This is how my template is configured:
<flat-profile>
<!-- Reset the global configuration options, now we will reset per day instead of every second -->
<Resync_Periodic>86400</Resync_Periodic>
<Resync_On_Reset>Yes</Resync_On_Reset>
<Profile_Rule>{$provisioning_type}://{$provisioning_path}/spa$MA.xml</Profile_Rule>
<Resync_At__HHmm_ group="Provisioning/Configuration_Profile">23:59</Resync_At__HHmm_>
<!-- Line Registration Information -->
<Text_Logo group="Phone/General">LCI Education</Text_Logo>
<Station_Name group="Phone/General">{$station_name}</Station_Name>
<Voice_Mail_Number group="Phone/General">{$vmail|*97}</Voice_Mail_Number>
{line_loop}
<Display_Name_{$line}_ ua="na">{$displayname.line.1}</Display_Name_{$line}_>
<!-- If BLF then set this to the BLF -->
<Short_Name_{$line}_ ua="na">{$short_name}</Short_Name_{$line}_>
<User_ID_{$line}_ ua="na">{$ext}</User_ID_{$line}_>
<Password_{$line}_ ua="na">{$pass}</Password_{$line}_>
<!-- Below set to disabled for BLF -->
<Extension_{$line}_ group="Phone/Line_Key_{$line}">{$blf_ext_type}</Extension_{$line}_>
<!-- If BLF set to shared -->
<Share_Call_Appearance_{$line}_ group="Phone/Line_Key_{$line}">{$share_call_appearance|private}</Share_Call_Appearance_{$line}_>
<!-- this changes how the button works. If it's set when the phone isn't on blf then the button turns orange. so we probably need to remove this normally.-->
<Extended_Function_{$line}_ group="Phone/Line_Key_{$line}">{$extended_function}</Extended_Function_{$line}_>
<Dial_Plan_{$line}_ ua="na">{$dial_plan}</Dial_Plan_{$line}_>
<SIP_Port_{$line}_ group="Ext_{$line}/SIP_Settings">{$server.port.1}</SIP_Port_{$line}_>
<Proxy_{$line}_ group="Ext_{$line}/Proxy_and_Registration">{$server.ip.1}</Proxy_{$line}_>
{/line_loop}
<!-- Proxy and Registration -->
<Proxy_1_ ua="na">{$server.ip.1}</Proxy_1_>
<Primary_NTP_Server ua="na">{$network_time_server}</Primary_NTP_Server>
<Upgrade_Enable ua="ro">{$enable_upgrade}</Upgrade_Enable>
<Upgrade_Rule ua="ro">{$upgrade_path}</Upgrade_Rule>
<!-- User Proxy and Registration -->
<Use_Outbound_Proxy_1_ ua="na">No</Use_Outbound_Proxy_1_>
<Outbound_Proxy_1_ ua="na">{$server.ip.1}</Outbound_Proxy_1_>
<Register_Expires_1_ ua="ro">3600</Register_Expires_1_>
<Ans_Call_Without_Reg_1_ ua="na">No</Ans_Call_Without_Reg_1_>
<Use_DNS_SRV_1_ ua="rw">No</Use_DNS_SRV_1_>
<Proxy_Fallback_Intvl_1_ ua="ro">3600</Proxy_Fallback_Intvl_1_>
<Proxy_Redundancy_Method_1_ ua="ro">Normal</Proxy_Redundancy_Method_1_>
<Voice_Mail_Number ua="na">{$vmail|*97}</Voice_Mail_Number>
<Time_Zone ua="na">{$timezone}</Time_Zone>
<Time_Zone group="Regional/Miscellaneous">GMT-05:00</Time_Zone>
<!-- Admin -->
<Enable_Web_Server ua="na">yes</Enable_Web_Server>
<Web_Server_Port ua="na">80</Web_Server_Port>
<Enable_Web_Admin_Access ua="na">yes</Enable_Web_Admin_Access>
<Admin_Passwd ua="na">Youngsky10</Admin_Passwd>
<User_Password ua="na">{$user_password}</User_Password>
<Enable_CDP group="System/VLAN_Settings">{$enable_cdp|No}</Enable_CDP>
<!-- options: -->
<Daylight_Saving_Time_Rule ua="na">start=3/8/7/02:0:0;end=11/1/7/02:0:0;save=1</Daylight_Saving_Time_Rule>
<Daylight_Saving_Time_Enable group="Regional/Miscellaneous">No</Daylight_Saving_Time_Enable>
<Date_Format >{$date_format|month/day}</Date_Format>
<Call_Return_Code ua="na"> </Call_Return_Code>
<Blind_Transfer_Code > </Blind_Transfer_Code>
