Welcome to the Cisco Small Business Community
Have a question? Click on a topic board below to get started in the community.
Get the latest news in this issue of the Cisco Small Business Monthly Newsletter
8222
Highlighted
Beginner
Change Lan IP Network
how can i change the ip Lan network with CCA 2.0?
26 REPLIES 26
Highlighted
Oh I see so yur configuring the ip on the vlan interface not the fast ethernet port. Would this still work going out to the isp if the fast ethernet port is tagging itself with vlan x frames?
Also how would this work out in relation to a dual wan setup with sla monitoring? My concern is having two interfaces that go to both of my isp's which are on NAT outside. this would load balance traffic, which I don't want. I want a failover scenario using ip sla monitoring.
thanks Marcos
Highlighted
The switchport would still be an access port, so no tagging.
Take a look at an article I wrote a while back for ideas on how to configure redundancy vs. load balancing:
https://supportforums.cisco.com/docs/DOC-9423
Glad to help! Let me know.
Marcos
Highlighted
Funny, I thought you would mention that article. my questions are stemming from reading through your suggesstions and seeing what would fit in my scenario. Yes you address the ip sla monitoring which is great and I will use that. My other main concern is how the uc520 will handle a dual "NAT outside" situation on both interfaces. If I apply nat outside to each interface and make my nat overload statements for each interface along with all the sla configuration, how will the uc520 only leave one link "active" and working? I know that the sla monitoring will keep only one default gateway active but won't it still try to nat out the other "inactive" interface causing problems?
thanks
Highlighted
Routing would fix this. I mean, a routing decision (outbound interface) is made prior to NAT'ing. Static route preference would be the way to go, or policy based routing, which is a little more complicated. Try to experiment with this and let me know if you need help.
Highlighted
Hmmm... routing decision before the nat occurs is good. With static route preference do you mean administrative distance? never done policy based routing. I thought with ip sla this is being done in terms of removing the routes. not sure where to go with this one.
ip route 0.0.0.0 0.0.0.0 [ISP 1 GATEWAY] 1
ip route 0.0.0.0 0.0.0.0 [ISP 1 GATEWAY] 10
Highlighted
Give the primary route a lower administrative disctane than teh backup route. Remember to use SLA tracking to detect when the first interface becomes unavailable.
Marcos
Highlighted
that is how I planned on doing it but I didn't know that would affect the nat choice and figured the uc520 would still try to nat on both interfaces. so does the natting occur before the route selection and the natting checks to see which route is active?
Highlighted
No. The router decides on which interface to put the packet for outbound transmission and then NAT kicks in.
Highlighted
so when it decides which interface it looks at the route with lowest AD in order to make that decision?
Highlighted
Well I implemented the following config and things work but users are saying that they will get disconnected and then reconnected at random times. When I checked the statistics it doesn't show that the ip sla is failing over. I'm wondering if it's a nat issue. what do you think or recommend?
interface FastEthernet0/0
description PRIMARY COX INTERFACE
ip address X.X.X.X 255.255.255.240
ip access-group 104 in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map mymap
interface FastEthernet0/1/0
description INTEGRA BACKUP T1 WAN
switchport access vlan 2
spanning-tree portfast
interface Vlan2
description INTEGRA BACKUP WAN
ip address X.X.X.X 255.255.255.248
ip nat outside
no ip virtual-reassembly
crypto map mymap
ip nat inside source route-map COX_PRIMARY interface FastEthernet0/0 overload
ip nat inside source route-map INTEGRA_BACKUP interface Vlan2 overload
route-map INTEGRA_BACKUP permit 10
match ip address 110
match interface Vlan2
route-map COX_PRIMARY permit 10
match interface FastEthernet0/0
ip sla 1
icmp-echo 8.8.8.8
timeout 500
threshold 2
frequency 30
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.8.8
timeout 500
threshold 2
frequency 30
ip sla schedule 2 life forever start-time now
track ip sla 1 reachability
track ip sla 2 reachability
ip route 0.0.0.0 0.0.0.0 ** COX PRIMARY GATEWAY ** track 1
ip route 0.0.0.0 0.0.0.0 ** INTEGRA BACKUP GATEWAY **  track 2 200
Highlighted
The "match interface" under the route-maps are not required. In fact, you can use just an "ip nat inside" statement and point it to acces list 110. Also, under "ip sla" I would track the reachability of the default gateway for that connected interface.
Marcos
Highlighted
So something like this is what you would do? Would this address my random internet drops?
Here is the article I followed prior to get the dual ISP NAT working
http://docwiki.cisco.com/wiki/NAT_failover_with_DUAL_ISP_on_a_router_Configuration_Example
ip nat outside
duplex auto
speed auto
crypto map mymap
interface Vlan2
ip nat outside
crypto map mymap
ip nat inside source list 110 interface FastEthernet0/0 overload
ip nat inside source list 110 interface Vlan2 overload
ip sla 1
icmp-echo ** COX PRIMARY GATEWAY **
timeout 500
threshold 2
frequency 30
ip sla 2
icmp-echo ** INTEGRA BACKUP GATEWAY **
timeout 500
threshold 2
frequency 30
