Cisco 7970 Contrast Problem
David Trad
Hi All,
Just wondering if anyone else is having the same issue as me...
I go to settings>>>preferrences>>>Contrast and i find it is greyed out, even though the phone has the latest firmware it still greyed out.
I have unlocked the settings and still no go in getting that setting active.
I have googled this annoyance to death and normal google is my friend, but this time i got dissowned by it
If anyone has any suggestions it would be much appreciated, it is happening to all phones connected too.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
I am pretty sure this menu becomes active if a sidecar is attached to the 7970. The phone itself does not support this option.
Marcos