<Call_Back_Act_Code> </Call_Back_Act_Code>
<Call_Back_Deact_Code> </Call_Back_Deact_Code>
<Cfwd_All_Act_Code> </Cfwd_All_Act_Code>
<Cfwd_All_Deact_Code> </Cfwd_All_Deact_Code>
<Cfwd_Busy_Act_Code> </Cfwd_Busy_Act_Code>
<Cfwd_Busy_Deact_Code> </Cfwd_Busy_Deact_Code>
<Cfwd_No_Ans_Act_Code> </Cfwd_No_Ans_Act_Code>
<Cfwd_No_Ans_Deact_Code> </Cfwd_No_Ans_Deact_Code>
<CW_Act_Code> </CW_Act_Code>
<CW_Deact_Code> </CW_Deact_Code>
<CW_Per_Call_Act_Code> </CW_Per_Call_Act_Code>
<CW_Per_Call_Deact_Code> </CW_Per_Call_Deact_Code>
<Block_CID_Act_Code> </Block_CID_Act_Code>
<Block_CID_Deact_Code> </Block_CID_Deact_Code>
<Block_CID_Per_Call_Act_Code> </Block_CID_Per_Call_Act_Code>
<Block_CID_Per_Call_Deact_Code> </Block_CID_Per_Call_Deact_Code>
<Block_ANC_Act_Code> </Block_ANC_Act_Code>
<Block_ANC_Deact_Code> </Block_ANC_Deact_Code>
<DND_Act_Code> </DND_Act_Code>
<DND_Deact_Code> </DND_Deact_Code>
<Secure_All_Call_Act_Code> </Secure_All_Call_Act_Code>
<Secure_No_Call_Act_Code> </Secure_No_Call_Act_Code>
<Secure_One_Call_Act_Code> </Secure_One_Call_Act_Code>
<Secure_One_Call_Deact_Code> </Secure_One_Call_Deact_Code>
<Paging_Code ua="na">{$page_code}</Paging_Code>
<Call_Park_Code> </Call_Park_Code>
<Call_Pickup_Code> </Call_Pickup_Code>
<Call_UnPark_Code> </Call_UnPark_Code>
<Group_Call_Pickup_Code> </Group_Call_Pickup_Code>
<Media_Loopback_Code> </Media_Loopback_Code>
<Referral_Services_Codes> </Referral_Services_Codes>
<BMP_Picture_Download_URL group="Phone/General">tftp://192.168.60.51/lasalle_1b.bmp</BMP_Picture_Download_URL>
<Select_Logo group="Phone/General">BMP Picture</Select_Logo>
<Select_Background_Picture group="Phone/General">BMP Picture</Select_Background_Picture>
<Syslog_Server group="System/Optional_Network_Configuration">{$server.ip.1}</Syslog_Server>
<Debug_Level group="System/Optional_Network_Configuration">3</Debug_Level>
<Debug_Server group="System/Optional_Network_Configuration">{$server.ip.1}</Debug_Server>
<Speed_Dial_2 ua="rw">{$speed_dial_2}</Speed_Dial_2>
<Speed_Dial_3 ua="rw">{$speed_dial_3}</Speed_Dial_3>
<Speed_Dial_4 ua="rw">{$speed_dial_4}</Speed_Dial_4>
<Speed_Dial_5 ua="rw">{$speed_dial_5}</Speed_Dial_5>
<Speed_Dial_6 ua="rw">{$speed_dial_6}</Speed_Dial_6>
<Speed_Dial_7 ua="rw">{$speed_dial_7}</Speed_Dial_7>
<Speed_Dial_8 ua="rw">{$speed_dial_8}</Speed_Dial_8>
<Speed_Dial_9 ua="rw">{$speed_dial_9}</Speed_Dial_9>
<Subscribe_Expires group="Attendant_Console/General">1800</Subscribe_Expires>
<Subscribe_Retry_Interval group="Attendant_Console/General">30</Subscribe_Retry_Interval>
<Unit_1_Enable group="Attendant_Console/General">Yes</Unit_1_Enable>
<Subscribe_Delay group="Attendant_Console/General">1</Subscribe_Delay>
<Unit_2_Enable group="Attendant_Console/General">Yes</Unit_2_Enable>
<Server_Type group="Attendant_Console/General">Asterisk</Server_Type>
<Test_Mode_Enable group="Attendant_Console/General">No</Test_Mode_Enable>
<Attendant_Console_Call_Pickup_Code group="Attendant_Console/General">**#</Attendant_Console_Call_Pickup_Code>
<BLF_List_URI group="Attendant_Console/General"/>
