Cisco Spa 30x and spa 50x - Failed - Not Reachable
d.shleg
After flashing 7.6.2f(SR6) firmware, phones lost registration via TLS transport, i enabled debug and see some messages.
TLS certificate is valid. other phones works correctly.
<143>RSE_DEBUG: find a rse that has name [name]and type [type] in rse pool [rp],return address of the found rse  or NULL if not found !!!
	172.17.4.57	02/03 17:31:51.646
<143>RSE_DEBUG:rse was found is not NULL and this rse is safe!!!
	172.17.4.57	02/03 17:31:51.664
<134>Getting a SIP TCP port for line 0
	172.17.4.57	02/03 17:31:51.683
	172.17.4.57	02/03 17:31:51.700
<134>### Get Sip Tcp Port = 5069
	172.17.4.57	02/03 17:31:51.715
	172.17.4.57	02/03 17:31:51.731
<134>[0]SIP/TCP:Connecting...(11)
	172.17.4.57	02/03 17:31:51.747
	172.17.4.57	02/03 17:31:51.762
<134>[0]SIP/TCP:Connect=0, errno=54
	172.17.4.57	02/03 17:31:57.455
	172.17.4.57	02/03 17:31:57.467
<134>[0]SIP/TLS:Connecting ...
	172.17.4.57	02/03 17:31:57.472
	172.17.4.57	02/03 17:31:57.476
<134>[0]SIP/TLS:Connect Failed -1
	172.17.4.57	02/03 17:31:57.481
	172.17.4.57	02/03 17:31:57.486
Please help, any ideas???
d.shleg
I founded solution:
all links to  SPA Certificate Authority (CA) List is broken, but i founded other information here
according information from top phones have preloaded Root Certificate Authority embedded in the firmware:
- Cisco Small Business CA Certificate
- CyberTrust CA Certificate
- Verisign CA certificate
- Sipura Root CA Certificate
- Linksys Root CA Certificate
for solve my problem i implemented option Custom CA RULE with value http://myvoipserver.com/ca_certificate.pem
and phone successly registered, thx all for answers!
12 Replies 12
Dan Lukes
According log you disclosed, phone is trying to connect, but connection attempts is refused by peer. So check log of peer - there may be a notice related to refused connection, including reason. And/Or use an tool to capture packets - it may help to identify the issue cause.
I created dump via wireshark and see Tls error Unknown CA, but i use paid wildcard certificate!
"Paid" doesn't mean "known".  Known mean known. While known mean "found on list of known CA".
But first we need distinguish - who is refusing connection to whom ? Even phone contain certificate and may use it during handshaking if requested by server. Phone certificate is not "paid" certificate you are speaking of ...
How to list of known ca on phone?
i will try to find who is refusing connection and come back again
based on dump posted by me , Unknown CA originated from Phone Device
d.shleg
I founded solution:
Just for completeness ...
Custom CA RULE based solution have major disadvantage - virgin phone (or cleared to factory default) have Custom CA Rule empty, thus it can't download provisioning from server (because considered untrusted). Phone needs to be manually pre-configured. It increases total cost of ownership.
SPA[35]xx models are ready for secure zero-touch provisioning. They accepts initial provisioning URL supplied by DHCP. Provisioning server needs to have certificate issued by a embedded trusted CA. Those certificates are issued free of charge by Cisco.
Hmm, maybe you know how to obtain free certificates from Cisco?
Yes, if reset phones to factory default custom ca cleared, but I configured
provisioning option 66 on my dhcp server. Phones configured from tftp server
I can`t find valid information of embedded CA list on SPA devices
https://community.cisco.com/t5/small-business-support-documents/small-business-ip-phone-documentation/ta-p/3293900
offical link is broken (
for example Verisign in now Symantec, if i paid Symantec it will works for SPA devices?
need up-to-date information about embedded CA
founded here https://web.archive.org/web/20151203011339/https://supportforums.cisco.com/document/96471/spa-certificate-authority-ca-list and converted to pdf, see attach.
remains to find how to make a request for a certificate...
Good job. I has failed searching for the document in question despite I'm co-author of it. I has republished it here.
It's easy to make certificate request. I assume you are asking where to submit CSR to.
Cisco Sales Representative should issue certificate for you. Cisco SMB Support should you to identify a Cisco Sales Representative.
If everything else will fail, write private message to me.
Wow, thx you for republication post!
I do not have  contact cisco sales or smb support and emailed to ciscosb-certadmin@cisco.com with question and wait answer.
If i have the problems with obtain certificate i will ask you.
