 any
access-list 104 deny ip 192.168.4.0 0.0.0.255 any
access-list 104 deny ip 189.87.9.54 0.0.0.7 any
access-list 104 deny ip 192.168.0.0 0.0.0.255 any
access-list 104 deny ip 10.1.10.0 0.0.0.3 any
access-list 104 deny ip 192.168.3.0 0.0.0.255 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark auto generated by SDM firewall configuration##NO_ACES_11##
access-list 105 remark SDM_ACL Category=1
access-list 105 permit tcp 192.168.3.0 0.0.0.255 eq 2000 any
access-list 105 permit udp 192.168.3.0 0.0.0.255 eq 2000 any
access-list 105 deny ip 118.87.9.5 0.0.0.7 any
access-list 105 deny ip 192.168.4.0 0.0.0.255 any
access-list 105 deny ip 189.87.9.54 0.0.0.7 any
access-list 105 deny ip 192.168.2.0 0.0.0.255 any
access-list 105 deny ip 192.168.0.0 0.0.0.255 any
access-list 105 deny ip 192.168.3.0 0.0.0.255 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 permit ip any any
access-list 106 remark auto generated by SDM firewall configuration##NO_ACES_18##
access-list 106 remark SDM_ACL Category=1
access-list 106 deny ip 189.87.9.50 0.0.0.7 any
access-list 106 deny ip 192.168.4.0 0.0.0.255 any
access-list 106 deny ip 192.168.2.0 0.0.0.255 any
access-list 106 deny ip 192.168.0.0 0.0.0.255 any
access-list 106 deny ip 10.1.10.0 0.0.0.3 any
access-list 106 deny ip 192.168.3.0 0.0.0.255 any
access-list 106 permit udp host 189.87.9.54 eq domain any
access-list 106 permit udp host 189.87.9.51 eq domain any
access-list 106 permit icmp any host 189.87.9.54 echo-reply
access-list 106 permit icmp any host 189.87.9.54 time-exceeded
access-list 106 permit icmp any host 189.87.9.54 unreachable
access-list 106 deny ip 10.0.0.0 0.255.255.255 any
access-list 106 deny ip 172.16.0.0 0.15.255.255 any
access-list 106 deny ip 192.168.0.0 0.0.255.255 any
access-list 106 deny ip 127.0.0.0 0.255.255.255 any
access-list 106 deny ip host 255.255.255.255 any
access-list 106 deny ip host 0.0.0.0 any
access-list 106 deny ip any any log
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/5x5/spa5x5-7-4-2.bin alias spa5x5-7-4-2.bin
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
control-plane
call threshold interface GigabitEthernet0/0 int-calls low 30 high 30
voice-port 0/0/0
cptone BR
shutdown
caller-id enable
voice-port 0/0/1
cptone BR
shutdown
caller-id enable
voice-port 0/0/2
cptone BR
shutdown
caller-id enable
voice-port 0/0/3
cptone BR
shutdown
caller-id enable
voice-port 0/3/0:15
cptone BR
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone BR
connection plar opx 201
shutdown
description Configured by CCA 4FXO-0/1/0-Custom-OP
caller-id enable
voice-port 0/1/1
cptone BR
connection plar 202
shutdown
caller-id enable
voice-port 0/1/2
cptone BR
connection plar 203
shutdown
caller-id enable
voice-port 0/1/3
cptone BR
connection plar 204
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Vlan90
sccp ccm 192.168.3.10 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
port 0/0/0
no sip-register
dial-peer voice 2 pots
port 0/0/1
no sip-register
dial-peer voice 3 pots
port 0/0/2
no sip-register
dial-peer voice 4 pots
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 1000
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 70 pots
description **CCA*Brazil*Local Calls**
no sip-register
dial-peer voice 72 pots
description **CCA*Brazil*Local Mobile Calls**
no sip-register
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 71 pots
trunkgroup ALL_T1E1
corlist outgoing call-international
description **CCA*Brazil*International Calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 000T
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup ALL_T1E1
corlist outgoing call-national
description **CCA*Brazil*National Calls**
preference 3
destination-pattern 00............
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup ALL_T1E1
corlist outgoing call-toll-free
description **CCA*Brazil*800,900 etc**
preference 3
destination-pattern 00[3-9]00.......
forward-digits all
no sip-register
dial-peer voice 77 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 78 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*Brazil*Police, Ambulance, etc**
preference 3
destination-pattern 019.
forward-digits all
no sip-register
dial-peer voice 79 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 80 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 19.
forward-digits all
no sip-register
dial-peer voice 81 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 82 pots
trunkgroup ALL_T1E1
corlist outgoing call-local-plus
description **CCA*Brazil*Electric, Water, etc**
preference 3
destination-pattern 01..
forward-digits all
no sip-register
dial-peer voice 83 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 84 pots
no sip-register
dial-peer voice 86 pots
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_T1E1
description **CCA*Brazil*Local**
preference 3
destination-pattern 0[2-9].......
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 150 pots
direct-inward-dial
port 0/3/0:15
dial-peer voice 3007 pots
description Diretoria-HG
translation-profile incoming Diretoria-HG_Called_12
incoming called-number 7399
direct-inward-dial
port 0/3/0:15
dial-peer voice 3008 pots
description Comercial-HG
translation-profile incoming Comercial-HG_Called_13
incoming called-number 4000
direct-inward-dial
port 0/3/0:15
dial-peer voice 3009 pots
description Financeiro-HG
translation-profile incoming Financeiro-HG_Called_14
incoming called-number 7372
direct-inward-dial
port 0/3/0:15
dial-peer voice 3010 pots
description Relacionamento-HG
translation-profile incoming Relacionamento-HG_Called_15
incoming called-number 7370
direct-inward-dial
port 0/3/0:15
dial-peer voice 3011 pots
description Suporte-HG
translation-profile incoming Suporte-HG_Called_16
incoming called-number 7371
direct-inward-dial
port 0/3/0:15
dial-peer voice 3015 pots
description Mauricio-HG
translation-profile incoming Mauricio-HG_Called_20
incoming called-number 7373
direct-inward-dial
port 0/3/0:15
dial-peer voice 3020 pots
description Geral
translation-profile incoming Geral_Called_25
incoming called-number 737[4-9]
direct-inward-dial
port 0/3/0:15
dial-peer voice 3021 pots
description Geral
translation-profile incoming Geral_Called_26
incoming called-number 738.
