Change tone when calling wrong number
Hello!
Anyone know how to change the fast busy tone when calling wrong number?
And one more question!
When starting to call a number and you have to look for the rest of the number, th display on the phone turn back to default, is there a posibility to change that time?
regards
Svein
David Trad
Hi Svein,
I do not know if this is possible on the UC, as far as i am aware this is controlled by the carrier, it is their switching equipment that usually dictates this.
I believe this is under the telephony-service section, not sure where to find this in CCA but it is to do wit the digit input time out, by default this is set to 5 seconds, on the odd ocassions i get asked to push this out to 10 seconds when you have real fussy customers :)
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
