Cisco spa504g phones toggle button prefix number
markberry666
I have gone through the manual and searched support sites but so far have been unable to find a way to create a toggle soft key that will add a prefix to a dialed number, I need this to add 1831 to numbers dialed out when the soft key is on, and to do nothing when it is off. I know *67 should work but I am in Australia and using a custom Pbx (asterisk) so the above mentioned method would be ideal. The feature is to block outbound caller ID in a toggle feature not per call.
Cisco spa504g phones with software version 7.4.9c, hardware version 1.0.4
Rgds
Mark
paolo bevilacqua
Wrong forum, post in "Small business voice - SPA phones". You can move your post using the actions panel on the right.
thanks for the tip Paolo, I have done that. Hopefully I will get a response now.
Rgds
Mark
Mark,
I've did this before, but in another way.
I've created two "lines" and gave each line a different dialplan. In the dialplan i've substituted the the dialstring with the prefix. It's working pretty good.
Erik Dekkers
Jener Network Solutions
Hi Erik
thanks for the response. I still havent found an ideal solution but I think yours could work for me.
can you give me a little more info on how you set the Line Keys to choose an outbound route or dialplan on the PBX.
Rgds
Mark