direct-inward-dial
port 0/3/0:15
dial-peer voice 3022 pots
description Geral
translation-profile incoming Geral_Called_27
incoming called-number 739[0-8]
direct-inward-dial
port 0/3/0:15
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 114
max-dn 600
ip source-address 192.168.3.10 port 2000
max-redirect 20
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Site Blindado S/A
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 521G-524G cp524g-8-1-17
load 501G spa5x5-7-4-2
load 502G spa5x5-7-4-2
load 504G spa5x5-7-4-2
load 508G spa5x5-7-4-2
load 509G spa5x5-7-4-2
time-zone 17
time-format 24
date-format dd-mm-yy
voicemail 1000
max-conferences 8 gain -6
call-forward pattern .T
hunt-group logout HLog
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$pzIx$QT6gij1Yk8r5y7qzQQhf70
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 0.T
transfer-pattern .T
transfer-pattern 6.... blind
secondary-dialtone 0
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 Oct 28 2011 14:52:30
ephone-template 15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use Newcall
softkeys idle Redial Newcall Cfwdall Pickup Gpickup Dnd HLog Login
softkeys seized Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template 16
ephone-template 17
softkeys remote-in-use CBarge Newcall
ephone-template 18
ephone-dn 9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn 10 dual-line
number 201 no-reg primary
label 201
description 201
name 201
ephone-dn 11 dual-line
number 202 no-reg primary
label 202
description 202
name 202
ephone-dn 12 dual-line
number 203 no-reg primary
label 203
description 203
name 203
ephone-dn 13 dual-line
number 204 no-reg primary
label 204
description 204
name 204
ephone-dn 14 dual-line
number 205 no-reg primary
label 205
description 205
name 205
ephone-dn 15 dual-line
number 206 no-reg primary
label 206
description 206
name 206
ephone-dn 16 dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn 17 dual-line
number 208 no-reg primary
label 208
description 208
name 208
ephone-dn 18 dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn 19 dual-line
number 210 no-reg primary
label 210
description 210
name 210
ephone-dn 20 dual-line
number 211 no-reg primary
label 211
description 211
name 211
ephone-dn 21 dual-line
number 212 no-reg primary
label 212
description 212
name 212
ephone-dn 22 dual-line
number 213 no-reg primary
label 213
description 213
name 213
ephone-dn 23 dual-line
number 214 no-reg primary
label 214
description 214
name 214
ephone-dn 24 dual-line
number 215 no-reg primary
label 215
description 215
name 215
ephone-dn 25 dual-line
number 216 no-reg primary
label 216
description 216
name 216
ephone-dn 26 dual-line
number 217 no-reg primary
label 217
description 217
name 217
ephone-dn 27 dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn 28 dual-line
number 219 no-reg primary
label 219
description 219
name 219
ephone-dn 29 dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn 30 dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn 31 dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn 32 dual-line
number 223 no-reg primary
label 223
description 223
name 223
ephone-dn 33 dual-line
number 224 no-reg primary
label 224
description 224
name 224
ephone-dn 34 dual-line
number 225 no-reg primary
label 225
description 225
name 225
ephone-dn 35 dual-line
number 226 no-reg primary
label 226
description 226
name 226
ephone-dn 36 dual-line
number 227 no-reg primary
label 227
description 227
name 227
ephone-dn 37 dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn 38 dual-line
number 229 no-reg primary
label 229
description 229
name 229
ephone-dn 39 dual-line
number 230 no-reg primary
label 230
description 230
name 230
ephone-dn 40 dual-line
number 231 no-reg primary
label 231
description 231
name 231
ephone-dn 41 dual-line
number 232 no-reg primary
label 232
description 232
name 232
ephone-dn 42 dual-line
number 233 no-reg primary
label 233
description 233
name 233
ephone-dn 43 dual-line
number 234 no-reg primary
label 234
description 234
name 234
ephone-dn 44 dual-line
number 235 no-reg primary
label 235
description 235
name 235
ephone-dn 45 dual-line
number 236 no-reg primary
label 236
description 236
name 236
ephone-dn 46 dual-line
number 237 no-reg primary
label 237
description 237
name 237
ephone-dn 47 dual-line
number 238 no-reg primary
label 238
description 238
name 238
ephone-dn 48 dual-line
number 239 no-reg primary
label 239
description 239
name 239
ephone-dn 49 dual-line
number 240 no-reg primary
label 240
description 240
name 240
ephone-dn 50 dual-line
number 241 no-reg primary
label 241
description 241
name 241
ephone-dn 51 dual-line
number 242 no-reg primary
label 242
description 242
name 242
ephone-dn 52 dual-line
number 243 no-reg primary
label 243
description 243
name 243
ephone-dn 53 dual-line
number 244 no-reg primary
label 244
description 244
name 244
ephone-dn 54 dual-line
number 245 no-reg primary
label 245
description 245
name 245
ephone-dn 55 dual-line
number 246 no-reg primary
label 246
description 246
name 246
ephone-dn 56 dual-line
number 247 no-reg primary
label 247
description 247
name 247
ephone-dn 57 dual-line
number 248 no-reg primary
label 248
description 248
name 248
ephone-dn 58 dual-line
number 249 no-reg primary
label 249
description 249
name 249
ephone-dn 59 dual-line
number 250 no-reg primary
label 250
description 250
name 250
ephone-dn 60 dual-line
number 251 no-reg primary
label 251
description 251
name 251
ephone-dn 61 dual-line
number 252 no-reg primary
label 252
description 252
name 252
ephone-dn 62 dual-line
number 253 no-reg primary
label 253
description 253
name 253
ephone-dn 63 dual-line
number 254 no-reg primary
label 254
description 254
name 254
ephone-dn 64 dual-line
number 255 no-reg primary
label 255
description 255
name 255
ephone-dn 65 dual-line
number 256 no-reg primary
label 256
description 256
name 256
ephone-dn 66 dual-line
number 257 no-reg primary
label 257
description 257
name 257
ephone-dn 67 dual-line
number 258 no-reg primary
label 258
description 258
name 258
ephone-dn 68 dual-line
number 259 no-reg primary
label 259
description 259
name 259
ephone-dn 69 dual-line
number 260 no-reg primary
label 260
description 260
name 260
ephone-dn 70 dual-line
number 261 no-reg primary
label 261
description 261
name 261
ephone-dn 71 dual-line
number 262 no-reg primary
label 262
description 262
name 262
ephone-dn 72 dual-line
number 263 no-reg primary
label 263
description 263
name 263
ephone-dn 73 dual-line
number 264 no-reg primary
label 264
description 264
name 264
ephone-dn 74 dual-line
number 265 no-reg primary
label 265
description 265
name 265
ephone-dn 75 dual-line
number 266 no-reg primary
label 266
description 266
name 266
ephone-dn 76 dual-line
number 267 no-reg primary
label 267
description 267
name 267
ephone-dn 77 dual-line
number 268 no-reg primary
label 268
description 268
name 268
ephone-dn 78 dual-line
number 269 no-reg primary
label 269
description 269
name 269
ephone-dn 79 dual-line
number 270 no-reg primary
label 270
description 270
name 270
ephone-dn 80 dual-line
number 271 no-reg primary
label 271
description 271
name 271
ephone-dn 81 dual-line
number 272 no-reg primary
label 272
description 272
name 272
ephone-dn 82 dual-line
number 273 no-reg primary
label 273
description 273
name 273
ephone-dn 83 dual-line
number 274 no-reg primary
label 274
description 274
name 274
ephone-dn 84 dual-line
number 275 no-reg primary
label 275
description 275
name 275
ephone-dn 85 dual-line
number 276 no-reg primary
label 276
description 276
name 276
ephone-dn 86 dual-line
number 277 no-reg primary
label 277
description 277
name 277
ephone-dn 87 dual-line
number 278 no-reg primary
label 278
description 278
name 278
ephone-dn 88 dual-line
number 279 no-reg primary
label 279
description 279
name 279
ephone-dn 89 dual-line
number 280 no-reg primary
label 280
description 280
name 280
ephone-dn 90 dual-line
number 281 no-reg primary
label 281
description 281
name 281
ephone-dn 91 dual-line
number 282 no-reg primary
label 282
description 282
name 282
ephone-dn 92 dual-line
number 283 no-reg primary
label 283
description 283
name 283
ephone-dn 93 dual-line
number 284 no-reg primary
label 284
description 284
name 284
ephone-dn 94 dual-line
number 285 no-reg primary
label 285
description 285
name 285
ephone-dn 95 dual-line
number 286 no-reg primary
label 286
description 286
name 286
ephone-dn 96 dual-line
number 287 no-reg primary
label 287
description 287
name 287
ephone-dn 97 dual-line
number 288 no-reg primary
label 288
description 288
name 288
ephone-dn 98 dual-line
number 289 no-reg primary
label 289
description 289
name 289
ephone-dn 99 dual-line
number 290 no-reg primary
label 290
description 290
name 290
ephone-dn 100 dual-line
number 291 no-reg primary
label 291
description 291
name 291
ephone-dn 101 dual-line
number 292 no-reg primary
label 292
description 292
name 292
ephone-dn 102 dual-line
