CISCO UC-540 TRUNK SIP CONFIG
Hi everyone, I'm new to the blog ... I need help setting up the sip trunk. outgoing calls work and incoming calls report this error:
UC540#debug ccsip calls
SIP Call statistics tracing is enabled
UC540#
000329: Mar 6 12:20:00.613: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with SIP000E08D86B0E Port 1 (half duplex).
000330: Mar 6 12:20:00.653: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on FastEthernet0/0 (not half duplex), with SIP000E08D75A5C Port 1 (half duplex).
000331: //-1/A6A327DC8056/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x889AE3D8
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number :
Called Number : 5406093027
Source IP Address (Sig ): 192.168.1.238
Destn SIP Req Addr:Port : 212.97.59.76:0
Destn SIP Resp Addr:Port : 212.97.59.76:5060
Destination Name : 212.97.59.76
000332: //-1/A6A327DC8056/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 100
Disconnect Cause (SIP) : 400
could someone please explain to me how to do it? are novice.
Good job everyone.
0 Replies 0
