Hi Simon,
Rest assured we are all waiting for it as well
As far as I am aware this is being worked on and should be released hopefully this side of Xmas... But alas that might be me wishful thinking
There is a way to get it to work but it is CLI only, and this will no doubt break CCA compliance and might even put the system out of SBS scope, so I don't recommend it.
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