number 293 no-reg primary
label 293
description 293
name 293
ephone-dn 103 dual-line
number 294 no-reg primary
label 294
description 294
name 294
ephone-dn 104 dual-line
number 295 no-reg primary
label 295
description 295
name 295
ephone-dn 105 dual-line
number 296 no-reg primary
label 296
description 296
name 296
ephone-dn 106 dual-line
number 297 no-reg primary
label 297
description 297
name 297
ephone-dn 107 dual-line
number 298 no-reg primary
label 298
description 298
name 298
ephone-dn 108 dual-line
number 299 no-reg primary
label 299
description 299
name 299
ephone-dn 109 dual-line
number 310 no-reg primary
label 310
description 310
name 310
ephone-dn 110 dual-line
number 311 no-reg primary
label 311
description 311
name 311
ephone-dn 111 dual-line
number 312 no-reg primary
label 312
description 312
name 312
ephone-dn 112 dual-line
number 313 no-reg primary
label 313
description 313
name 313
ephone-dn 113 dual-line
number 314 no-reg primary
label 314
description 314
name 314
ephone-dn 591 octo-line
number 7396 secondary 7396 no-reg primary
label 7396
description Leandro Anjos
name Leandro Anjos
ephone-dn 592 octo-line
number 7395 secondary 7395 no-reg primary
label 7395
description Bruno Silva
name Bruno Silva
call-forward busy 1000
call-forward noan 1000 timeout 20
ephone-dn 593 dual-line
number 7394 no-reg primary
label 7394
description Juliana Bonfim
name Juliana Bonfim
ephone-dn 594 dual-line
number 4001 no-reg primary
label 4001
description Mauricio Kigiela
name Mauricio Kigiela
call-forward busy 7373
ephone-dn 595 dual-line
number 7390 no-reg primary
label 7390
description Nelson Correa
name Nelson Correa
ephone-dn 596 dual-line
number 7380 no-reg primary
label 7380
description Bernardo Carneiro
name Bernardo Carneiro
ephone-dn 597 dual-line
number 7373 no-reg primary
label 7373
ephone-dn 598
number 6.... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 1000
ephone-dn 599
number A801.... no-reg primary
mwi off
ephone-dn 600
number A800.... no-reg primary
mwi on
ephone 1
device-security-mode none
mac-address C89C.1D6D.AD89
ephone-template 16
max-calls-per-button 2
username "bcarneiro" password 123456
type 502G
button 1:596
ephone 2
mac-address C89C.1D6D.D62B
ephone-template 16
username "ncorrea" password 123456
type 502G
button 1:595
ephone 3
mac-address 78E7.D1B0.6DCC
ephone-template 16
username "jubonfim" password 123456
type ata
button 1:593
ephone 4
mac-address 0000.0000.7395
ephone-template 16
username "bsilva" password bsilva
type CIPC
button 1:592
ephone 5
mac-address C89C.1D6D.AD58
ephone-template 16
username "mkigiela" password 123456
type 502G
button 1:597
ephone 6
mac-address 0000.0000.7396
ephone-template 16
username "lanjos" password lanjos
type CIPC
button 1:591
ephone-hunt 1 peer
pilot 7371
list 7373, 7380
timeout 8, 8
no-reg pilot
statistics collect
ephone-hunt 2 peer
pilot 5002
list 7390, 7380
timeout 15, 15
no-reg pilot
statistics collect
ephone-hunt 3 peer
pilot 5003
list 7373
timeout 8
no-reg pilot
statistics collect
ephone-hunt 4 peer
pilot 5004
list 7390
timeout 8
no-reg pilot
statistics collect
ephone-hunt 5 peer
pilot 5005
list 7390, 7394, 7395, 7396
timeout 8, 8, 8, 8
no-reg pilot
statistics collect
description Suporte
ephone-hunt 6 sequential
pilot 5001
list 7373, 4001
final 085928000
timeout 8, 8
no-reg pilot
statistics collect
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.1 (1). Thu Oct 13 16:08:00 BRT 2011^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
speed 115200
line vty 5 100
ntp master
end
11-01-2011 10:56 AM
Can you add the output of "debug ccsip all" command during incoming calls to Xlite?
Regards.
P.S. Remove password from the config.
11-01-2011 11:19 AM
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited,
14 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 1200 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Persistent logging: disabled
No active filter modules.
ESM: 0 messages dropped
Trap logging: level informational, 33015 message lines logged
Log Buffer (5000000 bytes):
032668: Nov 1 16:04:01.710: %SYS-5-CONFIG_I: Configured from http by admin on 192.168.0.42
032669: Nov 1 16:04:02.642: %SEC-6-IPACCESSLOGP: list 106 denied udp 88.0.138.225(22844) -> 198.80.94.50(42356), 1 packet
032670: Nov 1 16:04:04.102: %SEC-6-IPACCESSLOGP: list 106 denied tcp 201.10.87.45(20401) -> 198.80.94.50(42356), 1 packet
032671: Nov 1 16:04:07.398: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 118.159.231.157 -> 198.80.94.50 (8/0), 1 packet
032672: Nov 1 16:04:10.690: %SEC-6-IPACCESSLOGP: list 106 denied udp 85.170.105.250(32580) -> 198.80.94.50(42357), 1 packet
032673: Nov 1 16:04:12.066: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.248.132.21(35385) -> 198.80.94.50(42356), 1 packet
032674: Nov 1 16:04:13.454: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 113 packets
032675: Nov 1 16:04:13.670: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.108.253.91(22471) -> 198.80.94.50(42356), 1 packet
032676: Nov 1 16:04:15.706: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.200.90.45(19982) -> 198.80.94.50(42356), 1 packet
032677: Nov 1 16:04:17.994: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 222.132.26.98 -> 198.80.94.50 (8/0), 1 packet
032678: Nov 1 16:04:19.122: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.178.130.176(10114) -> 198.80.94.50(42356), 1 packet
032679: Nov 1 16:04:20.538: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.148.125.1(7185) -> 198.80.94.50(42356), 1 packet
032680: Nov 1 16:04:21.546: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 183.60.194.24 -> 198.80.94.50 (8/0), 1 packet
032681: Nov 1 16:04:23.266: %FW-6-DROP_PKT: Dropping http session 198.80.94.50:50959 75.126.233.14:80 due to RST inside current window with ip ident 5030 tcpflags 0x5014 seq.no 4056305728 ack 1564200922
032682: Nov 1 16:04:23.958: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.82.242.151(36762) -> 198.80.94.50(42356), 1 packet
032683: Nov 1 16:04:25.350: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.50.85.84(10023) -> 198.80.94.50(42356), 1 packet
032684: Nov 1 16:04:26.682: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.102.162.123(16641) -> 198.80.94.50(14650), 1 packet
032685: Nov 1 16:04:27.798: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 119.254.22.206 -> 198.80.94.50 (8/0), 1 packet
032686: Nov 1 16:04:29.514: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.252.199.181(17720) -> 198.80.94.50(42356), 1 packet
032687: Nov 1 16:04:31.046: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.51.129.251(24915) -> 198.80.94.50(42356), 1 packet
032688: Nov 1 16:04:32.370: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.91.244.205(26835) -> 198.80.94.50(42356), 1 packet
032689: Nov 1 16:04:33.422: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1924885770 1470 bytes is out-of-order; expected seq:1924861460. Reason: TCP reassembly queue overflow - session 192.168.0.3:3597 to 74.125.65.102:80
032690: Nov 1 16:04:33.558: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 222.132.26.98 -> 198.80.94.50 (8/0), 1 packet
032691: Nov 1 16:04:35.046: %SEC-6-IPACCESSLOGP: list 106 denied udp 177.60.172.134(45751) -> 198.80.94.50(42356), 1 packet
032692: Nov 1 16:04:36.494: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51034 to 65.95.111.185:80
032693: Nov 1 16:04:36.498: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51033 to 200.92.106.61:80
032694: Nov 1 16:04:36.678: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51034 to 65.95.111.185:80
032695: Nov 1 16:04:36.682: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51034 to 65.95.111.185:80
032696: Nov 1 16:04:36.694: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51033 to 200.92.106.61:80
032697: Nov 1 16:04:36.698: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51033 to 200.92.106.61:80
032698: Nov 1 16:04:37.434: %SEC-6-IPACCESSLOGP: list 106 denied tcp 201.19.104.205(3049) -> 198.80.94.50(9263), 1 packet
032699: Nov 1 16:04:37.438: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2538992217 1500 bytes is out-of-order; expected seq:2538954569. Reason: TCP reassembly queue overflow - session 192.168.4.13:57897 to 72.246.216.56:80
032700: Nov 1 16:04:39.178: %SEC-6-IPACCESSLOGP: list 106 denied udp 170.51.167.170(39382) -> 198.80.94.50(42356), 1 packet
032701: Nov 1 16:04:41.038: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.176.7.252(30133) -> 198.80.94.50(42356), 1 packet
032702: Nov 1 16:04:42.074: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.21.12.185(10028) -> 198.80.94.50(42356), 1 packet
032703: Nov 1 16:04:43.602: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.190.25.126(22631) -> 198.80.94.50(42356), 1 packet
032704: Nov 1 16:04:44.698: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.208.124.239(34837) -> 198.80.94.50(42356), 1 packet
032705: Nov 1 16:04:46.410: %SEC-6-IPACCESSLOGP: list 106 denied udp 84.90.14.227(49473) -> 198.80.94.50(42356), 1 packet
