Cisco Jabber for Android Not registered in BE3000
nexth0pself
Hi all,
I have issue when enabling Cisco Jabber for Android. It always say "Disconnected" and with red logo appear in the top of my phone screen. I've been reinstall and also check the device ID to make sure there is no mistake in typing device ID. I'm connecting my device using Cisco Any Connect Client in android to connect with BE3000 in my office.
Did any one have same issue like this? If there's any solution that I can do, I'm really appreciated. My phone device spec is :
  •     4.1.2 Jelly Bean
  •     GT-I9082 Samsung Grand
  •     Cisco Jabber for Android Version 9.1.2.3324
FYI, I've been successful enabling Cisco Jabber for iPhone (Cisco Jabber for iPhone Version 9.1.2.21344), phone service state say "Connected" and works like a charm. Is there any issue with Jabber for Android and BE3000 ?
Best Regards,
Nanda Nurhadyan
Best Regards,
Nanda Nurhadyan
sanjsinh
Hi Nanda,
Cisco Jabber for Android is officially supported on
the following devices:
Samsung Galaxy Nexus running Android Version 4.04
Samsung Galaxy S II (AT&T) running Android Version 2.3
Samsung Galaxy S II (NTT Docomo) running Android Version 2.3
Samsung Galaxy S i9000 (model number GT-I9000) running Android Version 2.3
Samsung Galaxy ACE (model number GT-S5830L) running Android Version 2.3
Samsung Galaxy Tab international version (model number GT-P1000) running Android Version 2.3
Sanjay
Hi sanjay,
So it's only recommended using that device right? Because I need justification to my customer that only some devices are recommended running with cisco jabber for android
Best Regards,
Nanda
Best Regards,
Nanda Nurhadyan
That is true.
