Get the latest new and information the November issue of the Cisco Small Business Monthly Newsletter
2431
Highlighted
Changing lan ip address on the uc520
When i setup the router, i assigned it the default ip of 192.168.10.1
However, i would like to change it to 192.168.1.1. How can i do this in the CCA or cli(specific steps please) ?
Can i change it under Routing-DHCP Server- and under DHCP Pools, modify the data vlan1 network, start and end ip addresses and default router?
Or is it to be changed elsewhere ?
Everyone's tags (5)
2 ACCEPTED SOLUTIONS
Collaborator
Re: Changing lan ip address on the uc520
Murtaza, please refer to this thread:
https://www.myciscocommunity.com/message/7933#7933
Notice that you will also have to delete the NAT service and then recreate it. Do not do this over the WAN or through VPN. Connect locally.
Marcos
Collaborator
Delete and recreate NAT at the end.
8 REPLIES 8
Collaborator
Marcos
Marcos,
in step 3, while changing the settings on the smartport, do i need to change it for all smartports except for the one i am connected to ?, example, if i am connected to 1/7, i should do it for all the rest?
And then in step7, i can connect to any other switch port (which was already configured in step 3) to open the CCA using the new vlan ip?
Thanks!
Collaborator
Yes to both questions. Good catch. Make sure you configure the port you were on only after you have connected your computer to the new VLAN.
Also, and I can't stress this enough, do not forget about deleting and recreating the NAT settings and the firewall config.
Marcos
Do i need to delete the NAT settings first or perform the NAT config in step 5 first? i am a little lost here.
Collaborator
at the end meaning... after i am connected to the new lan?
Collaborator
Yes
Also, there is a step for adding the NAT. Do i need to do anything over and above that step wrt NAT?