032706: Nov 1 16:04:47.698: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.107.100.7(8140) -> 198.80.94.50(42356), 1 packet
032707: Nov 1 16:04:49.214: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.189.243.224(29201) -> 198.80.94.50(42356), 1 packet
032708: Nov 1 16:04:50.350: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.133.1.154(18404) -> 198.80.94.50(42356), 1 packet
032709: Nov 1 16:04:51.518: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.102.167.250(44577) -> 198.80.94.50(42356), 1 packet
032710: Nov 1 16:04:52.554: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 59.175.148.2 -> 198.80.94.50 (8/0), 1 packet
032711: Nov 1 16:04:53.838: %FW-6-DROP_PKT: Dropping http session 187.108.192.21:80 192.168.0.24:53976 due to SYN inside current window with ip ident 0 tcpflags 0x6012 seq.no 2677993157 ack 4253623700
032712: Nov 1 16:04:53.838: %SEC-6-IPACCESSLOGP: list 106 denied udp 72.219.241.222(55859) -> 198.80.94.50(42356), 1 packet
032713: Nov 1 16:04:54.990: %SEC-6-IPACCESSLOGP: list 106 denied udp 62.98.162.229(15561) -> 198.80.94.50(42356), 1 packet
032714: Nov 1 16:04:57.922: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 221.8.77.15 -> 198.80.94.50 (8/0), 1 packet
032715: Nov 1 16:04:59.230: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.244.63.13(26821) -> 198.80.94.50(42356), 1 packet
032716: Nov 1 16:05:01.042: %SEC-6-IPACCESSLOGP: list 106 denied udp 65.188.44.143(11104) -> 198.80.94.50(42356), 1 packet
032717: Nov 1 16:05:02.262: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52878) -- responder (65.55.64.254:80)
032718: Nov 1 16:05:02.362: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52879) -- responder (65.55.64.254:80)
032719: Nov 1 16:05:02.422: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52878 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032720: Nov 1 16:05:02.426: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52878) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032721: Nov 1 16:05:02.566: %SEC-6-IPACCESSLOGP: list 106 denied tcp 65.55.64.254(80) -> 198.80.94.50(52878), 1 packet
032722: Nov 1 16:05:03.434: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52879 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032723: Nov 1 16:05:03.434: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52879) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032724: Nov 1 16:05:03.442: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52880) -- responder (65.55.64.254:80)
032725: Nov 1 16:05:03.578: %SEC-6-IPACCESSLOGP: list 106 denied tcp 65.55.64.254(80) -> 198.80.94.50(52879), 1 packet
032726: Nov 1 16:05:03.590: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52880 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032727: Nov 1 16:05:03.590: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52880) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032728: Nov 1 16:05:05.618: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52881) -- responder (65.55.64.254:80)
032729: Nov 1 16:05:05.770: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52881 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032730: Nov 1 16:05:05.770: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52881) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032731: Nov 1 16:05:05.914: %SEC-6-IPACCESSLOGP: list 106 denied tcp 65.55.64.254(80) -> 198.80.94.50(52881), 1 packet
032732: Nov 1 16:05:07.106: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.32.80.85(41563) -> 198.80.94.50(42356), 1 packet
032733: Nov 1 16:05:08.634: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.106.174.94(13552) -> 198.80.94.50(42356), 1 packet
032734: Nov 1 16:05:08.782: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52882) -- responder (65.55.64.254:80)
032735: Nov 1 16:05:08.930: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52882 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032736: Nov 1 16:05:08.930: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52882) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032737: Nov 1 16:05:09.994: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.34.6.56(14250) -> 198.80.94.50(42356), 1 packet
032738: Nov 1 16:05:12.918: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.82.112.212(10010) -> 198.80.94.50(42356), 1 packet
032739: Nov 1 16:05:12.966: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52885) -- responder (65.55.64.254:80)
032740: Nov 1 16:05:13.130: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52885 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032741: Nov 1 16:05:13.130: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52885) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032742: Nov 1 16:05:13.450: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 207 packets
032743: Nov 1 16:05:13.986: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 175.41.13.6 -> 198.80.94.50 (8/0), 1 packet
032744: Nov 1 16:05:15.062: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.104.105.131(48148) -> 198.80.94.50(42356), 1 packet
032745: Nov 1 16:05:16.206: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.192.92.247(21950) -> 198.80.94.50(42356), 1 packet
032746: Nov 1 16:05:18.490: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.208.68.200(44790) -> 198.80.94.50(42356), 1 packet
032747: Nov 1 16:05:19.750: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.88.167.75(40919) -> 198.80.94.50(42356), 1 packet
032748: Nov 1 16:05:21.794: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.30.75.66(17014) -> 198.80.94.50(42356), 1 packet
032749: Nov 1 16:05:23.242: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2436309507 1500 bytes is out-of-order; expected seq:2436271859. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032750: Nov 1 16:05:23.838: %FW-6-DROP_PKT: Dropping Other session 198.80.94.50:49635 200.196.153.62:443 due to RST inside current window with ip ident 6231 tcpflags 0x5014 seq.no 3507432708 ack 1078136965
032751: Nov 1 16:05:24.726: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2436533947 1500 bytes is out-of-order; expected seq:2436507883. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032752: Nov 1 16:05:24.746: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.13:57940 to 82.192.87.51:80
032753: Nov 1 16:05:24.826: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.239.208.199(27923) -> 198.80.94.50(42356), 1 packet
032754: Nov 1 16:05:26.022: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.253.198.199(10682) -> 198.80.94.50(42356), 1 packet
032755: Nov 1 16:05:27.082: %SEC-6-IPACCESSLOGP: list 106 denied udp 88.244.252.201(24509) -> 198.80.94.50(42356), 1 packet
032756: Nov 1 16:05:28.222: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.234.120.6(19880) -> 198.80.94.50(42356), 1 packet
032757: Nov 1 16:05:30.214: %SEC-6-IPACCESSLOGP: list 106 denied udp 70.180.161.234(29052) -> 198.80.94.50(42356), 1 packet
032758: Nov 1 16:05:30.666: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1567644149 1500 bytes is out-of-order; expected seq:1567619533. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032759: Nov 1 16:05:32.254: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.121.198.96(32215) -> 198.80.94.50(42356), 1 packet
032760: Nov 1 16:05:33.262: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.230.7.164(10058) -> 198.80.94.50(42356), 1 packet
032761: Nov 1 16:05:34.730: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.1.51.160(48233) -> 198.80.94.50(42356), 1 packet
032762: Nov 1 16:05:36.018: %SEC-6-IPACCESSLOGP: list 106 denied udp 88.242.175.195(18999) -> 198.80.94.50(42356), 1 packet
032763: Nov 1 16:05:36.526: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2437363651 1500 bytes is out-of-order; expected seq:2437339035. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032764: Nov 1 16:05:37.270: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.22.17.88(58034) -> 198.80.94.50(42356), 1 packet
032765: Nov 1 16:05:38.518: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.28.242.78(15813) -> 198.80.94.50(42356), 1 packet
032766: Nov 1 16:05:39.630: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.47.129.187(7390) -> 198.80.94.50(42356), 1 packet
032767: Nov 1 16:05:41.054: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.176.68.130(10475) -> 198.80.94.50(42356), 1 packet
032768: Nov 1 16:05:42.374: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 175.41.1.14 -> 198.80.94.50 (8/0), 1 packet
032769: Nov 1 16:05:42.666: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2438142675 1500 bytes is out-of-order; expected seq:2438118059. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032770: Nov 1 16:05:43.654: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.24.225.118(49426) -> 198.80.94.50(42356), 1 packet
