1991
Highlighted
Contributor
Cisco BE6K with CUWL Pro
Hi All,
Can someone confirm whether you can order CUWL Pro on the BE6K. Ordering guide makes reference to it however all I can see is CUWL-BE.
Many Thanks
Steve
1 ACCEPTED SOLUTION
Highlighted
CUWL Professional users are supported in a Business Edition 6000 deployment, however the CUWL Professional licenses are not available for order with the BE6000 top-level part number. You will have to order using two different top level part numbers.  Please use top level L-CUWL-ADDON-PROK9 for adding the CUWL-PRO users to the configuration.
1 REPLY 1
Highlighted
