CCA authentication failed
Turbo727
Level 2
Level 2
Having a very strange issue with UC560. This is a brand new box with default factory configuration. I was trying to log onto to CCA, but I kept getting error message saying failed to authentication using TELNET. Telnet access is required for access to voice configuration.
the thing is I can telnet to the router without any issue, I can open the router's http page. just CCA keeps saying authentication failed.
username and password are default. cisco/cisco, enable: cisco. CUE cisco/cisco.
please help.
mzaccone
Level 3
Level 3
Are you sure it's default?  Have you tried copying the default cfg file from a recent software pack to the flash and then the startup config and reloading to make sure that it's default?
