11-17-2019 02:12 AM
I recently updated my Cisco 7940 using firmware P003-8-12-00 for SIP including the SIPDefault.cnf file with correct firmware. But after that whenever the phone boots it looks for several files which are not available. Attached here. Also if I disconnect TFTP, it gives TFTP Timeout..
I cannot even install other version too. I tried hard reset using # and number sequence too.
Please guide where I am wrong.
My intention is to use the phone with Asterisk SIP.
11-17-2019 02:39 AM
11-17-2019 09:57 AM
It doesn't harm if unrelated files doesn't exist. But phone asks configuration files related to the SIP mode you wish to use (SIPdefault.cnf - SIP global configuration and SIP00270DBE0C7D,cnf - phone specific SIP configuration). At least one of them should exists and TFTP server must allow phone to fetch it.
11-22-2019 09:01 AM - edited 11-22-2019 09:03 AM
I managed to upgrade to P0S3-07-5-00.zip version. But cannot upgrade to latest version -
Any suggestions?
11-22-2019 12:58 PM
You should read release notes:
You cannot upgrade to firmware release 8.1(2)SR2 directly from firmware release 8.0(5) or an earlier release. Upgrade to firmware release 8.1(1) first, then upgrade from release 8.1(1) to release 8.1(2)SR2.
11-23-2019 09:22 AM
@Dan Lukes wrote:You should read release notes:
Thanks for your response. But I could only find Release 8.2(0) under the download section. There is no 8.1(1). The latest version is Release 8.12(0). Do you have a link to 8.1(1)?
11-23-2019 12:22 PM
So sorry, I quoted from wrong Release Notes file (related to SCCP flavor of firmware while you are using SIP).
Nether (SIP) Release Notes for Firmware Release 8.12 nor related Readme mentions a mandatory intermediate firmware step. Thus it should not be necessary. So sorry, I has upgraded my 7940 to 8.12 seven years ago. I remember no details.
What files are fetched by phone from TFTP server during boot ? Full list, please. Also, disclose content of OS79XX.TXT file (you created it on tftp server) and it's exact length.
11-23-2019 02:05 PM