<Application_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Serv_Subscribe_Failed_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Serv_Subscribing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<SNRM_Day_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<SNRM_Night_Mode_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Parking_Lot_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<Parking_Lot_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Idle_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Ringing_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Busy_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
<BLF_Held_LED group="Attendant_Console/Attendant_Key_LED_Pattern"/>
{loop_unit1}
<Unit_1_Key_{$number} group="Attendant_Console/Unit_1">{$data}</Unit_1_Key_{$number}>
{/loop_unit1}
{loop_unit2}
<Unit_2_Key_{$number} group="Attendant_Console/Unit_2">{$data}</Unit_2_Key_{$number}>
{/loop_unit2}
<!-- Ring tones and Cadences -->
<Ring1 group="Phone/Ring_Tone">{$ring1|n=Classic-1;w=3;c=1}</Ring1>
<Ring2 group="Phone/Ring_Tone">{$ring2|n=Classic-2;w=3;c=2}</Ring2>
<Ring3 group="Phone/Ring_Tone">{$ring3|n=Classic-3;w=3;c=3}</Ring3>
<Ring4 group="Phone/Ring_Tone">{$ring4|n=Classic-4;w=3;c=4}</Ring4>
<Ring5 group="Phone/Ring_Tone">{$ring5|n=Simple-1;w=2;c=1}</Ring5>
<Ring6 group="Phone/Ring_Tone">{$ring6|n=Simple-2;w=2;c=2}</Ring6>
<Ring7 group="Phone/Ring_Tone">{$ring7|n=Simple-3;w=2;c=3}</Ring7>
<Ring8 group="Phone/Ring_Tone">{$ring8|n=Simple-4;w=2;c=4}</Ring8>
<Ring9 group="Phone/Ring_Tone">{$ring9|n=Simple-5;w=2;c=5}</Ring9>
<Ring10 group="Phone/Ring_Tone">{$ring10|n=Office;w=4;c=1}</Ring10>
<Default_Ring__1__ group="Ext_1/Call_Feature_Settings">10</Default_Ring__1__>
<!-- LDAP Settings for Directory -->
<LDAP_Dir_Enable group="Phone/LDAP_Corporate_Directory_Search">{$ldap_enabled|No}</LDAP_Dir_Enable>
<LDAP_Corp_Dir_Name group="Phone/LDAP_Corporate_Directory_Search">{$ldap_name}</LDAP_Corp_Dir_Name>
<LDAP_Server group="Phone/LDAP_Corporate_Directory_Search">{$ldap_server}</LDAP_Server>
<LDAP_Auth_Method group="Phone/LDAP_Corporate_Directory_Search">Simple</LDAP_Auth_Method>
<LDAP_Client_DN group="Phone/LDAP_Corporate_Directory_Search">{$ldap_account}</LDAP_Client_DN>
<LDAP_Username group="Phone/LDAP_Corporate_Directory_Search">{$ldap_account}</LDAP_Username>
<LDAP_Password group="Phone/LDAP_Corporate_Directory_Search">{$ldap_password}</LDAP_Password>
<LDAP_Search_Base group="Phone/LDAP_Corporate_Directory_Search">{$ldap_base}</LDAP_Search_Base>
<LDAP_Last_Name_Filter group="Phone/LDAP_Corporate_Directory_Search">cn:(cn=*$VALUE*)</LDAP_Last_Name_Filter>
<LDAP_First_Name_Filter group="Phone/LDAP_Corporate_Directory_Search">cn:(cn=*$VALUE*)</LDAP_First_Name_Filter>
<LDAP_Search_Item_3 group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Item_3_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Search_Item_4 group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_item_4_Filter group="Phone/LDAP_Corporate_Directory_Search"/>
<LDAP_Display_Attrs group="Phone/LDAP_Corporate_Directory_Search">{$ldap_attrs|a=cn;a=sn;a=telephoneNumber,n=Phone,t=p;}</LDAP_Display_Attrs>
<LDAP_Number_Mapping group="Phone/LDAP_Corporate_Directory_Search">{$ldap_mapping}</LDAP_Number_Mapping>
<!-- Language -->
<Dictionary_Server_Script group="Regional/Miscellaneous">serv=tftp://192.168.60.51/;d0=English;x0=spa50x_30x_en_v756.xml;d1=French;x1=spa50x_30x_fr_v756.xml;</Dictionary_Server_Script>
<Language_Selection group="Regional/Miscellaneous">French</Language_Selection>
<Locale group="Regional/Miscellaneous">fr-CA</Locale>
</flat-profile>
