09-22-2009 05:52 PM - edited 03-21-2019 01:33 AM
When i setup the router, i assigned it the default ip of 192.168.10.1
However, i would like to change it to 192.168.1.1. How can i do this in the CCA or cli(specific steps please) ?
Can i change it under Routing-DHCP Server- and under DHCP Pools, modify the data vlan1 network, start and end ip addresses and default router?
Or is it to be changed elsewhere ?
Solved! Go to Solution.
09-22-2009 06:52 PM
Murtaza, please refer to this thread:
https://www.myciscocommunity.com/message/7933#7933
Notice that you will also have to delete the NAT service and then recreate it. Do not do this over the WAN or through VPN. Connect locally.
Marcos
09-23-2009 08:40 AM
Delete and recreate NAT at the end.
09-22-2009 06:52 PM
Marcos
09-23-2009 08:26 AM
Marcos,
in step 3, while changing the settings on the smartport, do i need to change it for all smartports except for the one i am connected to ?, example, if i am connected to 1/7, i should do it for all the rest?
And then in step7, i can connect to any other switch port (which was already configured in step 3) to open the CCA using the new vlan ip?
Thanks!
09-23-2009 08:33 AM
Yes to both questions. Good catch. Make sure you configure the port you were on only after you have connected your computer to the new VLAN.
Also, and I can't stress this enough, do not forget about deleting and recreating the NAT settings and the firewall config.
Marcos
09-23-2009 08:37 AM
Do i need to delete the NAT settings first or perform the NAT config in step 5 first? i am a little lost here.
09-23-2009 08:40 AM
09-23-2009 08:41 AM
at the end meaning... after i am connected to the new lan?
09-23-2009 08:43 AM
Yes
09-23-2009 08:35 AM
Also, there is a step for adding the NAT. Do i need to do anything over and above that step wrt NAT?
