06-16-2013 07:32 PM - edited 03-21-2019 07:28 AM
Hi all,
Kindly need your help. As far as I know BE3K comes pre installed in MCS 7890 - C1 , is it possible if I install in another MCS series?
Thank You,
Best Regards,
Nanda Nurhadyan
Solved! Go to Solution.
06-16-2013 09:55 PM
Nope. Only MCS 7890 as of now.
06-16-2013 09:55 PM
06-17-2013 08:49 PM
Well, thanks for your answer. I appreciate that
Best Regards,
Nanda Nurhadyan