032771: Nov 1 16:05:45.338: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1925378811 1470 bytes is out-of-order; expected seq:1925351641. Reason: TCP reassembly queue overflow - session 192.168.0.3:3597 to 74.125.65.102:80
032772: Nov 1 16:05:45.858: %SEC-6-IPACCESSLOGP: list 106 denied udp 84.125.59.162(39479) -> 198.80.94.50(42356), 1 packet
032773: Nov 1 16:05:47.090: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.155.24.45(18095) -> 198.80.94.50(42356), 1 packet
032774: Nov 1 16:05:47.694: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2438656715 1500 bytes is out-of-order; expected seq:2438632099. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032775: Nov 1 16:05:47.846: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032776: Nov 1 16:05:47.990: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032777: Nov 1 16:05:47.994: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032778: Nov 1 16:05:48.034: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032779: Nov 1 16:05:48.038: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032780: Nov 1 16:05:48.038: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032781: Nov 1 16:05:48.142: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032782: Nov 1 16:05:48.154: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032783: Nov 1 16:05:48.154: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032784: Nov 1 16:05:48.210: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032785: Nov 1 16:05:48.210: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032786: Nov 1 16:05:48.210: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032787: Nov 1 16:05:48.374: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032788: Nov 1 16:05:48.374: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032789: Nov 1 16:05:48.374: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032790: Nov 1 16:05:48.638: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032791: Nov 1 16:05:48.794: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032792: Nov 1 16:05:48.854: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032793: Nov 1 16:05:49.098: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032794: Nov 1 16:05:49.098: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032795: Nov 1 16:05:49.102: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032796: Nov 1 16:05:49.302: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032797: Nov 1 16:05:49.434: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 122.224.176.17 -> 198.80.94.50 (8/0), 1 packet
032798: Nov 1 16:05:49.550: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032799: Nov 1 16:05:49.602: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.4.36:58577 to 174.121.181.162:80
032800: Nov 1 16:05:50.390: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2438972379 1500 bytes is out-of-order; expected seq:2438941971. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032801: Nov 1 16:05:50.958: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.142.81.167(4132) -> 198.80.94.50(42356), 1 packet
032802: Nov 1 16:05:52.410: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.254.124.187(10027) -> 198.80.94.50(42356), 1 packet
032803: Nov 1 16:05:53.806: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.158.176.72(59785) -> 198.80.94.50(42356), 1 packet
032804: Nov 1 16:05:55.274: %FW-6-DROP_PKT: Dropping Other session 69.171.227.41:443 192.168.4.13:57981 due to Stray Segment with ip ident 0 tcpflags 0x5004 seq.no 572796475 ack 0
032805: Nov 1 16:05:55.446: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.35.186.155(24207) -> 198.80.94.50(42356), 1 packet
032806: Nov 1 16:05:56.346: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2439541443 1500 bytes is out-of-order; expected seq:2439502347. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032807: Nov 1 16:05:56.770: %SEC-6-IPACCESSLOGP: list 106 denied udp 72.28.57.65(5115) -> 198.80.94.50(42356), 1 packet
032808: Nov 1 16:05:58.758: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.41.63.205(18729) -> 198.80.94.50(42356), 1 packet
032809: Nov 1 16:06:00.074: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2440417483 1500 bytes is out-of-order; expected seq:2440388523. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032810: Nov 1 16:06:00.098: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.15.226.82(21546) -> 198.80.94.50(42356), 1 packet
032811: Nov 1 16:06:01.374: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.84.102.74(21267) -> 198.80.94.50(42356), 1 packet
032812: Nov 1 16:06:02.690: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 61.110.248.204 -> 198.80.94.50 (8/0), 1 packet
032813: Nov 1 16:06:03.970: %SEC-6-IPACCESSLOGP: list 106 denied udp 99.91.139.122(41417) -> 198.80.94.50(42356), 1 packet
032814: Nov 1 16:06:05.662: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.2.253.209(61178) -> 198.80.94.50(47042), 1 packet
032815: Nov 1 16:06:05.810: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2440986547 1500 bytes is out-of-order; expected seq:2440959035. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032816: Nov 1 16:06:07.142: %SEC-6-IPACCESSLOGP: list 106 denied udp 177.24.10.18(27160) -> 198.80.94.50(42356), 1 packet
032817: Nov 1 16:06:08.270: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.56.145.147(20279) -> 198.80.94.50(42356), 1 packet
032818: Nov 1 16:06:09.470: %SEC-6-IPACCESSLOGP: list 106 denied udp 90.173.195.143(45354) -> 198.80.94.50(42356), 1 packet
032819: Nov 1 16:06:12.486: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 113.204.249.7 -> 198.80.94.50 (8/0), 1 packet
032820: Nov 1 16:06:12.870: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1570936901 1500 bytes is out-of-order; expected seq:1570912285. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032821: Nov 1 16:06:13.450: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 85 packets
032822: Nov 1 16:06:13.990: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.61.33.181(24162) -> 198.80.94.50(42356), 1 packet
032823: Nov 1 16:06:16.394: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1571035365 1500 bytes is out-of-order; expected seq:1571010749. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032824: Nov 1 16:06:16.534: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.120.57.75(64949) -> 198.80.94.50(42356), 1 packet
032825: Nov 1 16:06:17.578: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.46.243.57(19498) -> 198.80.94.50(42356), 1 packet
032826: Nov 1 16:06:19.194: %SEC-6-IPACCESSLOGP: list 106 denied udp 87.111.72.60(49399) -> 198.80.94.50(42356), 1 packet
032827: Nov 1 16:06:19.558: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2444280747 1500 bytes is out-of-order; expected seq:2444251787. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032828: Nov 1 16:06:20.226: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.30.129.143(25090) -> 198.80.94.50(42356), 1 packet
032829: Nov 1 16:06:21.494: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.176.152.190(23830) -> 198.80.94.50(42356), 1 packet
032830: Nov 1 16:06:22.486: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2444832435 1500 bytes is out-of-order; expected seq:2444796235. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032831: Nov 1 16:06:22.706: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 174.35.82.9 -> 198.80.94.50 (8/0), 1 packet
032832: Nov 1 16:06:23.974: %SEC-6-IPACCESSLOGP: list 106 denied tcp 190.112.94.104(50840) -> 198.80.94.50(52520), 1 packet
032833: Nov 1 16:06:26.510: %FW-6-DROP_PKT: Dropping Other session 198.80.94.50:57974 200.123.198.202:443 due to Stray Segment with ip ident 58627 tcpflags 0x5004 seq.no 3870296674 ack 0
032834: Nov 1 16:06:27.626: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 62.64.17.196 -> 198.80.94.50 (8/0), 1 packet
032835: Nov 1 16:06:29.474: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.232.86.188(4210) -> 198.80.94.50(42356), 1 packet
032836: Nov 1 16:06:32.026: %SEC-6-IPACCESSLOGP: list 106 denied udp 177.65.17.227(38835) -> 198.80.94.50(42356), 1 packet
032837: Nov 1 16:06:33.034: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 95.128.60.133 -> 198.80.94.50 (8/0), 1 packet
032838: Nov 1 16:06:34.706: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.162.207.230(42030) -> 198.80.94.50(42356), 1 packet
032839: Nov 1 16:06:37.258: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2447043531 1500 bytes is out-of-order; expected seq:2447018915. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032840: Nov 1 16:06:37.662: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.206.90.244(10453) -> 198.80.94.50(42356), 1 packet
032841: Nov 1 16:06:39.402: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1572240101 1500 bytes is out-of-order; expected seq:1572215485. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032842: Nov 1 16:06:40.814: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.148.152.88(12565) -> 198.80.94.50(42356), 1 packet
