04-27-2011 08:58 AM - last edited on 03-25-2019 10:56 PM by ciscomoderator
I have seen this about 5 times or so now. Every once in a while I open CCA 3.01 my system and it crashes my phone system. I have software pack 8.1.0 and the IOS image is UC500-advipservicesk9-mz.151-2.T2 adn CME version 8.0.3. Locale is US English.
All I do is open CCA, enter username and password for the Uc540 phone system and bang... all the phones stop getting power, all the data on the network stops. The UC500 is nonresponsive. I can not PING it nor communicate with it. All the power is on the BOX and it has activity lights etc.
has anyone else experienced this? I have to pull the power on the system and then it comes back up and I can open CCA and get into the Uc540 just fine. Then a few weeks or so will go by and I will open CCA a half a dozen times with no issues... then one random day *bang*..again it goes down. Today it happened... hence this post..
The first time I upgraded to 3.0.1 this happened to me. It never happened before that.. since I was upgrading CCA to 3.0.1 I was going in often because I wanted to see the new features and message around with some T.37 Fax things... and it happened 3 times within the week... I must have went in 10 or so times... anyway... any feedback would be appreciated.
John Nikolatos
04-27-2011 04:53 PM
Hi John,
What would be great is if you could use a console cable into the system and then see what come sup on the terminal monitor messages when this happens.
I only suggest term mon because I would not even know where to begin with what debug to run, but if something comes up on the terminal monitor then it may indicate where to start.
Is this a possible option?
Cheers,
David.