032843: Nov 1 16:06:45.082: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.50.63.219(62021) -> 198.80.94.50(42356), 1 packet
032844: Nov 1 16:06:46.026: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.120:58960 to 216.14.113.166:80
032845: Nov 1 16:06:46.026: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.120:58960 to 216.14.113.166:80
032846: Nov 1 16:06:46.546: %SEC-6-IPACCESSLOGP: list 106 denied udp 69.142.239.199(34776) -> 198.80.94.50(42356), 1 packet
032847: Nov 1 16:06:48.230: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2449337163 1500 bytes is out-of-order; expected seq:2449312547. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032848: Nov 1 16:06:50.202: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:4225025941 1500 bytes is out-of-order; expected seq:4224992361. Reason: TCP reassembly queue overflow - session 192.168.0.120:59082 to 69.27.33.66:80
032849: Nov 1 16:06:51.726: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.228.217.192(12553) -> 198.80.94.50(42356), 1 packet
032850: Nov 1 16:06:53.946: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.255.211.145(10045) -> 198.80.94.50(42356), 1 packet
032851: Nov 1 16:06:56.850: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.226.57.80(10109) -> 198.80.94.50(42356), 1 packet
032852: Nov 1 16:06:57.714: %FW-6-DROP_PKT: Dropping http session 77.91.205.166:80 192.168.4.20:46828 due to Stray Segment with ip ident 4798 tcpflags 0x8018 seq.no 3862325123 ack 2747915049
032853: Nov 1 16:06:58.178: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.176.35.130(38108) -> 198.80.94.50(42356), 1 packet
032854: Nov 1 16:06:59.618: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.59.62.220(24088) -> 198.80.94.50(42356), 1 packet
032855: Nov 1 16:07:01.090: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.170.203.155(15565) -> 198.80.94.50(42356), 1 packet
032856: Nov 1 16:07:01.238: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.43:51202 to 189.90.111.254:80
032857: Nov 1 16:07:02.298: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 175.41.5.37 -> 198.80.94.50 (8/0), 1 packet
032858: Nov 1 16:07:02.510: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2450618643 1500 bytes is out-of-order; expected seq:2450594027. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032859: Nov 1 16:07:04.018: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.116.209.10(6794) -> 198.80.94.50(42356), 1 packet
032860: Nov 1 16:07:07.826: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 46.232.207.5 -> 198.80.94.50 (8/0), 1 packet
032861: Nov 1 16:07:10.546: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2451936323 1500 bytes is out-of-order; expected seq:2451904467. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032862: Nov 1 16:07:10.770: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.11.8.206(21812) -> 198.80.94.50(42356), 1 packet
032863: Nov 1 16:07:11.806: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.133.167.17(48217) -> 198.80.94.50(42356), 1 packet
032864: Nov 1 16:07:12.854: %SEC-6-IPACCESSLOGP: list 106 denied udp 177.54.7.64(33323) -> 198.80.94.50(32327), 1 packet
032865: Nov 1 16:07:13.450: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 65 packets
032866: Nov 1 16:07:13.614: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52894) -- responder (65.55.64.254:80)
032867: Nov 1 16:07:13.626: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52895) -- responder (65.55.64.254:80)
032868: Nov 1 16:07:13.762: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52894 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032869: Nov 1 16:07:13.762: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52894) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032870: Nov 1 16:07:13.906: %SEC-6-IPACCESSLOGP: list 106 denied tcp 65.55.64.254(80) -> 198.80.94.50(52894), 1 packet
032871: Nov 1 16:07:14.778: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52895 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032872: Nov 1 16:07:14.778: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52895) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032873: Nov 1 16:07:14.782: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52896) -- responder (65.55.64.254:80)
032874: Nov 1 16:07:14.922: %SEC-6-IPACCESSLOGP: list 106 denied tcp 65.55.64.254(80) -> 198.80.94.50(52895), 1 packet
032875: Nov 1 16:07:14.938: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52896 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032876: Nov 1 16:07:14.938: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52896) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032877: Nov 1 16:07:15.946: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1573511445 1500 bytes is out-of-order; expected seq:1573486829. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032878: Nov 1 16:07:16.714: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.199.37.70(45459) -> 198.80.94.50(42356), 1 packet
032879: Nov 1 16:07:16.950: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52897) -- responder (65.55.64.254:80)
032880: Nov 1 16:07:16.986: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2452653083 1500 bytes is out-of-order; expected seq:2452628467. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032881: Nov 1 16:07:17.102: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52897 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032882: Nov 1 16:07:17.102: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52897) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032883: Nov 1 16:07:18.006: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.87.1.119(61060) -> 198.80.94.50(14650), 1 packet
032884: Nov 1 16:07:19.610: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.79.55.241(5135) -> 198.80.94.50(42356), 1 packet
032885: Nov 1 16:07:20.146: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52898) -- responder (65.55.64.254:80)
032886: Nov 1 16:07:20.302: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52898 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032887: Nov 1 16:07:20.306: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52898) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032888: Nov 1 16:07:21.266: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 46.232.207.5 -> 198.80.94.50 (8/0), 1 packet
032889: Nov 1 16:07:21.826: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1573815525 1500 bytes is out-of-order; expected seq:1573790909. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032890: Nov 1 16:07:22.738: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.2.253.209(61178) -> 198.80.94.50(19219), 1 packet
032891: Nov 1 16:07:24.182: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.157.82.195(2347) -> 198.80.94.50(42356), 1 packet
032892: Nov 1 16:07:24.318: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52899) -- responder (65.55.64.254:80)
032893: Nov 1 16:07:24.474: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52899 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032894: Nov 1 16:07:24.474: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52899) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032895: Nov 1 16:07:25.314: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.81.172.52(26305) -> 198.80.94.50(42356), 1 packet
032896: Nov 1 16:07:26.906: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2454704899 1500 bytes is out-of-order; expected seq:2454678835. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032897: Nov 1 16:07:28.178: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.122.143.129(18905) -> 198.80.94.50(42356), 1 packet
032898: Nov 1 16:07:28.238: %FW-6-DROP_PKT: Dropping Other session 69.171.227.41:443 192.168.4.13:58092 due to Stray Segment with ip ident 0 tcpflags 0x5004 seq.no 1934396755 ack 0
032899: Nov 1 16:07:29.362: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.221.99.79(25435) -> 198.80.94.50(42356), 1 packet
032900: Nov 1 16:07:30.770: %SEC-6-IPACCESSLOGDP: list 106 denied icmp 62.64.16.9 -> 198.80.94.50 (8/0), 1 packet
032901: Nov 1 16:07:32.174: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.10.2.29(19249) -> 198.80.94.50(42356), 1 packet
032902: Nov 1 16:07:32.486: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2455405731 1500 bytes is out-of-order; expected seq:2455375323. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032903: Nov 1 16:07:33.934: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.74.153.197(15750) -> 198.80.94.50(42356), 1 packet
032904: Nov 1 16:07:34.178: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2455576595 1500 bytes is out-of-order; expected seq:2455551979. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032905: Nov 1 16:07:35.318: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.230.196.110(44987) -> 198.80.94.50(42356), 1 packet
032906: Nov 1 16:07:36.538: %SEC-6-IPACCESSLOGP: list 106 denied udp 72.213.42.37(44705) -> 198.80.94.50(42356), 1 packet
032907: Nov 1 16:07:37.658: %SEC-6-IPACCESSLOGP: list 106 denied udp 81.184.240.167(14303) -> 198.80.94.50(42356), 1 packet
032908: Nov 1 16:07:37.878: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1574388933 1500 bytes is out-of-order; expected seq:1574364317. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032909: Nov 1 16:07:39.038: %SEC-6-IPACCESSLOGP: list 106 denied udp 99.95.40.117(10079) -> 198.80.94.50(42356), 1 packet
032910: Nov 1 16:07:40.214: %SEC-6-IPACCESSLOGP: list 106 denied udp 78.189.185.225(27614) -> 198.80.94.50(42356), 1 packet
032911: Nov 1 16:07:41.514: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2456609019 1500 bytes is out-of-order; expected seq:2456582955. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032912: Nov 1 16:07:42.098: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.141.220.186(12410) -> 198.80.94.50(42356), 1 packet
032913: Nov 1 16:07:43.894: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.115.52.176(29059) -> 198.80.94.50(57110), 1 packet
032914: Nov 1 16:07:45.558: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.173.169.208(9130) -> 198.80.94.50(42356), 1 packet
032915: Nov 1 16:07:48.046: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2457296819 1500 bytes is out-of-order; expected seq:2457269307. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032916: Nov 1 16:07:49.106: %SEC-6-IPACCESSLOGP: list 106 denied udp 99.135.149.255(46494) -> 198.80.94.50(42356), 1 packet
032917: Nov 1 16:07:49.138: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1574947861 1500 bytes is out-of-order; expected seq:1574923245. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032918: Nov 1 16:07:50.394: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1575028949 1500 bytes is out-of-order; expected seq:1575004333. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032919: Nov 1 16:07:50.402: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.134.1.137(28155) -> 198.80.94.50(42356), 1 packet
032920: Nov 1 16:07:52.290: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.68.147.12(11030) -> 198.80.94.50(42356), 1 packet
032921: Nov 1 16:07:54.570: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.79.134.247(3531) -> 198.80.94.50(42356), 1 packet
032922: Nov 1 16:07:55.710: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2459082203 1500 bytes is out-of-order; expected seq:2459057587. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032923: Nov 1 16:08:02.622: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.193.244.69(31565) -> 198.80.94.50(42356), 1 packet
032924: Nov 1 16:08:03.686: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2460866139 1500 bytes is out-of-order; expected seq:2460837179. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032925: Nov 1 16:08:03.686: %FW-6-DROP_PKT: Dropping http session 208.88.227.133:80 192.168.4.13:57932 due to Out-Of-Order Segment with ip ident 45177 tcpflags 0x8010 seq.no 2460866139 ack 571551330
032926: Nov 1 16:08:04.094: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.242.185.114(4033) -> 198.80.94.50(42356), 1 packet
032927: Nov 1 16:08:05.706: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.173.253.106(3901) -> 198.80.94.50(42356), 1 packet
032928: Nov 1 16:08:06.818: %SEC-6-IPACCESSLOGP: list 106 denied udp 69.234.99.139(35069) -> 198.80.94.50(42356), 1 packet
032929: Nov 1 16:08:08.390: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.63.105.30(48671) -> 198.80.94.50(42356), 1 packet
032930: Nov 1 16:08:09.726: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.92.44.31(39654) -> 198.80.94.50(42356), 1 packet
032931: Nov 1 16:08:11.062: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1575880373 1500 bytes is out-of-order; expected seq:1575847069. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032932: Nov 1 16:08:11.502: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.33.82.102(1024) -> 198.80.94.50(14650), 1 packet
032933: Nov 1 16:08:12.946: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.14.161.148(9281) -> 198.80.94.50(42356), 1 packet
032934: Nov 1 16:08:13.010: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1575993317 1500 bytes is out-of-order; expected seq:1575968701. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032935: Nov 1 16:08:13.450: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 102 packets
032936: Nov 1 16:08:14.830: %SEC-6-IPACCESSLOGP: list 106 denied udp 200.8.141.60(25678) -> 198.80.94.50(42356), 1 packet
032937: Nov 1 16:08:16.678: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.209.226.111(35633) -> 198.80.94.50(42356), 1 packet
032938: Nov 1 16:08:18.010: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.24.240.137(13040) -> 198.80.94.50(42356), 1 packet
032939: Nov 1 16:08:19.310: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.79.27.81(34719) -> 198.80.94.50(42356), 1 packet
032940: Nov 1 16:08:20.878: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2463440683 1500 bytes is out-of-order; expected seq:2463414619. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032941: Nov 1 16:08:21.466: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.142.156.209(10050) -> 198.80.94.50(42356), 1 packet
032942: Nov 1 16:08:22.606: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.36.107.243(10402) -> 198.80.94.50(42356), 1 packet
032943: Nov 1 16:08:23.350: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1576517493 1500 bytes is out-of-order; expected seq:1576492877. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032944: Nov 1 16:08:23.858: %SEC-6-IPACCESSLOGP: list 106 denied udp 75.74.98.78(35772) -> 198.80.94.50(42356), 1 packet
032945: Nov 1 16:08:25.258: %SEC-6-IPACCESSLOGP: list 106 denied udp 90.168.215.70(35844) -> 198.80.94.50(42356), 1 packet
032946: Nov 1 16:08:27.098: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2463974995 1500 bytes is out-of-order; expected seq:2463948931. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032947: Nov 1 16:08:28.546: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.34.99.21(12592) -> 198.80.94.50(42356), 1 packet
032948: Nov 1 16:08:29.962: %SEC-6-IPACCESSLOGP: list 106 denied tcp 66.220.151.72(80) -> 198.80.94.50(50399), 1 packet
032949: Nov 1 16:08:31.242: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.14.40.107(29281) -> 198.80.94.50(42356), 1 packet
032950: Nov 1 16:08:32.286: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.21.206.49(21503) -> 198.80.94.50(42356), 1 packet
032951: Nov 1 16:08:32.486: %APPFW-4-HTTP_STRICT_PROTOCOL: Sig:15 HTTP protocol violation detected - HTTP Protocol not detected from 192.168.0.29:54180 to 184.168.91.202:80
032952: Nov 1 16:08:32.990: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1576989541 1500 bytes is out-of-order; expected seq:1576957685. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032953: Nov 1 16:08:33.702: %FW-6-DROP_PKT: Dropping Other session 69.171.227.41:443 192.168.4.13:58111 due to Stray Segment with ip ident 0 tcpflags 0x5004 seq.no 3055033381 ack 0
032954: Nov 1 16:08:34.386: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.87.1.119(19973) -> 198.80.94.50(14650), 1 packet
032955: Nov 1 16:08:35.314: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2464782979 1500 bytes is out-of-order; expected seq:2464758363. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032956: Nov 1 16:08:37.594: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2465055203 1500 bytes is out-of-order; expected seq:2465030587. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032957: Nov 1 16:08:38.806: %SEC-6-IPACCESSLOGP: list 106 denied udp 181.0.135.176(21182) -> 198.80.94.50(42356), 1 packet
032958: Nov 1 16:08:42.058: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.41.179.50(21520) -> 198.80.94.50(42356), 1 packet
032959: Nov 1 16:08:43.958: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.249.27.241(28248) -> 198.80.94.50(42356), 1 packet
032960: Nov 1 16:08:45.890: %SEC-6-IPACCESSLOGP: list 106 denied udp 66.220.149.232(49708) -> 198.80.94.50(53), 1 packet
032961: Nov 1 16:08:46.722: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2467250371 1500 bytes is out-of-order; expected seq:2467222859. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032962: Nov 1 16:08:46.914: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.30.131.206(11629) -> 198.80.94.50(42356), 1 packet
032963: Nov 1 16:08:47.974: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.27.155.64(10092) -> 198.80.94.50(42356), 1 packet
032964: Nov 1 16:08:48.354: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1578375277 1500 bytes is out-of-order; expected seq:1578350661. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032965: Nov 1 16:08:50.326: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.31.178.132(16718) -> 198.80.94.50(42356), 1 packet
032966: Nov 1 16:08:52.134: %SEC-6-IPACCESSLOGP: list 106 denied udp 88.29.43.81(7124) -> 198.80.94.50(42356), 1 packet
032967: Nov 1 16:08:54.882: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.36.222.15(4248) -> 198.80.94.50(42356), 1 packet
032968: Nov 1 16:08:57.490: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2469891523 1500 bytes is out-of-order; expected seq:2469866907. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032969: Nov 1 16:08:58.934: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.160.16.208(10102) -> 198.80.94.50(42356), 1 packet
032970: Nov 1 16:08:59.986: %SEC-6-IPACCESSLOGP: list 106 denied udp 82.130.205.51(24381) -> 198.80.94.50(42356), 1 packet
032971: Nov 1 16:09:01.830: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.81.111.210(9902) -> 198.80.94.50(42356), 1 packet
032972: Nov 1 16:09:03.906: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2470433075 1500 bytes is out-of-order; expected seq:2470408459. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032973: Nov 1 16:09:03.906: %FW-6-DROP_PKT: Dropping http session 208.88.227.133:80 192.168.4.13:57932 due to Out-Of-Order Segment with ip ident 52019 tcpflags 0x8010 seq.no 2470433075 ack 571551330
032974: Nov 1 16:09:04.454: %SEC-6-IPACCESSLOGP: list 106 denied udp 98.211.92.14(49612) -> 198.80.94.50(42356), 1 packet
032975: Nov 1 16:09:06.518: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.35.12.149(10180) -> 198.80.94.50(42356), 1 packet
032976: Nov 1 16:09:07.598: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.109.163.26(10001) -> 198.80.94.50(42356), 1 packet
032977: Nov 1 16:09:09.962: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2470960147 1500 bytes is out-of-order; expected seq:2470934083. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032978: Nov 1 16:09:10.494: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.21.198.178(19060) -> 198.80.94.50(42356), 1 packet
032979: Nov 1 16:09:13.450: %SEC-6-IPACCESSLOGRL: access-list logging rate-limited or missed 77 packets
032980: Nov 1 16:09:14.162: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.202.144.200(38705) -> 198.80.94.50(42356), 1 packet
032981: Nov 1 16:09:16.754: %SEC-6-IPACCESSLOGP: list 106 denied udp 99.100.159.65(17504) -> 198.80.94.50(42356), 1 packet
032982: Nov 1 16:09:18.118: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.25.74.35(10009) -> 198.80.94.50(42356), 1 packet
032983: Nov 1 16:09:20.750: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.126.69.44(57483) -> 198.80.94.50(42356), 1 packet
032984: Nov 1 16:09:21.814: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.73.6.181(3151) -> 198.80.94.50(42356), 1 packet
032985: Nov 1 16:09:23.030: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.59.72.117(21518) -> 198.80.94.50(42356), 1 packet
032986: Nov 1 16:09:23.294: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2472790419 1500 bytes is out-of-order; expected seq:2472764355. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
032987: Nov 1 16:09:25.018: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.81.45.222(5483) -> 198.80.94.50(42356), 1 packet
032988: Nov 1 16:09:25.366: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52912) -- responder (65.55.64.254:80)
032989: Nov 1 16:09:25.530: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52912 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032990: Nov 1 16:09:25.530: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52912) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032991: Nov 1 16:09:26.262: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.17.12.94(3055) -> 198.80.94.50(42356), 1 packet
032992: Nov 1 16:09:26.566: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52913) -- responder (65.55.64.254:80)
032993: Nov 1 16:09:26.722: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52913 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
032994: Nov 1 16:09:26.722: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52913) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
032995: Nov 1 16:09:26.938: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1580760133 1500 bytes is out-of-order; expected seq:1580735517. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
032996: Nov 1 16:09:27.282: %SEC-6-IPACCESSLOGP: list 106 denied udp 186.89.208.130(2024) -> 198.80.94.50(42356), 1 packet
032997: Nov 1 16:09:28.314: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.112.78.136(10026) -> 198.80.94.50(42356), 1 packet
032998: Nov 1 16:09:28.738: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52914) -- responder (65.55.64.254:80)
032999: Nov 1 16:09:28.886: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52914 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
033000: Nov 1 16:09:28.886: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52914) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
033001: Nov 1 16:09:29.414: %SEC-6-IPACCESSLOGP: list 106 denied udp 190.135.185.73(28572) -> 198.80.94.50(42356), 1 packet
033002: Nov 1 16:09:30.370: %FW-4-TCP_OoO_SEG: Deleting session as expected TCP segment with seq:2262352238 has not arrived even after 25 seconds - session 192.168.0.29:54176 to 184.168.91.202:80
033003: Nov 1 16:09:31.234: %SEC-6-IPACCESSLOGP: list 106 denied udp 201.87.1.119(46290) -> 198.80.94.50(32327), 1 packet
033004: Nov 1 16:09:31.478: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2473709899 1500 bytes is out-of-order; expected seq:2473683835. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
033005: Nov 1 16:09:31.898: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52916) -- responder (65.55.64.254:80)
033006: Nov 1 16:09:32.050: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52916 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
033007: Nov 1 16:09:32.050: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52916) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
033008: Nov 1 16:09:32.270: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.10.157.61(10018) -> 198.80.94.50(14650), 1 packet
033009: Nov 1 16:09:33.818: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:2473915515 1500 bytes is out-of-order; expected seq:2473889451. Reason: TCP reassembly queue overflow - session 192.168.4.13:57932 to 208.88.227.133:80
033010: Nov 1 16:09:34.002: %FW-6-DROP_PKT: Dropping http session 95.211.91.52:80 192.168.4.13:57934 due to Out-Of-Order Segment with ip ident 2028 tcpflags 0x8010 seq.no 1581209013 ack 3420267696
033011: Nov 1 16:09:34.062: %SEC-6-IPACCESSLOGP: list 106 denied tcp 190.236.87.215(50443) -> 198.80.94.50(42671), 1 packet
033012: Nov 1 16:09:34.902: %FW-4-TCP_OoO_SEG: Dropping TCP Segment: seq:1581239421 1500 bytes is out-of-order; expected seq:1581211909. Reason: TCP reassembly queue overflow - session 192.168.4.13:57934 to 95.211.91.52:80
033013: Nov 1 16:09:35.550: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.248.247.217(12645) -> 198.80.94.50(42356), 1 packet
033014: Nov 1 16:09:36.074: %FW-6-SESS_AUDIT_TRAIL_START: Start im-msn session: initiator (192.168.4.14:52917) -- responder (65.55.64.254:80)
033015: Nov 1 16:09:36.278: %APPFW-6-IM_MSN_CLIENT_VERSION: im-msn 192.168.4.14:52917 attempting to establish connection with msn server 65.55.64.254:80 using an unsupported version of the client
033016: Nov 1 16:09:36.278: %FW-6-SESS_AUDIT_TRAIL: Stop im-msn session: initiator (192.168.4.14:52917) sent 2432 bytes -- responder (65.55.64.254:80) sent 0 bytes
033017: Nov 1 16:09:37.246: %APPFW-4-HTTP_DEOBFUSCATE: Sig:14 Deobfuscation signature detected - HTTP deobfuscation detected IDS evasion technique from 192.168.4.16:64571 to 72.167.239.239:80
033018: Nov 1 16:09:37.586: %SEC-6-IPACCESSLOGP: list 106 denied udp 187.39.22.18(7996) -> 198.80.94.50(42356), 1 packet
033019: Nov 1 16:09:39.206: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.168.124.251(10021) -> 198.80.94.50(42356), 1 packet
033020: Nov 1 16:09:40.282: %SEC-6-IPACCESSLOGP: list 106 denied udp 189.102.110.5(11407) -> 198.80.94.50(42356), 1 packet
_____________________________________________________________________________________
The IPs and passwd are fake.
11-02-2011 06:26 AM
via vty use commands
term mon
debug ccsip all
and stop it with
undebug all
Regards.
11-03-2011 12:22 PM
Ok, I did these commands via vty, but I cant get any results, how I can get the responses?
11-05-2011 06:48 AM
If the SIP debug output is empty, the incoming SIP messages are dropped before to reach SIP stack. Check the firewall policies and ACL rules.
If you dont have an external sip provider, I suppose that failed calls are between local phone (xlite and SPA). Right? What are ip addresses of phones? Can you find these adresses in firewall logging?
What is the phone status? registered or not registered?
Regards.
